Posted: Sat Dec 09, 2017 6:39 am |
You have to 'split up' your program and send data to a PC terminal program.
You need to be able to see
1) the raw data from TC device
2) the result of the sortout() function
3) the result of the toCalcTC() function
When you do this ,you'll be able to see the result of each operation you're asking the PIC to do, Right now there is no way to see if the TC device is actually returning the correct data or if one of the 'math' functions is really causing the problem. Often 'casting' or 'math' will cause problems.
If you can't send to PC, then instead of reading the TC device, use a known number as the data and see what happens. For test purposes I'd try 5 values that cover the range of the TC device.IE if the range was from 0 to 100, I'd use 0, 25,50,80,100. Now if the LED display shows the correct result for the values you use as being 'TC device data', then you know the 'math' functions are correct. Therefore the bad data must be the TC device data. If that's the case you could have 1) incorrect wiring, 2) wrong SPI mode( it's 0 according to earlier posts) 3 defective chip 4) bad sensor or something else.
While the 3 digit LED display is fine for the final product, for 'debug' purpose you really need to send the data to a PC, an LCD module or even 16 LEDs.
Also, I'd put the 'LED display code' inside a 'function', like you did the 'math' routines. Since it does work it will make the main() code simpler to look at. something like void dspLED_TC_data(int16 result). I like names that say what they do, easier for me. |
Posted: Sat Dec 09, 2017 7:14 am |
| Quote: |
it is there i forget to copy the line here is the code.
That is not confidence giving,
How a single line inside the code gets omitted is not easy to see.
Build a _small_ program that just accesses the device. Preferably just using serial to send the result to the PC. It should be something _complete_. As Temtronic says you need to do one thing at a time. |
Posted: Sat Dec 09, 2017 9:49 am |
Er.
According to the picture of the module, it has the pins as GND, VCC, CLX, CS, DATA.
You post:
16f72 max6675 module
14 3
16 5
17 4
vcc 2
gnd 1
Now pin 14 is C3, 16 is C5, and 17 is C6. Disagrees totally with the pins you are using in the setup. No wonder it doesn't work. |
Posted: Sat Dec 09, 2017 10:04 am |
Ttelmah, I get his connections as follows and it looks OK to me.
| Code: | 16f72 max6675 #use spi()
14 RC3 3 sck CLK=PIN_C3
16 RC5 5 so DI=PIN_C5
17 RC6 4 cs ENABLE=PIN_C6
vcc 2 vcc
gnd 1 gnd |
Posted: Sat Dec 09, 2017 1:34 pm |
| madhusuthanan wrote: | hi Ttelmah,
But that's not really your code, because it doesn't compile. If I copy and
paste your code into MPLAB and compile, it gives me these errors:
| Quote: | *** Error 97 "pcm_test.c" Line 10(5,112): Must have a #USE DELAY before this #USE
*** Error 12 "pcm_test.c" Line 39(18,23): Undefined identifier SPI_1
2 Errors, 0 Warnings.
Build Failed. |
To fix those errors, I have to move the #use delay() statement above
the #use spi() line. Also, I have to rename the Stream in #use spi()
to SPI_1. Then it compiles.
So you're not really testing the same code that you post. Or you're not
testing it at all. |
madhusuthanan
| max6675 |
Posted: Sat Jan 13, 2018 11:21 am |
| I find the solution for that issue not it is showing the correct value. I made manually get the value of the module with software spi communication. manually calculated from spi communication. thanks for guidance for finding the issue. |
