SW Uart on PCD devices
Goto page Previous  1, 2
kmp84
PostPosted: Mon Apr 30, 2018 6:22 am     Reply with quote
Hi TT,
Yes, simple getc, putc and printf test example works correct.
Thanks!
PostPosted: Mon Apr 30, 2018 7:02 am     Reply with quote
You are sure the data format is 'right?. Specify it in the setup. So 8 bits no parity, and double check at the other end.
The only reason it can really go wrong, is that the getc, 'thinks' it has finished, and returns, while the actual incoming data has another low clock which then arrives. This then means the interrupt triggers again, and starts to read incorrect data. Now the sort of thing that would cause this would be (for example) having 9bit data arriving. The software UART does not 'test' for framing errors, so would not report a problem.
kmp84
PostPosted: Mon Apr 30, 2018 8:04 am     Reply with quote
Mr.TT com. parameters are OK(9600/8/N/1). With those parameters and without ext_int sw_uart work correct! Another strange thing is when debugging, after second byte I sent int_ext fire!
PostPosted: Mon Apr 30, 2018 11:40 am     Reply with quote
Which says it is seeing a rising edge....
Have you got a logic analyser?.
Pulse a pin when the interrupt handler gets to the end of the getc. Then have the analyser record the incoming data stream from this point.
kmp84
PostPosted: Wed May 02, 2018 12:23 am     Reply with quote
Hi TT,
I have no logic analyzer, but simple test with push button ext_int fire from low to high transition which is incorrect!
PostPosted: Wed May 02, 2018 1:11 am     Reply with quote
OK.
A quick look at the listing shows you are hitting a database error with the compiler for this chip....
//Use this:
#bit INT1EP=getenv("BIT:INT1EP")
#zero_ram
void main(){
   delay_ms(500); // wait PLL Lock.
   printf("\r\n Hello from 'SW-UART' on DsPic33Ep512MU810");
   INT1EP=TRUE; //falling edge
   clear_interrupt(INT_EXT1); //in case it is set by setting the edge
   ENABLE_INTERRUPTS(INT_EXT1);
   for(;;){
       if(fl){
          putc(c);
          fl = FALSE;
Report this to CCS.
For some reason the compiler is setting bit 5, not bit 1 to control the polarity.
kmp84
PostPosted: Wed May 02, 2018 5:13 am     Reply with quote
Now INT_EXT fire correct, but the data is wrong!
PostPosted: Wed May 02, 2018 7:05 am     Reply with quote
What do you mean wrong?. If it is triggering at the right place, then it should give the same as when you use it without interrupts (though you might need the SAMPLE_EARLY option).
What is it giving? If you send 'A' for example, what do you get?.
PostPosted: Wed May 02, 2018 8:03 am     Reply with quote
hmm.. I'm wondering if there's maybe no MAX232 between PIC and PC ?
PostPosted: Wed May 02, 2018 8:18 am     Reply with quote
He claims though that it works without using the interrupt. Otherwise I'd suspect something similar....
kmp84
PostPosted: Wed May 02, 2018 12:30 pm     Reply with quote
Yes, without using interrupt, getc and putc data are equal. With interrupt using every time I get 0x00.
PostPosted: Thu May 03, 2018 5:14 am     Reply with quote
It might be time to post your current code. There's been a LOT of changes in this thread and something might now be obvious, at least it could be tested by others.
kmp84
PostPosted: Thu May 03, 2018 5:36 am     Reply with quote
temtronic wrote:
It might be time to post your current code.There's been a LOT of changes in this thread and something might now be obvious,at leat it could be tested by others.
I also think so:
#include <33EP512MU810.h>
#device ICSP=1
#use delay(crystal=8MHz, clock=16MHz)
#FUSES CKSFSM                   //Clock Switching is enabled, fail Safe clock monitor is enabled
#FUSES NOJTAG                   //JTAG disabled
#FUSES NOPROTECT                //
#pin_select INT1=PIN_G12
#use rs232(baud=9600, xmit=PIN_G13, rcv=PIN_G12, SAMPLE_EARLY)
char c;
int1 fl = FALSE;
#int_ext1
void int1_swuart_isr(void){
   c=getc();
   fl = TRUE;
#zero_ram
void main(){
   char c;
   //ext_int_edge(INT_EXT1, H_TO_L);
   for(;;){
      if(fl){
         putc(c);
         fl = FALSE;
      //c = getc();  // ok
      //putc(c);     // ok
P.S I'm using MAX3232 level convertor.
Page 2 of 2
