Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
calculating distance from gps coordinates
championx
PostPosted: Thu Nov 16, 2017 6:13 pm     Reply with quote
Hi! do anyone have calculated distance using GPS coordinates?
It uses some complex math functions, do you have any advice to do this?
thanks
PostPosted: Thu Nov 16, 2017 7:06 pm     Reply with quote
use integers
do NOT use floating point
search the forum
newguy
PostPosted: Thu Nov 16, 2017 7:12 pm     Reply with quote
https://en.wikipedia.org/wiki/Haversine_formula
Definitely use integers. If you're attempting this in a PIC, your accuracy (gut feeling only) isn't going to be on the order of meters or better. What sort of accuracy do you require?
PostPosted: Fri Nov 17, 2017 2:35 am     Reply with quote
<http://www.ccsinfo.com/forum/viewtopic.php?t=27879&highlight=haversine>
<http://www.ccsinfo.com/forum/viewtopic.php?t=27947&highlight=cordic>
<http://www.ccsinfo.com/forum/viewtopic.php?t=47980&highlight=haversine>
The cordic code _with some added care to handle the quadrants and special cases_, can give great results.
