huynhhai
Driver control LCD TFT 320QVT ili9341 |
Posted: Wed Apr 06, 2016 8:09 pm |
I really to say lucky,
I write code driver for LCD TFT 320 QVT 9341 already, anyone need to code, please use code below, my Pic is using
tft320qvt_9341.h
#ifndef __TFT320QVT_9341_H
#define __TFT320QVT_9341_H
#define LCD_W 400
#define LCD_H 240
//#define LCD_DataPortH PORT_B
//#define LCD_DataPortL PORT_C
#define LCD_RS PIN_A0 //
#define LCD_WR PIN_A1 //
#define LCD_RD PIN_A2 //
#define LCD_CS PIN_A3 //
#define LCD_REST PIN_A4 //
extern int16 BACK_COLOR, POINT_COLOR;
void tft320qvt_9341_init(void);
void LCD_Clear(int16 Color);
void Address_set(unsigned int16 x1,unsigned int16 y1,unsigned int16 x2,unsigned int16 y2);
void LCD_WR_DATA8(char VH,char VL);
void LCD_WR_DATA(int16 da);
void LCD_WR_REG(int16 da);
void LCD_DrawPoint(int16 x,int16 y);
void LCD_DrawPoint_big(int16 x,int16 y);
int16 LCD_ReadPoint(int16 x,int16 y);
void Draw_Circle(int16 x0,int16 y0,int8 r);
void LCD_DrawLine(int16 x1, int16 y1, int16 x2, int16 y2);
void LCD_DrawRectangle(int16 x1, int16 y1, int16 x2, int16 y2);
void LCD_Fill(int16 xsta,int16 ysta,int16 xend,int16 yend,int16 color);
void LCD_ShowChar(int16 x,int16 y,int8 num,int8 mode);
void LCD_ShowNum(int16 x,int16 y,int32 num,int8 len);
void LCD_Show2Num(int16 x,int16 y,int16 num,int8 len);
void LCD_ShowString(int16 x,int16 y,int8 *p);
#define WHITE 0xFFFF
#define BLACK 0x0000
#define BLUE 0x001F
#define BRED 0XF81F
#define GRED 0XFFE0
#define GBLUE 0X07FF
#define RED 0xF800
#define MAGENTA 0xF81F
#define GREEN 0x07E0
#define CYAN 0x7FFF
#define YELLOW 0xFFE0
#define BROWN 0XBC40
#define BRRED 0XFC07
#define GRAY 0X8430
#define DARKBLUE 0X01CF
#define LIGHTBLUE 0X7D7C
#define GRAYBLUE 0X5458
#define LIGHTGREEN 0X841F
#define LGRAY 0XC618
#define LGRAYBLUE 0XA651
#define LBBLUE 0X2B12
#endif |
tft320qvt_9341.c
#include <tft320qvt_9341.h>
RS-P3^5; WR-P3^6; RD-P3^7; CS-P1^0; REST-P1^2;
DB0-DB7 P0^0-P0^7; DB8-DB15 P2^0-P2^7;
T_CLK-P1^7; T_CS-P1^4; T_DIN-P3^0; T_OUT-P3^1; T_IRQ-P3^4;
void LCD_Writ_Bus(char VH,char VL)
output_b(VH);
//LCD_DataPortH=VH;
output_c(VL);
//LCD_DataPortL=VL;
output_low(LCD_WR);
output_high(LCD_WR);
output_high(LCD_RS);
LCD_Writ_Bus(VH,VL);
LCD_Writ_Bus(da>>8,da);
output_low(LCD_RS);
void LCD_WR_REG_DATA(int16 reg,int16 da)
LCD_WR_REG(reg);
LCD_WR_DATA(da);
LCD_WR_REG(0x2A);
LCD_WR_DATA(x1>>8);
LCD_WR_DATA(x1);
LCD_WR_DATA(x2>>8);
LCD_WR_DATA(x2);
LCD_WR_REG(0x2B);
LCD_WR_DATA(y1>>8);
LCD_WR_DATA(y1);
LCD_WR_DATA(y2>>8);
LCD_WR_DATA(y2);
LCD_WR_REG(0x2c);
void tft320qvt_9341_Init(void)
output_high(LCD_CS);
if(input(LCD_CS)==0)
LCD_WR_REG_DATA(0,0);
LCD_ShowNum(0,0,0,0);
LCD_Show2Num(0,0,0,0);
LCD_DrawPoint_big(0,0);
LCD_DrawRectangle(0,0,0,0);
Draw_Circle(0,0,0);
output_high(LCD_RD);
output_low(LCD_REST);
delay_ms(20);
output_high(LCD_REST);
delay_ms(20);
output_low(LCD_CS);
//************* Start Initial Sequence **********//
LCD_WR_REG(0xcf);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0xc1);
LCD_WR_DATA(0x30);
LCD_WR_REG(0xed);
LCD_WR_DATA(0x64);
LCD_WR_DATA(0x03);
LCD_WR_DATA(0x12);
LCD_WR_DATA(0x81);
LCD_WR_REG(0xcb);
LCD_WR_DATA(0x39);
LCD_WR_DATA(0x2c);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x34);
LCD_WR_DATA(0x02);
LCD_WR_REG(0xea);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x00);
LCD_WR_REG(0xe8);
LCD_WR_DATA(0x85);
LCD_WR_DATA(0x10);
LCD_WR_DATA(0x79);
LCD_WR_REG(0xC0); //Power control
LCD_WR_DATA(0x23); //VRH[5:0]
LCD_WR_REG(0xC1); //Power control
LCD_WR_DATA(0x11); //SAP[2:0];BT[3:0]
LCD_WR_REG(0xC2);
LCD_WR_DATA(0x11);
LCD_WR_REG(0xC5); //VCM control
LCD_WR_DATA(0x3d);
LCD_WR_DATA(0x30);
LCD_WR_REG(0xc7);
LCD_WR_DATA(0xaa);
LCD_WR_REG(0x3A);
LCD_WR_DATA(0x55);
LCD_WR_REG(0x36); // Memory Access Control
LCD_WR_DATA(0x08);
LCD_WR_REG(0xB1); // Frame Rate Control
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x11);
