decimal position
PROMOD
decimal position
PostPosted: Fri Apr 06, 2018 12:43 pm     Reply with quote
Usually float type variable can have two decimal position after point.
example:
float a; //So a can have 3.33 but can't have 3.3333
But I would like to declare a variable which can have four decimal position after point, in other words which can have 3.3333, then what should I do?
PostPosted: Fri Apr 06, 2018 3:19 pm     Reply with quote
It's not limited to 2 digits after the decimal point.
Do this:
float a = 3.3333;
PROMOD
PostPosted: Fri Apr 06, 2018 7:59 pm     Reply with quote
#include<18f4431.h>
#device adc=10
#fuses xt,nowdt,nolvp
#include "flex.c"
float k=0,a=0,r=0,p=0,pav=0.0000,en=0.0000;int16 i=0,n=0;
#int_timer2
void pwm_interrupt()
i=i+1;
set_adc_channel(0);
k=read_adc();//to covert voltage value of a certain moment in channel 0 into digital value
k=((k/204)-2)*(313/2);// here offset value is 2; (311/2) is used to transfer scaled voltage value into original value.
set_adc_channel(1);
a=read_adc();//to covert current value of a certain moment in channel 1 in to digital value.
a=((a/204)-2)*(1/0.033);//here offset value is 2. 1023/5=204; (1/0.033) is used to transfer scaled current value into original value.
p=p+a*k; //a*k= power of that certain moment. p storing the sumation of power of 49 different moment.
if(i==50)
n=n+1;
pav=p/i;en=en+pav*0.02; //pav is the averag of whole some of 50 different moment value; setting all variable to 0.
if(n>100)
lcd_putc("\f");
printf(lcd_putc,"PAVRAGE = %fKW",pav/1000);//printing pav after converting it into KW.
lcd_gotoxy(1,2);
printf(lcd_putc,"ENERGY  = %fKWH",en/(1000*60*60)); //printing en after converting it into KWH.
n=0;
i=0;p=0;pav=0;
lcd_gotoxy(1,2);
printf(lcd_putc,"ENERGY  = %fKWH",en/(1000*60*60);
setup_timer_2(t2_div_by_16,125,1); //interrupt setting time(in every 4*10^-4 seconds interrupt is happening)
enable_interrupts(global);
enable_interrupts(int_timer2);
setup_adc_ports(all_analog);
setup_adc(adc_clock_internal);
Then in this program why is the variable "en, pav, etc" not showing four decimal position after point in LCD display?
Thanks in Advance!
PostPosted: Fri Apr 06, 2018 8:55 pm     Reply with quote
Add the width and precision numbers shown in bold below:
printf("lcd_putc, PAVRAGE = %7.4fKW", pav/1000);
lcd_gotoxy(1,2);
printf("lcd_putc, ENERGY = %7.4fKWH", en/(1000*60*60));
Mike Walne
PostPosted: Sat Apr 07, 2018 2:03 am     Reply with quote
Why have you created yet another version of your average power measurement post?
You've been given loads of advice and hints on how to correct numerous errors.
The code you're persisting in using hasn't a snowball in Hell's chance of success.
At this stage, I give up.
Mike
