pin B3 on 18f45k22
tysie
pin B3 on 18f45k22
PostPosted: Thu Jan 04, 2018 2:20 pm     Reply with quote
I try to use B3 as an input.
Everything works fine as an output, but now I connected a 10k pull-up resistor and a hall switch to the port, but the port is always low.
If i use only a pull-up and the hallswitch i can measure the signal going down when a magnet is present.
Why can't i use it as an input?
The header:
#include <18F45K22.h>
#device ADC=10
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#use delay(internal=16MHz)
#use FIXED_IO( A_outputs=PIN_A7,PIN_A6,PIN_A5,PIN_A4,PIN_A0 )
#use FIXED_IO( B_outputs=PIN_B2,PIN_B1,PIN_B0 )
#use FIXED_IO( C_outputs=PIN_C7,PIN_C6,PIN_C5,PIN_C4,PIN_C3,PIN_C2,PIN_C1,PIN_C0 )
#use FIXED_IO( D_outputs=PIN_D7,PIN_D6,PIN_D5,PIN_D4,PIN_D3,PIN_D2,PIN_D1,PIN_D0 )
#use FIXED_IO( E_outputs=PIN_E2,PIN_E1,PIN_E0 )
#define LED   PIN_A0
#define S1   PIN_A1
#define DISPLAY2C   PIN_A4
#define DISPLAY2B   PIN_A5
#define DISPLAY2D   PIN_A6
#define DISPLAY2E   PIN_A7
#define DISPLAY3C   PIN_B0
#define DISPLAY3B   PIN_B1
#define DISPLAY3A   PIN_B2
#define S4   PIN_B5
#define S3   PIN_B6
#define S2   PIN_B7
#define DISPLAYCOM1   PIN_C0
#define DISPLAYCOM2   PIN_C1
#define DISPLAY3F2   PIN_C2
#define DISPLAY3G2   PIN_C3
#define POWERENABLE   PIN_C4
#define DISPLAY3B2   PIN_C5
#define DISPLAY3A2   PIN_C6
#define DISPLAY1BC   PIN_C7
#define DISPLAY3E2   PIN_D0
#define BUZZER   PIN_D1
#define DISPLAY3D2   PIN_D2
#define DISPLAY3C2   PIN_D3
#define DISPLAY3F   PIN_D4
#define DISPLAY3G   PIN_D5
#define DISPLAY3E   PIN_D6
#define DISPLAY3D   PIN_D7
#define DISPLAY2A   PIN_E0
#define DISPLAY2F   PIN_E1
#define DISPLAY2G   PIN_E2
tysie
PostPosted: Thu Jan 04, 2018 2:34 pm     Reply with quote
When i tie the pin directly to VCC a current of 50mA flows through it
tysie
PostPosted: Thu Jan 04, 2018 2:38 pm     Reply with quote
Solved,
It is a copied project in mplab,
But it looks like it takes the header file of the old project.
