Text on LCD moved from column
jacktaylor
PostPosted: Mon May 14, 2018 2:55 pm     Reply with quote
Hello friends.
I have this simple prototype function in my program. I do not know why the value of the entire 8-bit pulse variable is being printed on LCD column 12. The same is true of the variable VAL that does not appear on the LCD, since it is outside the 16-column LCD field. The variable temperature is printed in the correct position, ie in column 6 of the LCD. Can anyone help with this problem?
void readtemp()
temperature = ds1820_read();
lcd_gotoxy(1,1);
printf(lcd_putc,"PWM:%.0u",pulse);
lcd_gotoxy(1,2); //lcd_gotoxy para coluna, linha
printf(lcd_putc,"TMP:%.0f VAL:%.0u",temperature,value);
Rolling Eyes
PostPosted: Mon May 14, 2018 4:32 pm     Reply with quote
hmm... what LCD module and which LCD driver ? kinda important as not all LCD modules use the same firmware to access them.
Re: Text on LCD moved from column
PostPosted: Mon May 14, 2018 5:34 pm     Reply with quote
I assume you want .0 in front of the 'value'.
Try doing the printf like this:
printf(lcd_putc,"TMP:%.0f VAL: .0%u", temperature, value);
Then it won't print it in column 18. It should print in column 13.
jacktaylor
PostPosted: Tue May 15, 2018 9:41 am     Reply with quote
Thank you PCM Programmer. The text has now been printed at the desired LCD position.
Actually what I really wanted was to have no decimal places after the value of the LCD variable.
When I use it printf(lcd_putc,"TMP:%f VAL:%u",temperature,value); 85.00 is printed for the TEMP: variable on the 16x2 LCD. and VAL: is set to 12.
When I use it printf(lcd_putc,"TMP:%.0f VAL:%u",temperature,value); 85 is printed for the TEMP: variable on the 16x2 LCD. and VAL: is set to 128.
ie the second case is what I need for my program. It's strange because I believe when using printf (lcd_putc, "TMP:% f VAL:% u", temperature, value); TMP could not be printed to 2 decimal places.
value represents the PWM sitting in the program as a function of temperature.
PostPosted: Tue May 15, 2018 12:54 pm     Reply with quote
If you don't want any decimals, print it as an integer:
printf(lcd_putc,"TMP:%ld VAL:%u",(signed int16)temperature,value);
Why would you think a float would default to not printing decimals?....
Converting to an int and printing as this will result in slightly smaller and faster code.
jacktaylor
PostPosted: Mon May 21, 2018 3:57 pm     Reply with quote
Thanks Ttelmah for the help.
