Explorer 16/32 LCD not working properly
E_Blue
PostPosted: Mon Apr 30, 2018 9:33 pm     Reply with quote
I'm make a little program to learn how PIC24 works but doesn't work as expected.
In the LCD I get
"OK! "
"SECONDS "
This is the program.
 * File:   Test_PIC24_01.c
 * Author: E_Blue
 * Created on 22 de abril de 2018, 00:28
#include <24fj1024gb610.h>
#device ICD=2
#use delay(clock=4M)
#fuses NOPROTECT,XT,NOWDT,ICSP2
//#USE FAST_IO (ALL)
  #define LCD_ENABLE_PIN  PIN_D4
  #define LCD_RS_PIN      PIN_B15
  #define LCD_RW_PIN      PIN_D5
 // #define LCD_DATA0       PIN_E0
 // #define LCD_DATA1       PIN_E1
 // #define LCD_DATA2       PIN_E2
 // #define LCD_DATA3       PIN_E3
  #define LCD_DATA4       PIN_E4
  #define LCD_DATA5       PIN_E5
  #define LCD_DATA6       PIN_E6
  #define LCD_DATA7       PIN_E7
  //#define LCD_LINE_TWO 0xC0
  #define LCD_LINE_LENGTH 16
  //#define E_LCD 1
//#include <lcd_mod.c>
#include <lcd.c>
#define Led_3 PIN_A0
void main() {
    long time=0;
   // set_tris_a(0xFE);
    //set_tris_e(0x00);
    lcd_gotoxy(1,1);
    printf(lcd_putc,"LCD OK!");
        lcd_gotoxy(1,2);
        printf(lcd_putc,"Seconds: %Lu",time);
        //output_high(Led_3);
       // output_low(Led_3);
        time++;
I tried with the J19(R/W) jumper plugged and unplugged.
The Explorer 16 demo works ok (XC16), I don't understand why CCS code doesn't work.
Since as far I read this microcontroller have remappable pins function I think is something related to port configuration.
I'm new with 16bit microcontrollers, I used a lot a 18F PIC microcontrollers
Does LCD.C is compatible with PIC24FJ?
Electric Blue
PostPosted: Mon Apr 30, 2018 11:12 pm     Reply with quote
The first thing is where are you getting 4MHz from?. The explorer board has an 8MHz crystal as standard. You may well be overclocking the display.
Do a basic 'flash an LED' test and get your clock options right first.
E_Blue
PostPosted: Tue May 01, 2018 9:45 am     Reply with quote
Flash a LED was the first program, then I added the LCD management code.
At first I make the program thinking that its going to run at 8MHZ as default, but the LED flash at half the speed expected.
I debug this program and seem like the program always read the busy bit as busy.
I also put a breakpoint when the LCD.C routine put LCD_ENABLE_PIN high but I read near to zero volts, so that's why I'm thinking that can be a port configuration problem.
With the flashing LED program it works all ok, and the LED flash OK.
After I added the LCD code the LED never light on.
Anyway I will try what you suggest me just to be 100% sure about clock speed.
Electric Blue
