Error compilation when trying write an interrupt handler
ElectronPIC
PostPosted: Sun Dec 03, 2017 9:20 am     Reply with quote
Hi everyone!
I want to write my own interrupt dispatcher. To start I've just copied the dispatcher generated automatically by CCS:
#INT_GLOBAL
void InterruptDispatcher(void)
#ASM
MOVWF  04
MOVFF  STATUS,05
MOVFF  BSR,06
MOVLB  0
MOVFF  FSR0L,0C
MOVFF  FSR0H,07
MOVFF  FSR1L,08
MOVFF  FSR1H,09
MOVFF  FSR2L,0A
MOVFF  FSR2H,0B
MOVFF  PRODL,12
MOVFF  PRODH,13
MOVFF  PCLATH,14
MOVFF  TABLAT,15
MOVFF  TBLPTRL,16
MOVFF  TBLPTRH,17
MOVFF  00,0E
MOVFF  01,0F
MOVFF  02,10
MOVFF  03,11
BTFSS  PIE1.RCIE
GOTO   0060
BTFSC  PIR1.RCIF
GOTO   0394
BTFSS  PIE1.TXIE
GOTO   006C
BTFSC  PIR1.TXIF
GOTO   0412
BTFSS  PIE1.CCP1IE
GOTO   0078
BTFSC  PIR1.CCP1IF
GOTO   0476
MOVFF  0E,00
MOVFF  0F,01
MOVFF  10,02
MOVFF  11,03
MOVFF  0C,FSR0L
MOVFF  07,FSR0H
BSF    07.7
MOVFF  08,FSR1L
MOVFF  09,FSR1H
MOVFF  0A,FSR2L
MOVFF  0B,FSR2H
MOVFF  12,PRODL
MOVFF  13,PRODH
MOVFF  14,PCLATH
MOVFF  15,TABLAT
MOVFF  16,TBLPTRL
MOVFF  17,TBLPTRH
MOVF   04,W
MOVFF  06,BSR
MOVFF  05,STATUS
RETFIE 0
#ENDASM
But I get this error when compiling: "Invalid interrupt directive Can not mix GLOBAL with non-global"
I'm using: PIC18F2550, CCS 5.061.
Is it right what I'm trying to do? Am I missing something?
PostPosted: Sun Dec 03, 2017 9:43 am     Reply with quote
It means you can't have #int_global and #int_rda (for example) at the
same time. If you use #int_global, ALL interrupt handling must be done
by you in the #int_global routine.
Do a forum search for #int_global to find examples of how to do this.
Also look at the CCS example file ex_glint.c in your compiler examples
folder on your PC.
PostPosted: Sun Dec 03, 2017 10:23 am     Reply with quote
and (important to understand), the only reason to do this, is if you have a handler that must be handled really quickly. In this case you only save the registers that are used in this handler, and get in an out of this ASAP.
If you call multiple handlers, your global has to save every register used in all the handlers, which then means you end up duplicating the CCS handler and gain nothing.....
Your handler is potentially handling INT_RDA, INT_TBE, and INT_CCP.
If you want one of these handled quickly, leave CCS to handle the rest, and declare just the interrupt you want dealt with quickly as a high priority interrupt. If you declare is as 'FAST', then it'll be called like the INT_GLOBAL, but as a high priority interrupt (you need to have HIGH_INTS=TRUE as well). You will be responsible only for saving the registers it uses, and things will be as fast as possible. Smile
ElectronPIC
PostPosted: Sun Dec 03, 2017 2:56 pm     Reply with quote
folder on your PC.
PCM programmer, thanks for your reply.
That means that I should delete #int_rda and make sure that that isr is in the direction invoked by GOTO instruction, in the interrupt handler?
ElectronPIC
PostPosted: Sun Dec 03, 2017 3:03 pm     Reply with quote
Ttelmah, thanks for your reply.
What I wanted was to make sure that all registers modified by all isrs are being saved.
Is the compiler generated interrupt handler already doing this?
PostPosted: Sun Dec 03, 2017 3:17 pm     Reply with quote
Yes.
In fact the one complaint about it, is that if you do something very minor in your interrupts (so no array accesses, but just increment a simple counter for example), it still saves everything, including the index registers.
PostPosted: Sun Dec 03, 2017 8:44 pm     Reply with quote
Yes, delete your existing #int_rda function.
Ttelmah has posted sample code of how to do this in the following thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=44031
