#int_rda help
chingB
#int_rda help
PostPosted: Fri Jan 16, 2004 4:28 am     Reply with quote
hello...
I have a code that will receive packets from a PC. The packet send by the PC is of variable length but not exceeding 64bytes.
Code list:
#define RX_SIZE 64         // RS485 buffer for serial reception
byte rxbuffer[RX_SIZE];    // RS485 serial RX buffer
byte rx_in  = 0;           // RS485 RX data IN index
byte rx_out = 0;           // RS485 RX data OUT index
#int_rda
void rx_isr()         // RS485 serial RX interrupt service routine
   int t;                   // local data storage
   if (kbhit(Com1))
      t = fgetc(Com1);  // get rx data and save to buffer
      rxbuffer[rx_in] = t ; // and save to buffer
      t = rx_in;                    // save current rx index
      rx_in = (rx_in+1) % RX_SIZE;  // increment index
My concern is? how can I able to detect that their is no character send by the PC? and How can I incorporate a flag that will prevent a multi-trigger of another packet while the program process the previous packet?
BTW, I am using PIC18F452 at 20MHz clock.
Need your info, comments and/or suggestions.
Thank you.
Re: #int_rda help
PostPosted: Fri Jan 16, 2004 4:37 am     Reply with quote
chingB wrote:
hello...
Code list:
#int_rda
   if (kbhit(Com1))
Thank you.
1) Consider flow control.
2) Do a search back through the archives. Neutone (I think), published a very tidy combination of buffered receive, with a timer based 'time out'.
chingB
PostPosted: Fri Jan 16, 2004 5:46 am     Reply with quote
I got the code of neutone... listed below:
#int_TIMER1                                                 //*********************************
TIMER1_isr()                                                // 1.5 byte periods after last byte I&O
{  disable_interrupts(int_TIMER1);                          // TMR1 Overflow Interrupt Enable bit off
   PacketA_Byte_Count=PacketA_Index;                        // Store length of packet
   if (PacketA_TX)                                          // Has last bit cleared transmit shift buffer?
   {  PacketA_TX=0;                                         // Turn off 485 transmitter driver
   else                                                     // Incomming packet recieved?
   {  PacketA_IN=1;                                         // Tag packet for processing
#int_RDA                                                    //**************
RDA_isr()                                                   // BYTE RECEIVED
{  PacketA_Data=fgetC(chanA);                               // Store incoming byte
   if(!PacketA_IN&&!TXIE)                                   // Don't receive transmitting noise or overrun last packet
   {  if(bit_test(RS232_ERRORS,2))                          // Check for framing errors
      {  if (++PacketA_Errors & 8)                          // If 32 errors
         {  if(!(PacketA_Baud & 16))                        // is baudrate locked
            {  if(++PacketA_Baud & 8)
               PacketA_Baud=0;
               if(PacketA_Baud==0)
               {  Set_UART_Speed(57600,chanA);
                  PacketA_timeout=64128;
               if(PacketA_Baud==1)
               {  Set_UART_Speed(38400,chanA);
                  PacketA_timeout=63424;
               if(PacketA_Baud==2)
               {  Set_UART_Speed(28800,chanA);
                  PacketA_timeout=62720;
               if(PacketA_Baud==3)
               {  Set_UART_Speed(19200,chanA);
                  PacketA_timeout=61312;
               if(PacketA_Baud==4)
               {  Set_UART_Speed(9600,chanA);
                  PacketA_timeout=57088;
               if(PacketA_Baud==5)
               {  Set_UART_Speed(4800,chanA);
                  PacketA_timeout=48640;
               if(PacketA_Baud==6)
               {  Set_UART_Speed(2400,chanA);
                  PacketA_timeout=31744;
               if(PacketA_Baud==7)
               {  Set_UART_Speed(1200,chanA);
                  PacketA_timeout=0;
      PacketA[PacketA_Index++]=PacketA_Data;                // Place incoming byte in Packet Buffer
      set_timer1(PacketA_timeout);                          // Wait 1.5 byte periods then interrupt
      TMR1IF=0;                                             // Clear timer1 overflow Interrupt Flag bit
      enable_interrupts(int_TIMER1);                        // TMR1 Overflow Interrupt Enable bit on
set_timer1(PacketA_timeout); ---> how can I compute for timer1 using PIC18F452 at 20MHz clock? what would be the difference if I use timer3 instead of timer1?
Is timer1 calculation has a correlation with the baudrate for serial communication? What would the calculation in order to have 1.5bytes period for either timer1 or timer3?
I notice that the code use PacketA_TX=0; as flow control for transmit and receive packet. I don't see any point on how I can detect that PC has already stop sending data? I can't figure out the code for multi-trigger prevention.
In addition, I plan to use a 115,200bps baudrate for the UART.
Any help please....
Thnx
Neutone
PostPosted: Fri Jan 16, 2004 8:58 am     Reply with quote
chingB wrote:
               PacketA_Baud=0;
               if(PacketA_Baud==0)
               if(PacketA_Baud==1)
               if(PacketA_Baud==2)
               if(PacketA_Baud==3)
               if(PacketA_Baud==4)
               if(PacketA_Baud==5)
               if(PacketA_Baud==6)
               if(PacketA_Baud==7)
                  PacketA_timeout=0;
Any help please....
Thnx
PacketA_TX is the pin that turns the 485 driver chip to transmit.
Timer 3 will work just as well as timer 1.
I was using a clock of 19660800hz so 20Mhz would use the same timer preloads just fine.
If you plan to run at 115,200bps baudrate you should not use this routine. I had a lot of timing issues with getting into and out of the interupt code at that baud rate.
chingB
PostPosted: Fri Jan 16, 2004 5:41 pm     Reply with quote
Can you provide me a math calculation for the values of PacketA-timeout. Do you have any idea on how I can prevent muti-trigger of packet?
Thanx
Neutone
PostPosted: Mon Jan 19, 2004 8:55 am     Reply with quote
The timer counts up from 0 to 65536 it then overflows to 0 and interupt occures.
With the timer set to increment every instruction cycle what value do you preload to cause the timer to interupt after a specified period?
The byte period is 1mS for 9600 baud.
The timeout period is 1.5 byte periods.
There are 1 instruction cycle in 0.25 uS at 20Mhz crystle.
There are 6000 instruction cycles in in 1.5mS.
The value to preload for for 9600 baud is 65536-6000.
This assumes a byte stream on the serial port. You can not get this to work if the bytes arrive with a pause between them.
To prevent multitrigger of packets do not clear the packet in flag untill the packet has been fully processed.