LCD_WR_REG(0xB6); // Display Function Control
LCD_WR_DATA(0x0a);
LCD_WR_DATA(0xa2);
LCD_WR_REG(0xF2); // 3Gamma Function Disable
LCD_WR_DATA(0x00);
LCD_WR_REG(0xF7);
LCD_WR_DATA(0x20);
LCD_WR_REG(0xF1);
LCD_WR_DATA(0x01);
LCD_WR_DATA(0x30);
LCD_WR_REG(0x26); //Gamma curve selected
LCD_WR_DATA(0x01);
LCD_WR_REG(0xE0); //Set Gamma
LCD_WR_DATA(0x0f);
LCD_WR_DATA(0x3f);
LCD_WR_DATA(0x2f);
LCD_WR_DATA(0x0c);
LCD_WR_DATA(0x10);
LCD_WR_DATA(0x0a);
LCD_WR_DATA(0x53);
LCD_WR_DATA(0xd5);
LCD_WR_DATA(0x40);
LCD_WR_DATA(0x0a);
LCD_WR_DATA(0x13);
LCD_WR_DATA(0x03);
LCD_WR_DATA(0x08);
LCD_WR_DATA(0x03);
LCD_WR_DATA(0x00);
LCD_WR_REG(0xE1); //Set Gamma
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x00);
LCD_WR_DATA(0x10);
LCD_WR_DATA(0x03);
LCD_WR_DATA(0x0f);
LCD_WR_DATA(0x05);
LCD_WR_DATA(0x2c);
LCD_WR_DATA(0xa2);
LCD_WR_DATA(0x3f);
LCD_WR_DATA(0x05);
LCD_WR_DATA(0x0e);
LCD_WR_DATA(0x0c);
LCD_WR_DATA(0x37);
LCD_WR_DATA(0x3c);
LCD_WR_DATA(0x0F);
LCD_WR_REG(0x11); //Exit Sleep
delay_ms(80);
LCD_WR_REG(0x29); //display on
int8 VH,VL;
int16 i,j;
VH=Color>>8;
VL=Color;
Address_set(0,0,LCD_W-1,LCD_H-1);
for(i=0;i<LCD_W;i++)
for (j=0;j<LCD_H;j++)
LCD_WR_DATA8(VH,VL);
void showhanzi(unsigned int16 x,unsigned int16 y,unsigned char index)
unsigned char i,j;
unsigned char *temp=hanzi;
Address_set(x,y,x+31,y+31);
temp+=index*128;
for(j=0;j<128;j++)
for(i=0;i<8;i++)
if((*temp&(1<<i))!=0)
LCD_WR_DATA(POINT_COLOR);
LCD_WR_DATA(BACK_COLOR);
temp++;
//POINT_COLOR:
Address_set(x,y,x,y);
//POINT_COLOR:
LCD_Fill(x-1,y-1,x+1,y+1,POINT_COLOR);
// (xend-xsta)*(yend-ysta)
int16 i,j;
Address_set(xsta,ysta,xend,yend);
for(i=ysta;i<=yend;i++)
for(j=xsta;j<=xend;j++)LCD_WR_DATA(color);
//x1,y1
//x2,y2
int16 t;
int16 xerr=0,yerr=0,delta_x,delta_y,distance;
int16 incx,incy,uRow,uCol;
delta_x=x2-x1;
delta_y=y2-y1;
uRow=x1;
uCol=y1;
if(delta_x>0)incx=1;
else if(delta_x==0)incx=0;
else {incx=-1;delta_x=-delta_x;}
if(delta_y>0)incy=1;
else if(delta_y==0)incy=0;
else{incy=-1;delta_y=-delta_y;}
if( delta_x>delta_y)distance=delta_x;
else distance=delta_y;
for(t=0;t<=distance+1;t++ )
LCD_DrawPoint(uRow,uCol);
xerr+=delta_x ;
yerr+=delta_y ;
if(xerr>distance)
xerr-=distance;
uRow+=incx;
if(yerr>distance)
yerr-=distance;
uCol+=incy;
LCD_DrawLine(x1,y1,x2,y1);
LCD_DrawLine(x1,y1,x1,y2);
LCD_DrawLine(x1,y2,x2,y2);
LCD_DrawLine(x2,y1,x2,y2);
int16 a,b;
signed int16 di;
a=0;b=r;
di=3-(r<<1);
while(a<=b)
LCD_DrawPoint(x0-b,y0-a); //3
LCD_DrawPoint(x0+b,y0-a); //0
LCD_DrawPoint(x0-a,y0+b); //1
LCD_DrawPoint(x0-b,y0-a); //7
LCD_DrawPoint(x0-a,y0-b); //2
LCD_DrawPoint(x0+b,y0+a); //4
LCD_DrawPoint(x0+a,y0-b); //5
LCD_DrawPoint(x0+a,y0+b); //6
LCD_DrawPoint(x0-b,y0+a);
a++;
if(di<0)di +=4*a+6;
di+=10+4*(a-b);
b--;
int8 temp;
int8 pos,t;
int16 x0=x;
int16 colortemp=POINT_COLOR;
if(x>LCD_W-16||y>LCD_H-16)return;
num=num-' ';
Address_set(x,y,x+8-1,y+16-1);
if(!mode)
for(pos=0;pos<16;pos++)
temp=asc2_1608[(int16)num*16+pos];
for(t=0;t<8;t++)
if(temp&0x01)POINT_COLOR=colortemp;
else POINT_COLOR=BACK_COLOR;
temp>>=1;
x++;
x=x0;
y++;
}else
for(t=0;t<8;t++)
if(temp&0x01)LCD_DrawPoint(x+t,y+pos);
temp>>=1;
int32 mypow(int8 m,int8 n)
int32 result=1;
while(n--)result*=m;
return result;
//num:(0~4294967295);
int8 t,temp;
int8 enshow=0;
num=(int16)num;
for(t=0;t<len;t++)
temp=(num/mypow(10,len-t-1))%10;
if(enshow==0&&t<(len-1))
if(temp==0)
LCD_ShowChar(x+8*t,y,' ',0);
continue;
}else enshow=1;
LCD_ShowChar(x+8*t,y,temp+48,0);
//num: (0~99);
int8 t,temp;
for(t=0;t<len;t++)
LCD_ShowChar(x+8*t,y,temp+'0',0);
while(*p!='\0')
if(x>LCD_W-16){x=0;y+=16;}
if(y>LCD_H-16){y=x=0;LCD_Clear(RED);}
LCD_ShowChar(x,y,*p,0);
x+=8;
p++;
cvargcal
Re: Driver control LCD TFT 320QVT ili9341 |
Posted: Tue Sep 06, 2016 8:13 am |
huynhhai wrote: | I really to say lucky,
}[/code] |
Hi, Can you share someone example, please?
