Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
18F67J50 question
championx
18F67J50 question
PostPosted: Mon Dec 11, 2017 10:51 am     Reply with quote
Hi! I'm developing a board with a 18F67j50, the board works ok, but only connected to the pickit2.
If i disconnect the pickit2 and then power the board, it doesn't start the program...
It could be some fuse config?
compiler 5.045
fuses and config:
#include <18F67J50.h>
#device PASS_STRINGS = IN_RAM
#fuses INTRC_PLL
#fuses NOWDT
#fuses NOIESO
#fuses NOXINST
#fuses NOSTVREN
#fuses FCMEN
#fuses NOPROTECT
#fuses NODEBUG
#device ADC=16
#use delay(internal=48MHz)
#use rs232(baud=9600,parity=N,xmit= pin_C6,rcv= pin_C7,bits=8)
Any advice? thanks!
PostPosted: Mon Dec 11, 2017 11:37 am     Reply with quote
How are your writing the program?.
Not possibly using MPLAB?.
If so, beware that this will default to enabling the DEBUG, unless you tell it to compile for 'release'.
championx
PostPosted: Mon Dec 11, 2017 11:39 am     Reply with quote
Thanks for your answer, no, im writing it using pickit software, no debug function.
PostPosted: Mon Dec 11, 2017 12:17 pm     Reply with quote
What is connected to the MCLR line?. The programmer will hold this high, with this disconnected, if it is floating, the chip won't start.
championx
PostPosted: Mon Dec 11, 2017 4:48 pm     Reply with quote
It has a 4k7 resistor to 3.3v and a diode.
3.3v ---/\/\/\/\---|>|---- MCLR PIN.
PostPosted: Tue Dec 12, 2017 2:35 am     Reply with quote
OK. It all looks good.
Are you sure the PICKIT is setup to overwrite the fuses?.
You behaviour has all the marks that the chip still thinks it is in debug mode. The question is 'why'.
Look at the end of the .LST file to see the actual fuse setup.
Then read these back from the chip.
Do they match?.
championx
PostPosted: Tue Dec 12, 2017 8:13 pm     Reply with quote
Thanks Ttelmah, but i discovered the problem, it was the voltage regulator...
It seems that the Pickit helped with the current and was able to start running.
Changed the regulator and Voila. Seems like it was defective...
Thanks !
