Preload Eeprom with Null-Terminating
pilar
PostPosted: Thu Apr 05, 2018 8:39 am     Reply with quote
I have a doubt, I need preload the eeprom of a Pic18FXXX with a string value but a NULL-Terminating, this definition is OK?
#ROM 0xF000EC = {"0054123456789\0"}
PostPosted: Thu Apr 05, 2018 9:32 am     Reply with quote
Obvious answer is to try it, see what gets written to the EEPROM. I suspect as written it would write a ...9 then a slash then a zero .
PostPosted: Thu Apr 05, 2018 12:30 pm     Reply with quote
The quoted string automatically puts a zero at the end. The "\0" adds
an additional zero at the end. Your posted code will put two zeros at
the end.
To see this, compile the following program using MPLAB vs. 8.92.
Then go to this menu: View / EEPROM
#include <18F46K22.h>
#fuses INTRC_IO, NOWDT, BROWNOUT, PUT, NOPBADEN
#use delay(clock=4M)
#rom getenv("EEPROM_ADDRESS") = {"0054123456789\0"}
while(TRUE);
PostPosted: Thu Apr 05, 2018 4:21 pm     Reply with quote
hmm, that's interesting... I compile the program and yes, two zeros on the end.
curious as to why, I went to the manual
from the manual...
address is a ROM word address, list is a list of words separated by commas
NO mention that 'strings' can be in the list...hmm.
I'd have thought everything between the double quotes would have been treated as string characters, 0x39 for the "9" and the "/" would be a string as well, not the 'command code' for a null. The 2nd " would be the 'command' to say 'end of string, and the compilerwould add the null terminator.
pilar
PostPosted: Thu Apr 05, 2018 4:41 pm     Reply with quote
Yes, is true, at the end I get three zeros...
Thank you