Thanks |
huynhhai
Posted: Sat Sep 09, 2017 9:43 am |
Hi everyone,
i used PIC18F4620, hardware as config in software
main.h file
#include <18F4620.h>
//STATUS = FD8H
#device PASS_STRINGS=IN_RAM
#device ADC=10
#use delay(clock=32MHz,crystal=8MHz)
#bit carry_Flag = 0xFD8.0
/*==> trong file main.c (khai bao phim nhan)
#define key1 PIN_E0 //khai bao lai phim
#define key2 PIN_E1 //khai bao lai phim
#define key3 PIN_E2 //khai bao lai phim
/*==> trong file touch7843.h (khai bao spi cho cam ung)
#define DCLK PIN_D0
#define CS PIN_D1
#define DIN PIN_D2
#define DOUT PIN_D3
#define Penirq PIN_D4
/*==> trong file tft320qvt_9341.h (khai bao giao tiep TFTLCD)
#define LCD_DataPortH PORT_B //khai bao lai port
#define LCD_DataPortL P0RT_C //khai bao lai port
main.c file
#include <main.h>
#include <tft320qvt_9341.c>
#include <fonts_tft320.h>
#include <touch7843.c>
int16 thermal;
float result_thermal,testthu=10.5;
int8 jiance()
if (tpstate()==0)
LCD_Clear(WHITE);
BACK_COLOR=WHITE;
POINT_COLOR=RED;
point();
return 1;
if(input(key1)==0)
Touch_Adjust();
return 1;
if(input(key2)==0)
LCD_Clear(RED);
LCD_Clear(GREEN);
LCD_Clear(BLUE);
LCD_Clear(YELLOW);
LCD_Clear(MAGENTA);
LCD_Clear(CYAN );
LCD_Clear(BROWN );
return 1;
return 0;
void info()
int16 lx,ly;
LCD_Clear(WHITE);
BACK_COLOR=WHITE;
POINT_COLOR=RED;
LCD_ShowString(10,35,"PIC18F4620 - LCDTFT 320QVT");
POINT_COLOR=BLUE;
LCD_ShowString(10,55,"LCD_W:");
LCD_ShowNum(70,55,LCD_W,3);
LCD_ShowString(110,55,"LCD_H:");
LCD_ShowNum(160,55,LCD_H,3);
lx=10;ly=75;
POINT_COLOR=MAGENTA ;
LCD_ShowString(lx,ly,"VX:");lx+=40;
LCD_ShowNum(lx,ly,vx,5);
lx+=60;
LCD_ShowString(lx,ly,"Vy:");lx+=40;
LCD_ShowNum(lx,ly,vy,5);
lx=10;ly=95;
LCD_ShowString(lx,ly,"CHX:");lx+=40;
LCD_ShowNum(lx,ly,chx,5);
lx+=60;
LCD_ShowString(lx,ly,"CHY:");lx+=40;
LCD_ShowNum(lx,ly,chy,5);
lx+=200;
LCD_ShowString(lx,ly,"Designed by huynhhai");
void xianshi()
int16 lx,ly;
BACK_COLOR=WHITE;
POINT_COLOR=RED;
//showhanzi(10,0,0);
//showhanzi(45,0,1);
LCD_ShowString(10,35,"http://ttmcu.taobao.com");
LCD_ShowString(10,55,"LCD_W:"); LCD_ShowNum(70,55,thermal,3);
LCD_ShowString(110,55,"LCD_H:");LCD_ShowNum(160,55,LCD_H,3);
lx=10;ly=75;
LCD_ShowString(lx,ly,"VX:");lx+=40;LCD_ShowNum(lx,ly,vx,5);
lx+=60;
LCD_ShowString(lx,ly,"Vy:");lx+=40;LCD_ShowNum(lx,ly,vy,5);
lx=10;ly=95;
LCD_ShowString(lx,ly,"CHX:");lx+=40;LCD_ShowNum(lx,ly,chx,5);
lx+=60;
LCD_ShowString(lx,ly,"CHY:");lx+=40;LCD_ShowNum(lx,ly,chy,5);
void showimage() //ÏÔʾ40*40ͼƬ
int16 i,j,k;
LCD_Clear(WHITE); //ÇåÆÁ
for(k=3;k<8;k++)
for(j=0;j<6;j++)
Address_set(40*j,40*k,40*j+39,40*k+39); //×ø±êÉèÖÃ
for(i=0;i<1600;i++)
LCD_WR_DATA8(image[i*2+1],image[i*2]); //·¢ËÍÑÕÉ«Êý¾ÝΪÌá¸ßËٶȸß8λµÍ8λ·Ö±ð´«µÝ
spistar();
tft320qvt_9341_Init();
LCD_Clear(WHITE);
BACK_COLOR=WHITE;
POINT_COLOR=RED;
while(true)
if(jiance())
showimage();
delay_ms(5000);
font for LCD
fonts_tft320.h file
#ifndef __FONTS_TFT320_H
#define __FONTS_TFT320_H
const unsigned char image[]={ /* 0X00,0X10,0X28,0X00,0X28,0X00,0X01,0X1B,*/
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBE,0XF7,0X7D,0XEF,
0XBA,0XD6,0XB6,0XB5,0XF3,0X9C,0XB2,0X94,0XB3,0X9C,0XB2,0X94,0X34,0XA5,0XF7,0XBD,
0XFB,0XDE,0X7D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBE,0XF7,0XFB,0XDE,0XF3,0X9C,0XCB,0X5A,
0XC7,0X39,0X04,0X21,0X82,0X10,0X42,0X10,0X42,0X10,0X41,0X08,0X83,0X18,0X45,0X29,
0XC7,0X39,0X0C,0X63,0X75,0XAD,0X3C,0XE7,0XBE,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X3C,0XE7,0XB2,0X94,0X08,0X42,0XC3,0X18,0X82,0X10,
0X04,0X21,0X45,0X29,0X86,0X31,0X86,0X31,0X86,0X31,0X86,0X31,0X45,0X29,0X04,0X21,
0X82,0X10,0X41,0X08,0XC3,0X18,0X08,0X42,0XF3,0X9C,0X3C,0XE7,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFB,0XDE,0X0C,0X63,0XC3,0X18,0XC3,0X18,0X45,0X29,0XC7,0X39,
0X08,0X42,0X08,0X42,0X08,0X42,0X08,0X42,0X08,0X42,0X08,0X42,0XC7,0X39,0XC7,0X39,
0X86,0X31,0X86,0X31,0X04,0X21,0X41,0X08,0X82,0X10,0XCB,0X5A,0XBA,0XD6,0XFF,0XFF,
