Programming Failed. MPLAB 8.92 ICD3 Debugging works.
Jody
PostPosted: Mon Mar 12, 2018 4:12 am     Reply with quote
I have MPLAB 8.92 in debugging and this works great.. Selected the ICD3 as a debugger and this works...
When switching to the ICD3 as a programmer and setting MPLAB to Release it recognize the PIC (16F873A) and returns connected and gives the version number of the PIC.
But when I want to program it it says "Programming Failed"
Where o where is my mistake??
Here is my header file... maybe I am doing something wrong with the fuses.
#include <16F873A.h>
//#device ICD=NODEBUG
#device ADC=16
#FUSES NOWDT                //No Watch Dog Timer
#FUSES NOBROWNOUT           //No brownout reset
#FUSES NOLVP                //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOPUT
#FUSES HS
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7, enable = PIN_A5 ,bits=8, stream = RS485)
#define VOLTAGE   PIN_A0
#define ENABLE   PIN_C0
#define FWD_REV   PIN_C5
#define   MAXINPUTBUF   25
#define DELAY 1000
Best regards,
Jody
PostPosted: Mon Mar 12, 2018 4:36 am     Reply with quote
While I don't use an ICD or 'debugger'....am familiar with MPLAB.
After you change the build configuration from 'debug' to 'release' you DO recompile again ( F10) ??
Fuses can be set by either MPLAB or the program, there's an option under 'config', configuration bits', top line, small check box...config bits set by code..
Usually when it fails, it'll display a few bytes 'expected' vs 'read'.
maybe this helps you ?
Jay
Jody
PostPosted: Mon Mar 12, 2018 5:14 am     Reply with quote
Hi Jay,
Thanks for the information...
Suddenly it started to work...
I switched down everything (PC uC etc.) and after restarting it works....
Something was a little lost into the woods.....
Thanks for your help!!!
Regards,
Jody
PostPosted: Mon Mar 12, 2018 5:51 am     Reply with quote
glad it's 'up and running' !
re:..Something was a little lost into the woods.....
yeah, know about that ! For some unknown reason Windows7 decided to lose 20,000 of my PIC files couple months ago... It irks me I can't locate them but at least the older stuff(20+ years) is stored on a Win98 harddrive 'somewhere' in the basement.
Jay
