passing array of structures
kmp84
PostPosted: Wed Apr 18, 2018 5:37 am     Reply with quote
Hello Everyone,
What is the true way to passing array of struct to function? Below example does not work correct!
char str1[] = "123456";
typedef struct {
   int8 arr1[6];
   int8 arr2[12];
}st;
st st1;
#zero_ram
void main(){
   memcpy(st1.arr1, str1, 6);
   memcpy(st1.arr2, st1.arr1, 6);
   while(TRUE);
Best Regards!
PostPosted: Wed Apr 18, 2018 7:01 am     Reply with quote
First problem is that str1, is seven characters long. There is not sufficient space in the arr1 to hold the string. Remember a 'string' in C, is an array of characters, with a terminating null added. str1 is seven characters long. You are copying it without it's terminating null....
The address will be correctly passed by what you show. You can use the 'explicit' form (&st1.arr1[0]), but either is syntactically correct, and the compiler will correctly accept either.
If you use strcpy, not memcpy. This will automatically copy the correct number of characters, but won' handle the destination not being large enough.....
kmp84
PostPosted: Wed Apr 18, 2018 7:24 am     Reply with quote
Hi, Ttelmah,
I know about null terminating. It is only example to show you what is the problem. The real data is binary not string. Only first byte from str1 is copied to st1.arr1 and first byte from st1.arr1 to st1.arr2.
CCS C v.5.075, dsPic33EP512MU810.
PostPosted: Wed Apr 18, 2018 7:46 am     Reply with quote
It merrily copies all six bytes for me on your chip & compiler version. Either your 'example' is not showing the real problem, or something else not included is making it go wrong.
kmp84
PostPosted: Thu Apr 19, 2018 1:09 am     Reply with quote
Hi Ttelmah,
Everything works correctly! I thought this was not working because ICD U80 stopping on first byte after command "step over". Sorry for my mistake! Confused
I have another question about passing nested structure to function. Here is some test program.
#include <33EP512MU810.h>
#device ICSP=1
#use delay(crystal=8MHz, clock=32MHz)
#FUSES CKSFSM                   //Clock Switching is enabled, fail Safe clock monitor is enabled
#FUSES NOJTAG                   //JTAG disabled
#FUSES NOPROTECT
/**************Test 3 ******************/
struct _st{
   int8 a;
   int8 b;
   rtc_time_t t1;  // <33EP512MU810.h>
   rtc_time_t t2;  // <33EP512MU810.h>
struct _st st[4];
void func(rtc_time_t &date_time){
   unsigned int8 a;
   a = date_time.tm_year;
#zero_ram
void main(){
   int8 i = 0;
   func(st[i].t1);
   while(TRUE);
The CCS compiler says: *** Error 105 "main.c" Line 100(15,17): Different levels of indirection
PostPosted: Thu Apr 19, 2018 1:34 am     Reply with quote
It's right....
Think about it. Your 'func' is expecting to receive a pointer to an rtc_time_t type. You are passing it the variable.
func(&st[1].t1);
As structure name is _not_ automatically treated as an address. This is reserved for arrays. A structure name itself (so the outer container here), is always treated as a pointer, but this is reserved for the first element in a structure. So a structure inside a structure can't be used as a shortcut to it's address
kmp84
PostPosted: Thu Apr 19, 2018 1:59 am     Reply with quote
I have no idea how to workaround. Sad
PostPosted: Thu Apr 19, 2018 2:48 am     Reply with quote
Er. I posted what you have to use.....
kmp84
PostPosted: Thu Apr 19, 2018 3:49 am     Reply with quote
Hi Ttelmah,
You mean "func(&st[1].t1); ", which doesn't work! Also the struct array index is not const value!
Thanks.
PostPosted: Thu Apr 19, 2018 4:12 am     Reply with quote
The reason it doesn't work, is your syntax in the function is wrong:
   a = date_time->tm_year;
//You are passing an _[u]address[/u]_ you need to work from this
func(&st[1].t1);
Will happily accept a variable index.
kmp84
PostPosted: Thu Apr 19, 2018 5:10 am     Reply with quote
Finally it's working! Smile
#device ICSP=1
#FUSES NOPROTECT
#pin_select U3RX=PIN_G12   // Rx Com3.
#pin_select U3TX=PIN_G13   // Tx Com3.
#use rs232(UART3,baud=115200,errors)
/**************Test 3 [ok] ******************/
struct _st{
   int8 a;
   int8 b;
   rtc_time_t t1;
   rtc_time_t t2;
struct _st st[4];
void func(rtc_time_t *date_time){
   unsigned int8 a;
   unsigned int8 b;
   b = date_time->tm_mon;
   printf("\r\n a: %u, b: %u", a, b);
#zero_ram
void main(){
   int8 i;
   i = 0;
   st[i].t1.tm_year = 18;
   st[i].t1.tm_mon = 4;
   func(&st[i].t1);
   while(TRUE);
I have to educate more myself with C language.
Shocked
Thanks Mr.Ttelmah!
PostPosted: Thu Apr 19, 2018 6:28 am     Reply with quote
Yes.
One 'trick' that is well worth learning, is to use useful names. So in the rtc_time, they use rtc_time_t to say 'this is a type'. If you call pointers when they are passed fo functions, something like *date_time_ptr, then it gives you a really solid reminder in the function, that this is not the variable directly, but a pointer to it. Similarly there is a 'semi standard' in C to reserve things declared in ALL_UPPER_CASE as enums or defines. Then use explicit sizes (int8, int16 etc.), rather than assuming an 'int' is a particular size. Combine these, and it helps massively to keep track of what you are doing. Smile