0XFF,0XFF,0XFB,0XDE,0XCB,0X5A,0X82,0X10,0X45,0X29,0XC7,0X39,0X08,0X42,0X08,0X42,
0X09,0X4A,0X49,0X4A,0X49,0X4A,0X49,0X4A,0X49,0X4A,0X49,0X4A,0X08,0X42,0XC7,0X39,
0XC7,0X39,0XC7,0X39,0X86,0X31,0X45,0X29,0X83,0X18,0X00,0X00,0XC8,0X41,0X38,0XC6,
0X7D,0XEF,0X8E,0X73,0X82,0X10,0X45,0X29,0XC7,0X39,0X08,0X42,0X09,0X4A,0X8A,0X52,
0X30,0X84,0XCF,0X7B,0X8A,0X52,0X49,0X4A,0X4A,0X52,0X49,0X4A,0XCB,0X5A,0XCF,0X7B,
0X0C,0X63,0X08,0X42,0XC7,0X39,0X86,0X31,0X45,0X29,0XC3,0X18,0X00,0X00,0X49,0X4A,
0XBA,0XD6,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XF3,0X9C,0XC3,0X18,0X04,0X21,0XC7,0X39,0X08,0X42,0X49,0X4A,0X49,0X4A,0X72,0X94,
0X7D,0XEF,0X7D,0XEF,0XB2,0X94,0X4A,0X52,0X49,0X4A,0X8A,0X52,0X75,0XAD,0XBE,0XF7,
0XBA,0XD6,0X4D,0X6B,0XC7,0X39,0XC7,0X39,0X86,0X31,0X45,0X29,0XC3,0X18,0X41,0X08,
0XCF,0X7B,0X7C,0XE7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBA,0XD6,
0X08,0X42,0X82,0X10,0XC7,0X39,0X08,0X42,0X49,0X4A,0X49,0X4A,0X8E,0X73,0XFB,0XDE,
0XFF,0XFF,0XBE,0XF7,0XBA,0XD6,0X8E,0X73,0X08,0X42,0X30,0X84,0X3C,0XE7,0X7D,0XEF,
0XFF,0XFF,0XB6,0XB5,0X49,0X4A,0XC7,0X39,0X86,0X31,0X45,0X29,0X04,0X21,0X41,0X08,
0X45,0X29,0XB6,0XB5,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBE,0XF7,0X71,0X8C,
0X41,0X08,0X45,0X29,0X08,0X42,0X49,0X4A,0X49,0X4A,0X4A,0X52,0XB2,0X94,0XBE,0XF7,
0XBE,0XF7,0XB2,0X94,0XCF,0X7B,0XCF,0X7B,0X49,0X4A,0XB6,0XB5,0XF3,0X9C,0X0C,0X63,
0X38,0XC6,0XBA,0XD6,0X0C,0X63,0X87,0X39,0XC7,0X39,0X86,0X31,0X45,0X29,0XC3,0X18,
0X41,0X08,0X30,0X84,0X7D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X3C,0XE7,0XCB,0X5A,
0X41,0X08,0XC7,0X39,0X08,0X42,0X49,0X4A,0X4A,0X52,0X8A,0X52,0XF3,0X9C,0XFF,0XFF,
0X7D,0XEF,0XC7,0X39,0XC3,0X18,0X0C,0X63,0XCB,0X5A,0XB6,0XB5,0XB2,0X94,0XCB,0X5A,
0X75,0XAD,0XFA,0XD6,0X4D,0X6B,0X87,0X39,0XC7,0X39,0X86,0X31,0X45,0X29,0X04,0X21,
0X41,0X08,0X8A,0X52,0X79,0XCE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X38,0XC6,0X86,0X31,
0X04,0X21,0XC8,0X41,0X49,0X4A,0X49,0X4A,0X4A,0X52,0X49,0X4A,0XB1,0X8C,0XBE,0XF7,
0XBE,0XF7,0XB2,0X94,0XCF,0X7B,0XCF,0X7B,0X49,0X4A,0X74,0XA5,0X7D,0XEF,0X7C,0XE7,
0XBE,0XF7,0X79,0XCE,0X0C,0X63,0XC7,0X39,0XC7,0X39,0X86,0X31,0X45,0X29,0X04,0X21,
0X82,0X10,0X45,0X29,0X75,0XAD,0XBE,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X34,0XA5,0X82,0X10,
0X86,0X31,0X08,0X42,0X49,0X4A,0X49,0X4A,0X8A,0X52,0X49,0X4A,0X4D,0X6B,0XBA,0XD6,
0XFF,0XFF,0XFF,0XFF,0X79,0XCE,0X0D,0X63,0XC7,0X39,0XCF,0X7B,0X7D,0XEF,0XFF,0XFF,
0XFF,0XFF,0X75,0XAD,0X08,0X42,0X86,0X31,0XC7,0X39,0X86,0X31,0X45,0X29,0X45,0X29,
0XC3,0X18,0XC3,0X18,0XB2,0X94,0X7D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBE,0XF7,0XB2,0X8C,0X41,0X08,
0XC7,0X39,0X08,0X42,0X49,0X4A,0X49,0X4A,0X8A,0X52,0X8A,0X52,0X4A,0X4A,0XD0,0X7B,
0X7A,0XC6,0X7B,0XBE,0X90,0X6B,0XC9,0X39,0X88,0X31,0XC9,0X39,0XB3,0X84,0XBB,0XC6,
0XF8,0XB5,0XCC,0X5A,0X86,0X31,0XC7,0X39,0XC7,0X39,0X86,0X31,0X45,0X29,0X45,0X29,
0XC4,0X20,0X41,0X08,0X30,0X84,0X3C,0XE7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X3C,0XE7,0X8A,0X4A,0XC3,0X10,
0XC7,0X39,0X08,0X42,0X49,0X4A,0X49,0X4A,0X4A,0X4A,0X4A,0X42,0X09,0X3A,0X08,0X4A,
0X09,0X6B,0X49,0X7B,0XC6,0X7A,0X05,0X83,0X46,0X83,0XC5,0X7A,0XC6,0X72,0X09,0X7B,
0X48,0X5A,0X87,0X31,0X88,0X21,0X88,0X29,0X86,0X31,0X86,0X31,0X45,0X29,0X45,0X29,
0X04,0X21,0X41,0X08,0X4A,0X4A,0XBA,0XD6,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF7,0XC5,0X82,0X50,0X05,0X41,
0XC7,0X29,0X08,0X42,0X49,0X4A,0X4A,0X42,0X49,0X4A,0X09,0X7B,0X88,0X9B,0XC6,0XB3,
0X21,0XD4,0XA0,0XDC,0XE1,0XE4,0X61,0XED,0X61,0XED,0X21,0XED,0XA0,0XE4,0X20,0XDC,
0X80,0XCB,0X43,0XAB,0XC4,0X82,0X06,0X5A,0X47,0X21,0X46,0X29,0X45,0X29,0X04,0X29,
0X04,0X19,0X82,0X10,0X82,0X18,0XF3,0X9C,0X7D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7D,0XEF,0X4D,0X93,0X00,0XA0,0X82,0XB8,
0XC7,0X31,0X09,0X32,0X49,0X4A,0X86,0X7A,0X43,0XC3,0X6B,0XED,0XF4,0XF6,0XEB,0XFD,
