Interfacing hc-05 bluetooth module with pic 18f2550
Goto page Previous  1, 2
PostPosted: Thu Dec 21, 2017 5:05 am     Reply with quote
Obviously a lot of other connections needed:
5v to all the Vdd connections on the PIC.
0v to all the Vss connections on the PIC.
Gnd to both sides of the module.
Two of the HV connections to pins C6 and C7 on the PIC.
MCLR pulled up on the PIC
Then the corresponding LV connection for C7 to the UART TXD pin on the module.
Then the LV connection for C6 to the UART RXD connection on the module.
Ideally add a current limiting resistor and LED to the LED line on the module if it doesn't already have one.
Then before anything else run the 'flash an LED' test on the PIC. What you have posted is _not_ correct for the PIC setup. You have the XT oscillator selected (4Mhz max) yet are saying you are running at 20MHz....
The oscillator will probably be failing and running off the internal RC.
PostPosted: Thu Dec 21, 2017 5:46 am     Reply with quote
this line...
is wrong !
Please check the adc section in the datasheet, table 17-1 for WHY it is wrong and what clocks are valid.
I have to assume some 'wizard' defaults this value ?? It appears on a LOT of posts..
also this...
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,PARITY=N,BITS=8)
you need to add 'ERRORS' to the (...options...), otherwise teh PIC UART will 'stall,'freeze', 'lockup', 'fail'.
Jay
srikrishna
PostPosted: Thu Dec 21, 2017 7:00 am     Reply with quote
#include <18f2550.h>
#device ADC=10
#FUSES WDT128
#FUSES INTXT
#FUSES NOPROTECT
#FUSES NOBROWNOUT
#FUSES NOPUT
#FUSES NOCPD
#FUSES STVREN
#FUSES NODEBUG
#FUSES NOLVP
#FUSES NOWRT
#FUSES NOWRTD
#FUSES IESO
#FUSES FCMEN
#FUSES PBADEN
#FUSES NOWRTC
#FUSES NOWRTB
#FUSES NOEBTR
#FUSES NOEBTRB
#FUSES NOCPB
#FUSES MCLR
#FUSES LPT1OSC
#FUSES NOXINST
#FUSES PLL1
#FUSES CPUDIV1
#FUSES NOUSBDIV
#FUSES NOVREGEN
#use delay(clock=20M)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,PARITY=N,BITS=8,errors)
int16 pot;
setup_adc_ports(AN0_ANALOG);
setup_adc(ADC_CLOCK_DIV_32);
set_adc_channel(0);
delay_us(10);
while (TRUE);
pot = read_adc();
delay_ms(20);
printf("%lu",pot);
Now its ok????
PostPosted: Thu Dec 21, 2017 7:04 am     Reply with quote
Still has an impossible CPU clock....
This is why we repeat again and again, that the _first_ thing you must do, is the basic 'flash an LED' test, and get this running at the correct rate. Until the CPU is setup to run at the right rate all clock based functions (which includes RS232) will not work right.
srikrishna
PostPosted: Thu Dec 21, 2017 7:29 am     Reply with quote
OK tell me which software you used to communicate between pc and bluetooth??
PostPosted: Thu Dec 21, 2017 7:38 am     Reply with quote
Something like this after the fuses.
#use delay(clock=4M) //4MHz xtal
#define LED PIN_B1 //whatever pin the LED and resistor are on
while (TRUE);
output_toggle(LED);
srikrishna
PostPosted: Thu Dec 21, 2017 8:09 am     Reply with quote
I have tested the blink led program
PostPosted: Thu Dec 21, 2017 8:15 am     Reply with quote
What speed is it meant to be giving?.
The whole point is that if you set it as Temtronic shows (500mSec on 500mSec off), the flash should be exactly 1/second. Your video looks like about 4 seconds, which would then mean the CPU is actually running at 1/4 the rate you think it is.
Since your oscillator setup is impossible for the chip, it will probably be falling back to the default RC oscillator.
Serial is not going to work until this is flashing at exactly the speed it is meant to be giving.....
srikrishna
PostPosted: Thu Dec 21, 2017 8:17 am     Reply with quote
Previously i have set the 100ms delay. Now i set it to 500ms.
PostPosted: Thu Dec 21, 2017 11:30 am     Reply with quote
It appears to be very, very slow...though that could be the internet.
Would have to see the fuses related to clocks. I suspect the main clock is NOT running and the failsafe clock may be running.
A 20MHz xtal would need 2, say 15-22pfd caps.
Jay
PostPosted: Thu Dec 21, 2017 12:34 pm     Reply with quote
As I have pointed out twice, he is selecting the wrong oscillator.
Hint HS is for a crystal over 4MHz.
srikrishna
PostPosted: Fri Dec 22, 2017 2:56 pm     Reply with quote
I have measured the level converter output my level converter output is (4.01-3.99)v. when i applied 5v to its high voltage site and 3.3v to its low voltage site.
The output of Rx pin of Bluetooth is (3.19-3.15)v
As Ttelmah previously told
PIC RXD needs the signal to go up to 4v to be seen as a logic '1'. The 3.3v HC05 can't do this.
I think i have to increase the level converter high voltage reference
i mean when i give 5 v it gives 4.1v So
if i give 6v it will give 4.5v or around 5v.Then the pic might regarded as logic '1'
thefloyd
Still need to fix your oscillator
PostPosted: Fri Dec 22, 2017 3:05 pm     Reply with quote
As others have already told you repeatedly, your oscillator configuration is way off. You're blinking an LED at either 500/500ms on/off or 100/100ms on/off but your animated picture shows your LED blinking at *way longer* intervals - something like 8 seconds. If you're asking for a 500ms blink and you're blinking at 8s you're way off. Even if you get your voltage levels sorted, your serial communications *will not* work with a bad oscillator configuration.
PostPosted: Fri Dec 22, 2017 5:55 pm     Reply with quote
As others have said, you need to go back ...
Get the 1Hz LED running. Delete ALL other code ! NO ADC, NO bluetooth, Nothing but
device header
fuses
main()
toggle led
forever
You NEED to do that BEFORE adding anything else. ONCE you get that running, then proceed.
Jay
Page 2 of 2
