C# serialport usage
omer64
C# serialport usage
PostPosted: Thu Oct 26, 2017 3:37 pm     Reply with quote
Firstly, i'm sorry for my bad english!
When i use serialport1.writeline, pic16f877a is freezing.
But, when i use serialport1.write, sometimes pic16f877a freeze, sometimes pic receive data.
How can i solve this problem?
Have nice a day...
#include <rxtx.h>
#define LCD_ENABLE_PIN PIN_B0
#define LCD_RS_PIN PIN_B1
#define LCD_RW_PIN PIN_B2
#define LCD_DATA4 PIN_B4
#define LCD_DATA5 PIN_B5
#define LCD_DATA6 PIN_B6
#define LCD_DATA7 PIN_B7
#include <lcd.c>
#include <stdlib.h>
#include <string.h>
#include <stdio.h>
#include <input.c>
unsigned long int bilgi=0;
float volt1=0,volt2=0,volt3=0,volt4=0;
unsigned int zaman=0;
char gelen[50]="\0";
char veri1[20]="\0",veri2[20]="\0";
char bol[]="#";
#INT_RTCC
void  RTCC_isr(void)
   disable_interrupts(INT_RDA);
   zaman++;
   if(zaman>100)
      zaman=0;
      output_toggle(led2);
      set_adc_channel(0);
      delay_us(20);
      bilgi=read_adc();
      volt1=(0.0048828125*bilgi)*1000;
      set_adc_channel(1);
      delay_us(20);
      bilgi=read_adc();
      volt2=(0.0048828125*bilgi)*1000;
      set_adc_channel(2);
      delay_us(20);
      bilgi=read_adc();
      volt3=(0.0048828125*bilgi)*1000;
      set_adc_channel(3);
      delay_us(20);
      bilgi=read_adc();
      volt4=(0.0048828125*bilgi)*1000;
      fprintf(mavidis,"%07.2f#%07.2f#%07.2f#%07.2f\n\r",volt1,volt2,volt3,volt4);
      printf(lcd_putc,"\f%s",veri1);
      printf(lcd_putc,"\n%s",veri2);
#INT_RDA
void  RDA_isr(void)
   disable_interrupts(INT_RTCC);
   fgets(gelen,mavidis);
   output_toggle(led1);
   strcpy(veri1,strtok(gelen,bol));
   strcpy(veri2,strtok(0,bol));
   setup_adc_ports(ALL_ANALOG);
   setup_adc(ADC_CLOCK_DIV_32);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_4|RTCC_8_BIT);      //1,0 ms overflow
   enable_interrupts(INT_RTCC);
   enable_interrupts(INT_RDA);
   output_low(led1);
   output_low(led2);
using System;
using System.Collections.Generic;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
using System.IO.Ports;
using System.Threading;
namespace thread_data_received_deneme
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
        private void Form1_Load(object sender, EventArgs e)
            CheckForIllegalCrossThreadCalls = false;
            serialPort1.DataReceived += new SerialDataReceivedEventHandler(serialPort1_DataReceived);
            string[] portlar = SerialPort.GetPortNames();
            foreach (string ports in portlar)
                comboBox1.Items.Add(ports);
        private void v_Click(object sender, EventArgs e)
            if (serialPort1.IsOpen == false)
                try
                    serialPort1.Open();
                    serialPort1.DiscardInBuffer();
                    serialPort1.DiscardOutBuffer();
                    label1.Text = "Bağlandı";
                catch (Exception hata)
                    MessageBox.Show(hata.Message);
        private void button1_Click(object sender, EventArgs e)
            if (serialPort1.IsOpen == true)
                try
                    serialPort1.Close();
                    label1.Text = "Bağlantı Kesildi";
        private void button2_Click(object sender, EventArgs e)
            try
                serialPort1.Write(textBox1.Text.ToString()+ "\0"+(char)13);
            catch (Exception)
        string gelen;
        string[] veri = new string[5];
        private void serialPort1_DataReceived(object sender, SerialDataReceivedEventArgs e)
            try
                gelen = serialPort1.ReadLine();
                veri = gelen.Split('#');
                textBox2.Text = veri[0].ToString();
                textBox3.Text = veri[1].ToString();
                textBox4.Text = veri[2].ToString();
                textBox5.Text = veri[3].ToString();
            catch (Exception)
        private void button3_Click(object sender, EventArgs e)
            try
                serialPort1.Write("\0"+(char)13);
                textBox1.Clear();
            catch (Exception)
        private void comboBox1_SelectedIndexChanged(object sender, EventArgs e)
            serialPort1.PortName = comboBox1.Text.ToString();
        private void comboBox2_SelectedIndexChanged(object sender, EventArgs e)
            serialPort1.BaudRate = Convert.ToInt32(comboBox2.Text);
PostPosted: Thu Oct 26, 2017 11:06 pm     Reply with quote
Start by reading the forum.
There are so many things fundamentally 'wrong' that it is difficult to know where to start.
Floating point maths in an interrupt.
Delays in an interrupt.
INT_RDA, means _one_ character is waiting. Not a string.
Disabling interrupts. Why?.
The whole approach is flawed. You have the code that should be in your main, all written inside interrupts.
Look at ex_sisr, for an example of 'how' to do a serial interrupt.
Then all your RTCC interrupt needs do is update a clock.
Repeat the mantra fifty times. All an interrupt handler should do is handle the event that triggered it, and exit ASAP.
Now you don't show your serial setup, but I'd guess it is missing 'ERRORS'. Because of the code faults, if the data arrives while the processor is inside the RTCC interrupt, the UART overflows, and is then hung.