0X20,0XFD,0X20,0XFD,0X60,0XFD,0XA0,0XFD,0XA0,0XFD,0X60,0XFD,0X60,0XFD,0X20,0XFD,
0XE0,0XFC,0XA0,0XFC,0X60,0XF4,0XC1,0XDB,0X83,0X9A,0XC5,0X49,0X45,0X29,0X04,0X19,
0XC4,0X20,0X82,0X38,0X00,0X50,0XCB,0X6A,0XBA,0XD6,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFB,0XEE,0X04,0XA1,0X00,0XC0,0X00,0XF0,
0XC3,0XA0,0XC8,0X41,0X49,0X42,0X05,0X9B,0X20,0XFC,0XA4,0XFC,0X69,0XFD,0XE8,0XFD,
0X63,0XFD,0X20,0XFD,0X60,0XFD,0X60,0XFD,0X60,0XFD,0X20,0XFD,0X20,0XFD,0XE0,0XFC,
0XE0,0XFC,0XA0,0XFC,0X60,0XFC,0X20,0XFC,0X41,0XD3,0XC5,0X49,0X45,0X19,0XC4,0X38,
0X82,0X68,0X41,0X88,0X00,0X70,0X49,0X5A,0X79,0XCE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFB,0XF6,0X82,0XC0,0X00,0XD0,0X86,0XC1,
0X46,0XF1,0X41,0XC8,0X45,0X79,0X89,0X52,0X88,0X62,0X86,0X6A,0XC6,0X7A,0XC4,0XBB,
0XE1,0XFC,0X60,0XFD,0X60,0XFD,0XA0,0XFD,0XA0,0XFD,0X60,0XFD,0X60,0XFD,0XE0,0XFC,
0X60,0XE4,0X03,0X93,0X84,0X72,0X44,0X6A,0XC5,0X41,0X45,0X29,0XC3,0X58,0X41,0XA8,
0X40,0X98,0X00,0XB0,0X00,0X60,0X0C,0X6B,0X79,0XCE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7D,0XEF,0XCE,0X83,0X82,0X88,0X00,0XF8,0XC4,0XD8,
0X0C,0XF3,0X8A,0XFA,0X82,0XE8,0X82,0XB0,0X45,0X69,0XC7,0X51,0X08,0X42,0X08,0X3A,
0X86,0X5A,0X83,0X9B,0XA2,0XBC,0X22,0XCD,0X21,0XCD,0XA1,0XC4,0X22,0XB4,0XC4,0X7A,
0X06,0X3A,0X86,0X29,0X45,0X29,0X05,0X31,0XC4,0X50,0X41,0X90,0X00,0XC0,0X00,0XA8,
0X00,0XA0,0X00,0XA8,0X00,0X30,0X4A,0X4A,0XBA,0XD6,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0X7D,0XEF,0X8E,0X73,0XC3,0X18,0X05,0X39,0X82,0XA8,0X00,0XF8,
0XC3,0XF8,0X4D,0XFB,0X4D,0XFB,0XC7,0XF9,0XC3,0XF0,0X82,0XD8,0XC3,0XB0,0X04,0X81,
0X45,0X61,0X46,0X51,0X86,0X49,0X86,0X49,0X46,0X41,0X45,0X41,0X45,0X41,0X45,0X41,
0X05,0X49,0X04,0X61,0X82,0X90,0X41,0XB0,0X00,0XD0,0X00,0XC8,0X00,0XA8,0X00,0XA8,
0X00,0XB8,0X41,0X58,0X82,0X10,0X82,0X10,0XB2,0X94,0XBE,0XF7,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XBE,0XF7,0XCF,0X7B,0X82,0X10,0X04,0X21,0X86,0X29,0X86,0X41,0X04,0X99,
0X40,0XE8,0X41,0XF8,0X86,0XF9,0XCB,0XFA,0X49,0XFA,0X82,0XF8,0X00,0XF8,0X00,0XF0,
0X00,0XE8,0X41,0XD8,0X41,0XD0,0X41,0XC0,0X41,0XC0,0X41,0XC0,0X41,0XC0,0X41,0XC8,
0X00,0XD0,0X00,0XE0,0X00,0XE0,0X00,0XD8,0X00,0XD0,0X00,0XB8,0X00,0XA8,0X41,0X88,
0X82,0X48,0X82,0X10,0X82,0X10,0X00,0X00,0X45,0X29,0X79,0XCE,0XFF,0XFF,0XFF,0XFF,
0XBE,0XF7,0XF3,0X9C,0X82,0X10,0XC3,0X18,0X45,0X29,0X86,0X31,0XC7,0X31,0X30,0X7C,
0XF3,0XDC,0X86,0XE1,0X00,0XF0,0X00,0XF8,0X41,0XF8,0X41,0XF8,0X00,0XF8,0X00,0XF8,
0X00,0XF8,0X00,0XF8,0X00,0XF8,0X00,0XF8,0X00,0XF8,0X00,0XF8,0X00,0XF8,0X00,0XF8,
0X00,0XE8,0X00,0XE0,0X00,0XE0,0X00,0XD8,0X00,0XC8,0X41,0XA0,0X8A,0X9A,0X0C,0X63,
0X04,0X11,0X82,0X10,0X82,0X10,0X41,0X08,0X00,0X00,0X4D,0X6B,0X7D,0XEF,0XFF,0XFF,
0XFB,0XDE,0X08,0X42,0X42,0X10,0X45,0X29,0X86,0X31,0X86,0X31,0X49,0X4A,0X38,0XBE,
0XFF,0XFF,0X38,0XD6,0X86,0XA9,0X00,0XC8,0X00,0XE0,0X00,0XF0,0X00,0XF8,0X00,0XF8,
0X00,0XF8,0X00,0XF8,0X00,0XF8,0X00,0XF8,0X00,0XF8,0X00,0XF8,0X00,0XF0,0X00,0XF0,
0X00,0XE8,0X00,0XE0,0X00,0XD0,0XC3,0X98,0X8A,0X8A,0XB2,0XA4,0XBA,0XC6,0XF7,0XB5,
0X08,0X42,0X41,0X08,0X82,0X10,0X41,0X08,0X00,0X00,0X45,0X29,0XF7,0XBD,0XFF,0XFF,
0X71,0X8C,0X41,0X08,0X04,0X21,0X45,0X29,0X86,0X31,0X86,0X31,0X0C,0X63,0X3C,0XE7,
0XFF,0XFF,0X79,0XD6,0X46,0XB9,0X00,0XE0,0X42,0XC8,0X82,0XA8,0X82,0XB0,0X41,0XD8,
0X82,0XE8,0X82,0XF0,0X41,0XE8,0X41,0XE8,0X41,0XE8,0X41,0XF0,0X41,0XE8,0X41,0XD8,
0X04,0XC1,0X08,0X92,0X4D,0X8B,0X34,0XA5,0XFB,0XC6,0XFB,0XD6,0XBA,0XCE,0X3C,0XE7,
0X30,0X84,0XC3,0X18,0X41,0X08,0X41,0X08,0X00,0X00,0X41,0X08,0XCF,0X7B,0X7D,0XEF,
0X49,0X4A,0X00,0X00,0X04,0X21,0X45,0X29,0X46,0X31,0X86,0X31,0X30,0X84,0XFF,0XFF,
0XFF,0XF7,0XF7,0XDD,0X09,0XDA,0X83,0XF8,0X01,0XF0,0X42,0XC0,0X82,0X98,0X49,0X9A,
0XF3,0XB4,0XF3,0XCC,0X71,0XBC,0X8E,0XBB,0X8E,0XBB,0X30,0XBC,0X71,0XBC,0XF3,0XBC,
0XB6,0XBD,0XFB,0XCE,0XBE,0XE7,0X7D,0XE7,0X3B,0XDF,0XBA,0XD6,0X79,0XCE,0XFB,0XDE,
0X75,0XAD,0X86,0X31,0X41,0X08,0X41,0X08,0X00,0X00,0X00,0X00,0X49,0X4A,0XFB,0XDE,
