I'm hoping someone can help me figure out how to get the CCS IDE talking to a PICkit 3 so that I can click Program > ICD for burning. I have installed the latest CCS IDE and CCSLOAD as well as the IDE plugin, setup_mctools.exe. There are no issues using my PICkit 3 within MPLAB X so it is not a connection problem or USB driver problem. I've browsed the CCS forum as well. I'm running Windows 8. So, could someone who has gotten this to work take me through the process step-by-step? Thanks.
[5/4/2015 update]
I got it to work. The solution was to install Java SE version 7 (update 80). I was running Java SE version 8 (update 45), which apparently has problems working nicely with MPLAB X and the PICkit.
vasiliok
Joined: 17 May 2011 Posts: 7 Location: Kaunas, Lithuania
Posted: Thu Oct 19, 2017 6:13 am
Hello!
It was hard :-) Spent some time to figure out how to configure.
You need to go to Options > IDE > Tools and put new line there. Check the box and add:
