PIC C compiler config bits set/reset option dspic30f4011
Posted: Mon Apr 30, 2018 3:10 pm
Hello
I am using PIC C compiler. I am using a dspic30f4011 Microcontroller.
I want to ask if I could set/reset configuration bits of a specific module/function register??? or I am bound to use predefined functions in PIC C??
e.g.
T1CONbits.TON = 0; // Turn off timer 1
T1CONbits.TSIDL = 0; // Continue operation during sleep
T1CONbits.TGATE = 0; // Gated timer accumulation disabled
T1CONbits.TCS = 0; // use Tcy as source clock
T1CONbits.TCKPS = 0; // Tcy / 1 as input clock
Can I do this in PIC C????
newguy
Posted: Mon Apr 30, 2018 6:15 pm
Unless the PIC is relatively new, the compiler features built-in functions that do this sort of thing for you. In your example,
I want to ask if I could set/reset configuration bits of a specific module/function register ?
The answer is yes, if want to, you can do it that way.
The IDE version of the CCS compiler can generate a header file like this:
http://www.ccsinfo.com/forum/viewtopic.php?t=46210
I assume you want this because you're translating code to CCS from
another compiler, and it sets the bits to configure peripherals.
