pointer to function
pic user
pointer to function
PostPosted: Sat Jan 10, 2004 6:50 am     Reply with quote
what is the proper syntax for a pointer to a function
I have
long * func1;
func1=disp_character;
disp_character is defined
I get a compiler error 'improper use of a function identifier'
am using PCM version 3.169
thanks
Re: pointer to function
PostPosted: Sat Jan 10, 2004 6:55 am     Reply with quote
I have
long * func1;
thanks
The declaration here is saying that 'func1', is a pointer to a function returning a long. The defintion depends on what type the function returns.
pic_user
PostPosted: Sat Jan 10, 2004 11:13 am     Reply with quote
still don't work.
a little more details
float c2f(float celsius);
float c2f(float clecius)
float f;
f=(celsius*1.8)+32;
return f;
main()
float c;
float * func1;
func1=c2f;
c=(func1) (32);
this is a sample of my code. Not sure whats wrong with it but it won't compile.
error : improper use of function identifier
any help would be greatly appreciated
PostPosted: Sat Jan 10, 2004 4:27 pm     Reply with quote
pic_user wrote:
still don't work.
//spelling error here
float f;
f=(celsius*1.8)+32;
return f;
main()
float c;
float * func1;
//declare as:
// float (*func1)(float);
//This says that func1, is a pointer to a function that requires a float
//argument, and returns a float. All parts of this are required.
func1=c2f;
c=(func1) (32);
//Here you need to use the function, not the pointer, so the declaration
//is:
// c=(*func1)(32);
This is standard C pointer handling, not a compiler problem. I suggest you read up, on how to use pointers to functions. :-)
pic_user
PostPosted: Sat Jan 10, 2004 4:43 pm     Reply with quote
thanks. fixed it
