ADC with PIC18f4580
thanhandaithanh
ADC with PIC18f4580
PostPosted: Mon Oct 30, 2017 9:27 pm     Reply with quote
I have a problem with read_adc(). I cannot read adc value from AN0 of this Pic
This is my code:
#include <18f458.h>
#device adc=8
int8 data=0;
  set_tris_a(0xff);
  set_tris_b(0x00);
  setup_adc_ports(AN0);
  set_adc_channel(0);
   while(1){
          data = read_adc();
          OUTPUT_B(data);
Last edited by thanhandaithanh on Tue Oct 31, 2017 8:14 am; edited 2 times in total
srikrishna
Re: ADC with PIC18f4580
PostPosted: Mon Oct 30, 2017 10:43 pm     Reply with quote
modify according to your settings
PostPosted: Mon Oct 30, 2017 10:46 pm     Reply with quote
What PIC do you really have ? Your title says 18F4580, but your program
says 18F458. Those are different PICs.
What is your CCS compiler version ?
thanhandaithanh
PostPosted: Mon Oct 30, 2017 10:47 pm     Reply with quote
I don't know what is problem in my code ?
thanhandaithanh
PostPosted: Mon Oct 30, 2017 10:48 pm     Reply with quote
I tried both of them, they don't work
PostPosted: Tue Oct 31, 2017 5:25 am     Reply with quote
Comments...
The speed used in setup_adc() is wrong. Ther's a table (21-1 ?) in the ADC section of the PIC datasheet that shows what's valid for various PIC clock rates.
The clock option might not compute ? 20,000000 I'd use 20,000,000 or 20MHz and recompile.
There's an extra, in the use RS232(...options...). BTW you need to add ERRORS to that.
The variable value only needs to be unsigned interger 16.
Hopefully you've got VDD and GND connected, though NOT shown in the Proteus schematic, they are required.
That is a 5 volt PIC, most BT modules are 3 volts, so be careful !!
Does a 1Hz LED program work ?
PostPosted: Tue Oct 31, 2017 7:32 am     Reply with quote
Unfortunately, some comments are being addressed to code that was a reply to the original post.
Lets just look at the original:
First comment. Have you verified that the PIC is actually running?.
Simple 'flash an LED' test. :
#include <18f458.h>
#device adc=8
#use delay(crystal=20MHz)
   SETUP_PSP(PSP_DISABLED);
   SETUP_COMPARATOR(NC_NC_NC_NC);
   SETUP_CCP1(CCP_OFF);
   SETUP_CCP2(CCP_OFF);
   //several of these peripherals use pins on the ports being used
   //ensure these are off.
        output_toggle(PIN_B0);
Does pin B0 toggle every second?.
If not, then the chip is not running. MCLR pulled up?. Crystal not working?. Power connections correct?.
If it does, then move on to the ADC.
As already pointed out the ADC clock is not recommended at this CPU clock rate.
#include <18f458.h>
#device adc=8
int8 data=0;
   setup_adc(ADC_CLOCK_DIV_32);
   set_adc_channel(0);
          data = read_adc();
          OUTPUT_B(data);
thanhandaithanh
PostPosted: Tue Oct 31, 2017 7:52 am     Reply with quote
#include <18f458.h>
#device adc=8
#include <18f458.h>
#device adc=8
int8 data=0;
   set_adc_channel(0);
          data = read_adc();
          OUTPUT_B(data);
Firstly, I'm sure that my Chip is good. I tried your first ex, and pin B0 toggles every second. But I still cannot read adc and export it to portB.
PostPosted: Tue Oct 31, 2017 7:58 am     Reply with quote
Even with the second version as posted?.
What is on port B?.
PostPosted: Tue Oct 31, 2017 8:06 am     Reply with quote
I'm assuming you have 8 LEDs and Rs connected to PortB.
Have you confirmed the AN0 pin of the PIC is connected to wiper of pot and that it does get 0v, 5v, 2.5v, etc.?
If so what do you see on the LEDs ?
I would add a 'test LED and 470r' on an unused I/O pin to toggle every time in main(). That way you KNOW the program is running..
the concept....
main()....
loop
toggle led
read adc
display adc
delay
loop again
end of main()...
Jay
thanhandaithanh
PostPosted: Tue Oct 31, 2017 8:08 am     Reply with quote
What is on port B?.
Yes, even with your second version
Nothing on port B
[/img]
PostPosted: Tue Oct 31, 2017 8:10 am     Reply with quote
You are sure you are connecting the voltage to the right pin?.
I have just tested this with a 4580 at 8MHz, and it merrily outputs the value on the port.
thanhandaithanh
PostPosted: Tue Oct 31, 2017 8:15 am     Reply with quote
Can you upload the image of ISIS file ?
PostPosted: Tue Oct 31, 2017 8:16 am     Reply with quote
I can't decide WHICH PIC he's using
18F458
18F4580
18F2550
sigh....
PostPosted: Tue Oct 31, 2017 8:57 am     Reply with quote
No Isis file. Just a real PIC.
Read the sticky at the top of the forum about Proteus/Isis.
If you are basing your 'it does not work' on these, then you are misleading yourself.
Proteus is a great PCB package, but if you try to develop code using Isis, you will end up doing the job twice. Once to get it working in Isis, and then a second time when you go to the real PIC....
