WDT in PIC18 it's not working
pilar
PostPosted: Thu Apr 05, 2018 8:04 pm     Reply with quote
Hi, I am use a PIC18F4620 at 20Mhz and the CCS version 4.074 to I am using the WDT.
As you can see in my code, the WDT is working, the problem is that it does not stop when the setup_wdt(WDT_OFF) command, there are parts of my code that I need to disable and in others enable the WDT but it is not disabled and the WDT keeps running, can someone tell me what my error is?
#include <18F4620.h>
#fuses HS,WDT32768,PROTECT,NOLVP,NOBROWNOUT
#use delay(clock=20MHz)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)// RS232 Estándar
main()   {
   switch ( restart_cause() )
      case WDT_TIMEOUT:
         printf("\r\nRestarted processor because of watchdog timeout!\r\n");
      case NORMAL_POWER_UP:
         printf("\r\nNormal power up!\r\n");
   //setup_wdt(WDT_ON)
   setup_wdt(WDT_OFF);
      restart_wdt();
      printf("Hit any key to avoid a watchdog timeout.\r\n");
      getc();
PostPosted: Thu Apr 05, 2018 8:25 pm     Reply with quote
Add NOWDT to your #fuses line. Then you can turn the WDT on and off
by software control. This is in the PIC data sheet.
RF_Developer
PostPosted: Fri Apr 06, 2018 4:12 am     Reply with quote
If you are having to turn the watchdog on and off then you've got a big design/architecture problem. If you use the watchdog at all, and most people who are using it/having trouble using it on PICs don't need it at all and would be better off without it, then you should turn it on and leave it on. If you keep turning it on and off then you pretty much lose any protection against errant code that it provides.