0X04,0X21,0X41,0X08,0X04,0X21,0X45,0X29,0X45,0X29,0X87,0X39,0XB2,0X94,0XFF,0XFF,
0XBE,0XF7,0X34,0XDD,0X0C,0XEB,0X09,0XFA,0X00,0XF0,0X01,0XD8,0X00,0XD8,0X8B,0XD2,
0X7D,0XE7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XBE,0XFF,0X7D,0XEF,0XFB,0XDE,0XFB,0XDE,0XBA,0XD6,0X79,0XCE,0XBA,0XD6,
0X78,0XC6,0XC7,0X39,0X00,0X00,0X41,0X08,0X00,0X00,0X00,0X00,0XC7,0X39,0X79,0XCE,
0X00,0X00,0X82,0X10,0XC3,0X18,0X04,0X21,0X05,0X29,0X86,0X31,0XB3,0X9C,0XFF,0XFF,
0XFF,0XF7,0X75,0XDD,0XC7,0XE9,0XC7,0XF9,0X01,0XF8,0X01,0XF0,0X00,0XE8,0X49,0XE2,
0XFB,0XEE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XBE,0XF7,0X7D,0XEF,0XFB,0XDE,0XFB,0XDE,0XBA,0XD6,0X79,0XCE,0XBA,0XD6,
0XB9,0XCE,0X08,0X42,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0X00,0XC7,0X39,0X38,0XC6,
0X00,0X00,0X82,0X10,0X82,0X10,0X04,0X21,0X04,0X21,0X45,0X29,0X30,0X84,0XFF,0XFF,
0XFF,0XFF,0X38,0XDE,0XC4,0XD0,0X00,0XF0,0X01,0XF8,0X00,0XF8,0X00,0XF0,0X08,0XD2,
0XFB,0XE6,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XBE,0XF7,0X7D,0XEF,0XFB,0XDE,0XBA,0XD6,0X79,0XCE,0X79,0XCE,0XBA,0XD6,
0X79,0XCE,0XC7,0X39,0X41,0X08,0X00,0X00,0X00,0X00,0X00,0X00,0X86,0X31,0X38,0XC6,
0X00,0X00,0X00,0X00,0XC3,0X18,0XCB,0X5A,0X86,0X31,0XC3,0X18,0XCB,0X5A,0X7D,0XEF,
0XFF,0XFF,0X7D,0XEF,0XCF,0XBB,0XC3,0XB0,0X41,0XD0,0X41,0XD0,0X82,0XB8,0X4D,0XB3,
0XBE,0XF7,0XBE,0XF7,0X3D,0XEF,0XFB,0XDE,0XBA,0XD6,0X79,0XCE,0X79,0XCE,0XFA,0XD6,
0XF7,0XBD,0X04,0X21,0X86,0X31,0X04,0X21,0X00,0X00,0X00,0X00,0X86,0X31,0X38,0XC6,
0X86,0X31,0XC3,0X18,0XCB,0X5A,0X75,0XAD,0XCF,0X7B,0X41,0X08,0X86,0X31,0XF7,0XBD,
0XFF,0XFF,0XFF,0XFF,0XBE,0XEF,0X74,0XB5,0X30,0X9C,0X30,0X9C,0X72,0XA4,0XBB,0XD6,
0XBE,0XF7,0X7D,0XEF,0X3C,0XE7,0XFB,0XDE,0XBA,0XD6,0X79,0XCE,0X79,0XCE,0X3C,0XE7,
0X71,0X8C,0X81,0X08,0X0C,0X63,0XCF,0X7B,0X82,0X10,0X00,0X00,0X8A,0X52,0X38,0XC6,
0X75,0XAD,0X71,0X8C,0XB6,0XB5,0X3C,0XE7,0XFB,0XDE,0XC7,0X39,0X00,0X00,0XCF,0X73,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBE,0XF7,
0X7D,0XEF,0X7D,0XEF,0X3B,0XDF,0XFA,0XD6,0X79,0XCE,0X79,0XCE,0XFB,0XDE,0XB9,0XCE,
0XC7,0X39,0XC4,0X20,0X71,0X8C,0XBA,0XD6,0X71,0X8C,0XCB,0X5A,0XB2,0X94,0XBA,0XD6,
0XFF,0XFF,0X7D,0XEF,0X7D,0XEF,0XFF,0XFF,0XFF,0XFF,0XB6,0XB5,0X46,0X29,0X05,0X19,
0X75,0XA5,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0X7D,0XEF,0X3C,0XE7,0XFB,0XDE,0XBA,0XD6,0X79,0XCE,0XBA,0XD6,0XFC,0XDE,0X4E,0X63,
0X42,0X08,0X0C,0X63,0XF7,0XBD,0XBE,0XF7,0XFF,0XFF,0XFB,0XDE,0XFB,0XDE,0XBE,0XF7,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XF4,0X9C,0X04,0X21,
0X05,0X21,0XB6,0XA5,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBE,0XF7,0XBE,0XF7,0X7D,0XEF,
0X3C,0XE7,0XFB,0XDE,0XBA,0XD6,0X79,0XCE,0XFB,0XDE,0XBB,0XD6,0XD1,0X73,0X83,0X18,
0X86,0X39,0X34,0X9D,0XBD,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBE,0XFF,0X35,0XD6,0XEB,0XCC,0X43,0XB3,
0X40,0X51,0X05,0X19,0XF5,0X8C,0XBE,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBE,0XF7,0XBE,0XF7,0X7D,0XEF,0X7D,0XEF,0X3C,0XE7,
0XFB,0XDE,0XBA,0XDE,0XBA,0XD6,0X3C,0XDF,0X3A,0XBE,0X4F,0X63,0X82,0X49,0X40,0XA3,
0X23,0XB4,0XCC,0X83,0X3A,0XBE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XBF,0XF7,0XB5,0XBD,0X82,0X92,0X20,0XF4,0XA0,0XFC,
0X60,0XE4,0X40,0X82,0X84,0X41,0X8F,0X6B,0X77,0XAD,0X3D,0XE7,0XFF,0XFF,0XFF,0XFF,
0XFE,0XFF,0XBE,0XF7,0XBE,0XF7,0XBE,0XF7,0X7D,0XEF,0X7D,0XEF,0X3C,0XE7,0XFB,0XDE,
0XFB,0XDE,0X3D,0XE7,0XBB,0XCE,0X36,0X9D,0X0B,0X6B,0X41,0X6A,0X60,0XC4,0X20,0XFE,
0X60,0XF5,0X00,0X8B,0XC7,0X6A,0X38,0XC6,0XBE,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7D,0XEF,0X4B,0X7B,0X80,0XB2,0XA0,0XFC,0XA0,0XFC,
0XE0,0XFC,0XE0,0XFC,0XC0,0XCB,0XC1,0X8A,0X45,0X62,0X4D,0X6B,0XB3,0X94,0XF7,0XBD,
0X3D,0XDF,0XFF,0XF7,0XFF,0XFF,0XBE,0XF7,0X7D,0XEF,0X7D,0XEF,0X7D,0XE7,0X3D,0XDF,
0XBA,0XC6,0X75,0XA5,0X8D,0X7B,0X84,0X7A,0X40,0XB3,0XE0,0XEC,0XE0,0XFD,0XE0,0XFD,
0X60,0XF5,0X20,0XE5,0XA0,0XD4,0X0A,0X6B,0XFB,0XDE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7D,0XEF,0XCC,0X93,0X40,0XEB,0X60,0XFC,0XA0,0XFC,
