refa
Posted: Mon Jan 12, 2004 3:59 pm |
Yeah, I should ask them or solve the problem myself. Thank you a lot for your time PCM Programmer  |
Posted: Mon Jan 12, 2004 4:00 pm |
You obviously note the comment in the data sheet, that the "data must be preceeded by a 'preamble' 1 to 3mSec long to stabilise the AGC".
For radio comms, you will need to add a 'header' to the packet, with an identifier at the end, that the receive processor looks for.
So you send something like:
for (n=0;n<3;n++) putc(0xAA);
putc(0);
then the actual data.
At the receive, your code ignores characters, till the '0' if seen, and then receives the following data as the 'real' packet.
A technique like this is necessary with communications of this sort.
refa
Posted: Mon Jan 12, 2004 4:07 pm |
Ttelmah thank you a lot for sharing this. It 'll save me a lot of time ... Thank you pal |
