Simple version control
jujoab
PostPosted: Sat Sep 30, 2017 11:37 am     Reply with quote
I am looking for a simple way to keep different versions of a project on the disk, but seems to be no information on the subject.
Any suggestion please ?
jujoab
PostPosted: Sat Sep 30, 2017 12:02 pm     Reply with quote
Just make different versions.
Make sub directory's with names like version1, 2 etc.. Put all the files into each, except the project file. Make sure the #include statements for your include files use "" rather than <>. This means 'look in the local directory first'. Then open the main code file with the compiler, and compile. It'll generate a project file, referring to the local copies, not others, and put all the result files in the directory. Include a note in your source file saying what compiler version this uses.
Do the same with the compiler, Instead of just having one, install each time into a separate directory and turn off automatic updates.
You can then use your code versionxx, with the right compiler version it was built with before.
PostPosted: Sat Sep 30, 2017 12:27 pm     Reply with quote
Instead of always editting the same 'project' file, over and over, I copy the source to a new file called 'projectxv2'. THEN I edit that source, compile and test. Next time I copy 'projectxv2' to 'projectxv3', edit that source, compile and test. Yup, I've got 40, 50, 80 versions of some projects on the PC.
.. BUT I can ALWAYS go back 1, 2 or 102 versions to something that did work ! All to often you can make 3-4 changes and you'll spend hours wondering WHAT did I do, it ran 5 minutes ago......
Once the project is complete, just delete all but the last 3 versions, though with hard drives being huge you'll probably never have to make space.
Jay
jujoab
PostPosted: Sat Sep 30, 2017 12:57 pm     Reply with quote
It works like a charm.
Thanks a lot.
Have a nice weekend.
jujoab
Jerson
PostPosted: Sat Sep 30, 2017 10:34 pm     Reply with quote
For those who wish to have a nice standalone VCS, take a look at fossil-scm.org Single binary, powerful features. Command line operation mainly, but can be viewed via browser. Handles tickets, wiki all in one. Highly recommended. I am just a user.
bkamen
PostPosted: Sun Oct 01, 2017 11:57 pm     Reply with quote
If you have Windows and load Cygqin, you can probably install RCS...
If you have a linux system as your NAS, the possibilities are endless.
Just google it. To many choices to list.
gjs_rsdi
PostPosted: Sun Oct 08, 2017 10:26 pm     Reply with quote
I am with you on that Jay Smile
It was the only way in Assembler, I think is also the only way in C.
Best wishes
Joe