0XE0,0XFC,0X20,0XFD,0X60,0XFD,0X20,0XF5,0XA0,0XD4,0XC0,0XBB,0X42,0X9B,0X45,0X8B,
0X6B,0X9C,0XAE,0X9C,0X71,0X8C,0XB3,0X94,0X33,0X9D,0X34,0XA5,0XF2,0XA4,0XF0,0XB4,
0XCA,0X9B,0X04,0X9B,0X40,0XBB,0X20,0XE4,0X20,0XFD,0XA0,0XFD,0XA0,0XFD,0XE0,0XFD,
0XE0,0XFD,0XE0,0XFD,0X20,0XC4,0X88,0X5A,0X38,0XBE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X78,0XD6,0X46,0XAB,0X40,0XDB,0X20,0XF4,
0X60,0XFC,0XA0,0XFC,0XE0,0XFC,0X60,0XFD,0XA0,0XFD,0X60,0XFD,0X20,0XF5,0XA0,0XDC,
0XC0,0XB3,0XC0,0X51,0X86,0X29,0X0D,0X63,0X8F,0X7B,0X0D,0X5B,0XC7,0X41,0X01,0X82,
0X00,0XC3,0XC0,0XE3,0X60,0XFC,0XA0,0XFC,0XE0,0XFC,0XE0,0XFC,0X60,0XF5,0X60,0XF5,
0X20,0XE5,0X80,0X9B,0X86,0X62,0X30,0X84,0X79,0XCE,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X38,0XC6,0X2D,0X9C,0X05,0X93,
0X43,0XA3,0X82,0XB3,0XC2,0XBB,0XC2,0XBB,0X22,0XB4,0X82,0XA3,0X42,0X93,0XC3,0X7A,
0X85,0X62,0X0B,0X63,0X71,0X84,0XB6,0XB5,0X79,0XCE,0X79,0XC6,0XB5,0XAD,0X70,0X94,
0X4A,0X8B,0X06,0X83,0X04,0X93,0X04,0X9B,0X43,0X9B,0X43,0X9B,0X43,0X93,0X04,0X83,
0X08,0X73,0X8D,0X73,0XB3,0X94,0X79,0XCE,0X7D,0XEF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,
0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X3C,0XDF,0X38,0XBE,
0X75,0XB5,0X33,0XA5,0X33,0XA5,0XF3,0X9C,0XF3,0X9C,0XF3,0X9C,0XF3,0X94,0XF3,0X9C,
0X35,0XA5,0XF8,0XBD,0XFB,0XDE,0XBE,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0X7E,0XEF,
0XBB,0XD6,0XF8,0XBD,0XB6,0XAD,0X75,0XAD,0X34,0XA5,0X33,0X9D,0X34,0X9D,0X35,0XA5,
0XB7,0XAD,0X79,0XC6,0X3C,0XE7,0XBE,0XF7,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF,0XFF
const char hanzi[]={
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x00,0x00,0xFE,0xFF,0x01,
0x00,0xFE,0xFF,0x01,0x00,0x06,0xC0,0x00,0x00,0x06,0xC0,0x00,0x00,0x06,0xC0,0x00,
0x00,0xFE,0xFF,0x00,0x00,0x06,0xC0,0x00,0x00,0x06,0xC0,0x00,0x00,0x06,0xC0,0x00,
0x00,0xFE,0xFF,0x00,0x00,0x06,0xC0,0x00,0x00,0x06,0xC0,0x00,0x00,0x02,0x00,0x00,
0x30,0x30,0x0C,0x1C,0xF0,0x7F,0xFC,0x3F,0x30,0x30,0x0C,0x1C,0x30,0x30,0x0C,0x1C,
0x30,0x30,0x0C,0x1C,0x30,0x30,0x0C,0x1C,0xF0,0x3F,0xFC,0x1F,0x30,0x30,0x0C,0x1C,
0x30,0x30,0x0C,0x1C,0x30,0x30,0x0C,0x1C,0x30,0x30,0x0C,0x1C,0xF0,0x3F,0xFC,0x1F,
0xF0,0x3F,0xFC,0x1F,0x30,0x30,0x0C,0x1C,0x30,0x10,0x04,0x0C,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x00,0x08,0x08,0xC0,0xF1,0xFF,0x1F,
0xC0,0xF0,0xFF,0x1F,0xC0,0x48,0x4C,0x1C,0xC4,0xDC,0xCC,0x1D,0xCC,0xDC,0x8D,0x1D,
0xDC,0x8E,0x8D,0x1D,0xD8,0x06,0x0E,0x1F,0xF8,0xC3,0xEF,0x1D,0xF8,0xF1,0xEC,0x1C,
0xD0,0x60,0x1D,0x1C,0xC0,0x1C,0x77,0x0C,0xFE,0x9F,0xE7,0x00,0x34,0x83,0xE3,0x0C,
0x30,0xC3,0xFF,0x1F,0x30,0xC3,0x61,0x00,0x30,0xE3,0x61,0x00,0x30,0xE3,0x61,0x06,
0x30,0xF3,0xFF,0x0F,0x30,0xDB,0x61,0x00,0x30,0xFB,0x61,0x04,0x38,0xDB,0x61,0x0E,
0x18,0xCF,0xFF,0x0F,0x18,0xC7,0x61,0x00,0x98,0xC7,0x61,0x00,0x0C,0xC3,0x61,0x38,
0x04,0xC2,0xFF,0x3F,0x06,0xC0,0x01,0x00,0x02,0xC0,0x01,0x00,0x00,0x00,0x00,0x00
const unsigned char asc2_1608[1520]={
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x00,0x00,0x18,0x18,0x00,0x00,
0x00,0x48,0x6C,0x24,0x12,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x24,0x24,0x24,0x7F,0x12,0x12,0x12,0x7F,0x12,0x12,0x12,0x00,0x00,
0x00,0x00,0x08,0x1C,0x2A,0x2A,0x0A,0x0C,0x18,0x28,0x28,0x2A,0x2A,0x1C,0x08,0x08,
0x00,0x00,0x00,0x22,0x25,0x15,0x15,0x15,0x2A,0x58,0x54,0x54,0x54,0x22,0x00,0x00,
0x00,0x00,0x00,0x0C,0x12,0x12,0x12,0x0A,0x76,0x25,0x29,0x11,0x91,0x6E,0x00,0x00,
0x00,0x06,0x06,0x04,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x40,0x20,0x10,0x10,0x08,0x08,0x08,0x08,0x08,0x08,0x10,0x10,0x20,0x40,0x00,
0x00,0x02,0x04,0x08,0x08,0x10,0x10,0x10,0x10,0x10,0x10,0x08,0x08,0x04,0x02,0x00,
0x00,0x00,0x00,0x00,0x08,0x08,0x6B,0x1C,0x1C,0x6B,0x08,0x08,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x08,0x08,0x08,0x08,0x7F,0x08,0x08,0x08,0x08,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x06,0x04,0x03,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x06,0x06,0x00,0x00,
