Indira Learner
| Propblem comparing two strings using rs232 |
Posted: Sat Sep 09, 2017 3:33 am |
Hello, there is a code i wrote to compare a string received using a communication port. The code worked well a few times, and then it stopped working. I do not know what the error is. It actually compiles without an error, but when i run it, the output is always wrong even if both words match.
| Code: | #include <main.h>
#include <stdio.h>
#include <string.h>
#fuses HS
#use rs232(uart1, baud=9600)
char password[] = {"123abc"};
char string_pass[];
char input_str[];
#define BUFFER_SIZE 32
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#INT_EXT
void EXT_isr(void)
reset_cpu();
#INT_RDA
void RDA_isr(void)
int t;
buffer[next_in] = getc();
t = next_in;
next_in =(next_in + 1) % BUFFER_SIZE;
if(next_in == next_out)
next_in = t;
#define bkbhit (next_in!=next_out)
BYTE bgetc()
BYTE c;
while( ! bkbhit);
c = buffer[next_out];
next_out =(next_out + 1) % BUFFER_SIZE;
return(c);
void my_get_string(char* s)
unsigned int8 len;
char c;
len = 0;
do
c = bgetc();// Call bgetc()
if((c >= ' ')&&(c <= '~'))
s[len++] = c;
putc(c);
while(c != 13);
s[len] = 0;
void toggle_function()
int i;
i=0;
while(i<20){
output_high(led1);
output_low(led1);
i++;
void compare_function(char *string)
if(strcmp(string,password) == 0)
printf("\n Correct Keyword ! \n ");
toggle_function();
printf("\n ERROR\n");
clear_interrupt(INT_EXT);
enable_interrupts(INT_EXT);
clear_interrupt(INT_RDA);
enable_interrupts(INT_RDA);
printf("Type string here: ");
my_get_string(input_str);
strcpy(string_pass,input_str);
compare_function(string_pass);
Posted: Sat Sep 09, 2017 9:55 am |
| Quote: | char password[] = {"123abc"};
char string_pass[];
char input_str[];
Give these two arrays a size. Without the size, you don't have arrays.
You just have a pointers, and they will overwrite other RAM values
if you write to the "array".
Give each array a useful size, big enough so that it will hold the entire
expected string, and maybe some more bytes as a precaution.
Make sure you make the arrays big enough to have the 0x00 byte
that marks the end of every string. |
