Problem in TCP/IP Communication using PIC18F97J60
Mrinmoy Dey
PostPosted: Sat Apr 14, 2018 12:02 am     Reply with quote
Hii All!!!
I am facing some problem to do LAN Communication using PIC18F97J60. My job is to fetch real-time data from a place which I have successfully done using RS485 and send the same data to a server through LAN.
But this communication is still not clear to me after putting 2 days behind it.
Can anyone give me a brief idea what to do next step by step to make the communication done ? My MPLAB version is 8.92 and compiler version is 5.025.
Anyone having any idea how to do it, please turn up.
PostPosted: Sat Apr 14, 2018 5:07 am     Reply with quote
try 'googling' for it. There is a TON of PIC-LAN projects on the 'web',so you're not the first to try doing it. I'd even look in the code library here, or search this forum.
The key is to google the proper 'keywords' and their order.
I can't supply working code as I do not use 'PC based LAN' technology as it's unsecured and top heavy.
Jay
Mrinmoy Dey
PostPosted: Sat Apr 14, 2018 5:13 am     Reply with quote
@temtronic
Thnx for answer.. May be I am not Googling it with proper keywords.. Can you suggest the proper keywords.
PostPosted: Sat Apr 14, 2018 5:23 am     Reply with quote
you could try 'PIC18F97J60 LAN ccs c code' or something similar
Mrinmoy Dey
PostPosted: Sat Apr 14, 2018 7:44 am     Reply with quote
Thanks a lot .. Smile
