Problem pin2 pic12f519
tysie
PostPosted: Tue Nov 14, 2017 10:13 am     Reply with quote
I want to toggle some pins.
I did the following:
output_toggle(LIFELED);
output_toggle(SERVO);
output_toggle(LIGHTOUTPUT);
And my header:
#use delay(internal=8MHz)
#use FIXED_IO( B_outputs=PIN_B5,PIN_B4,PIN_B2 )
#define PULSE   PIN_B0
#define BUTTON   PIN_B1
#define SERVO   PIN_B2
#define LIFELED   PIN_B4
#define LIGHTOUTPUT   PIN_B5
I see pins 4 and 5 toggling, but pin 2 doesn't do anything. Does someone know why?
alan
PostPosted: Tue Nov 14, 2017 11:19 am     Reply with quote
A quick look at the datasheet says that if bit T0CS are set (default value) then it overrides the TRIS registers anf the pin are an input. Try clearing the T0CS bit in the OPTIONS register.
Regards
PostPosted: Tue Nov 14, 2017 11:43 am     Reply with quote
setup_timer_0(T0_INTERNAL);
Does this for you.
tysie
solved
PostPosted: Tue Nov 14, 2017 12:15 pm     Reply with quote
I solved it with the options register.
