Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
Problem with fuses
inge_simo
Problem with fuses
PostPosted: Tue Nov 28, 2017 4:37 am     Reply with quote
Hello to everybody,
I'm going crazy with #FUSES defined with pic16f88 and ccs/ide version 5.019.
This is the code:
file .h
#include <16F88.h>
#device ADC=10
#FUSES NOWDT
//#device ICD=TRUE
#use delay(clock=8000000)
file.c
#include <VR_PWM.h>
#INT_TIMER1
void  TIMER1_isr(void) {
clear_interrupt(int_TIMER1);
setup_oscillator(OSC_8MHZ|OSC_INTRC);
setup_wdt(0);
  // setup_adc_ports(sAN0);
  // setup_adc(ADC_CLOCK_DIV_2);
  // setup_timer_1(T1_INTERNAL|T1_DIV_BY_4);      //131 ms overflow
  // setup_timer_2(T2_DIV_BY_1,39,1);      //20,0 us overflow, 20,0 us interrupt
  // setup_ccp1(CCP_PWM);
  // set_pwm1_duty((int16)0);
  // enable_interrupts(INT_TIMER1);
  // enable_interrupts(GLOBAL);
  while(TRUE){
      //TODO: User Code
      output_High(PIN_A2);
      output_Low(PIN_A2);
When i compile the code i have:
Unknown keyword in #FUSES "NOWDT"
I tried to change multiple fuses but the result is the same!
Simone
PostPosted: Tue Nov 28, 2017 6:19 am     Reply with quote
I don't see why that error occurs. Perhaps remove all commented out code, the pwm header, etc. and recompile. Even IF the device header was bad, that error shouldn't happen.
this...
setup_wdt(0);
is incorrect as '0' is not a valid option. If you look at the pic 'device' header, it lists all the options for that PIC.
I'd start with the simple '1Hz LED program', get it working, then build upon that.
Jay
dyeatman
PostPosted: Tue Nov 28, 2017 6:21 am     Reply with quote
It compiles under 5.075 with no problems.
Google and Forum Search are some of your best tools!!!!
PostPosted: Tue Nov 28, 2017 6:32 am     Reply with quote
You have this line at the top of your program:
#include <VR_PWM.h>
You call your header file "file.h". But you don't have an #include line
for file.h. You have it for VR_PWM.h.
What is in VR_PWM.h ?
PostPosted: Tue Nov 28, 2017 9:41 am     Reply with quote
maybe (V)ariable (R)esistor to (P)ulse(W)idth(M)odulation .
it is confusing though
For small 'beginner' or 'test' programs, it's always best to have the ENTIRE program in one file. Everything from PIC device.h to end of main(). Once it does work THEN you can breakdown into smaller 'include' files.
I have a separate 'fuses' file ( 46k22_basic_fuses.fuz ) for PIC18F46K22 projects. It is a complete(yes, every fuse) set that works as tested with a 1Hz LED program. I'm a lousy typist(bad finger) so doing it once really helps, especially since there are more fuses than PIC instructions !