0x00,0x00,0x80,0x40,0x40,0x20,0x20,0x10,0x10,0x08,0x08,0x04,0x04,0x02,0x02,0x00,
0x00,0x00,0x00,0x18,0x24,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x24,0x18,0x00,0x00,
0x00,0x00,0x00,0x08,0x0E,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x3E,0x00,0x00,
0x00,0x00,0x00,0x3C,0x42,0x42,0x42,0x20,0x20,0x10,0x08,0x04,0x42,0x7E,0x00,0x00,
0x00,0x00,0x00,0x3C,0x42,0x42,0x20,0x18,0x20,0x40,0x40,0x42,0x22,0x1C,0x00,0x00,
0x00,0x00,0x00,0x20,0x30,0x28,0x24,0x24,0x22,0x22,0x7E,0x20,0x20,0x78,0x00,0x00,
0x00,0x00,0x00,0x7E,0x02,0x02,0x02,0x1A,0x26,0x40,0x40,0x42,0x22,0x1C,0x00,0x00,
0x00,0x00,0x00,0x38,0x24,0x02,0x02,0x1A,0x26,0x42,0x42,0x42,0x24,0x18,0x00,0x00,
0x00,0x00,0x00,0x7E,0x22,0x22,0x10,0x10,0x08,0x08,0x08,0x08,0x08,0x08,0x00,0x00,
0x00,0x00,0x00,0x3C,0x42,0x42,0x42,0x24,0x18,0x24,0x42,0x42,0x42,0x3C,0x00,0x00,
0x00,0x00,0x00,0x18,0x24,0x42,0x42,0x42,0x64,0x58,0x40,0x40,0x24,0x1C,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x00,0x00,0x00,0x18,0x18,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x08,0x08,0x04,
0x00,0x00,0x00,0x40,0x20,0x10,0x08,0x04,0x02,0x04,0x08,0x10,0x20,0x40,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0x00,0x00,0x00,0x7F,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x02,0x04,0x08,0x10,0x20,0x40,0x20,0x10,0x08,0x04,0x02,0x00,0x00,
0x00,0x00,0x00,0x3C,0x42,0x42,0x46,0x40,0x20,0x10,0x10,0x00,0x18,0x18,0x00,0x00,
0x00,0x00,0x00,0x1C,0x22,0x5A,0x55,0x55,0x55,0x55,0x2D,0x42,0x22,0x1C,0x00,0x00,
0x00,0x00,0x00,0x08,0x08,0x18,0x14,0x14,0x24,0x3C,0x22,0x42,0x42,0xE7,0x00,0x00,
0x00,0x00,0x00,0x1F,0x22,0x22,0x22,0x1E,0x22,0x42,0x42,0x42,0x22,0x1F,0x00,0x00,
0x00,0x00,0x00,0x7C,0x42,0x42,0x01,0x01,0x01,0x01,0x01,0x42,0x22,0x1C,0x00,0x00,
0x00,0x00,0x00,0x1F,0x22,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x22,0x1F,0x00,0x00,
0x00,0x00,0x00,0x3F,0x42,0x12,0x12,0x1E,0x12,0x12,0x02,0x42,0x42,0x3F,0x00,0x00,
0x00,0x00,0x00,0x3F,0x42,0x12,0x12,0x1E,0x12,0x12,0x02,0x02,0x02,0x07,0x00,0x00,
0x00,0x00,0x00,0x3C,0x22,0x22,0x01,0x01,0x01,0x71,0x21,0x22,0x22,0x1C,0x00,0x00,
0x00,0x00,0x00,0xE7,0x42,0x42,0x42,0x42,0x7E,0x42,0x42,0x42,0x42,0xE7,0x00,0x00,
0x00,0x00,0x00,0x3E,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x3E,0x00,0x00,
0x00,0x00,0x00,0x7C,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x11,0x0F,
0x00,0x00,0x00,0x77,0x22,0x12,0x0A,0x0E,0x0A,0x12,0x12,0x22,0x22,0x77,0x00,0x00,
0x00,0x00,0x00,0x07,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0x42,0x7F,0x00,0x00,
0x00,0x00,0x00,0x77,0x36,0x36,0x36,0x36,0x2A,0x2A,0x2A,0x2A,0x2A,0x6B,0x00,0x00,
0x00,0x00,0x00,0xE3,0x46,0x46,0x4A,0x4A,0x52,0x52,0x52,0x62,0x62,0x47,0x00,0x00,
0x00,0x00,0x00,0x1C,0x22,0x41,0x41,0x41,0x41,0x41,0x41,0x41,0x22,0x1C,0x00,0x00,
0x00,0x00,0x00,0x3F,0x42,0x42,0x42,0x42,0x3E,0x02,0x02,0x02,0x02,0x07,0x00,0x00,
0x00,0x00,0x00,0x1C,0x22,0x41,0x41,0x41,0x41,0x41,0x4D,0x53,0x32,0x1C,0x60,0x00,
0x00,0x00,0x00,0x3F,0x42,0x42,0x42,0x3E,0x12,0x12,0x22,0x22,0x42,0xC7,0x00,0x00,
0x00,0x00,0x00,0x7C,0x42,0x42,0x02,0x04,0x18,0x20,0x40,0x42,0x42,0x3E,0x00,0x00,
0x00,0x00,0x00,0x7F,0x49,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x1C,0x00,0x00,
0x00,0x00,0x00,0xE7,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x3C,0x00,0x00,
0x00,0x00,0x00,0xE7,0x42,0x42,0x22,0x24,0x24,0x14,0x14,0x18,0x08,0x08,0x00,0x00,
0x00,0x00,0x00,0x6B,0x49,0x49,0x49,0x49,0x55,0x55,0x36,0x22,0x22,0x22,0x00,0x00,
0x00,0x00,0x00,0xE7,0x42,0x24,0x24,0x18,0x18,0x18,0x24,0x24,0x42,0xE7,0x00,0x00,
0x00,0x00,0x00,0x77,0x22,0x22,0x14,0x14,0x08,0x08,0x08,0x08,0x08,0x1C,0x00,0x00,
0x00,0x00,0x00,0x7E,0x21,0x20,0x10,0x10,0x08,0x04,0x04,0x42,0x42,0x3F,0x00,0x00,
0x00,0x78,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x78,0x00,
0x00,0x00,0x02,0x02,0x04,0x04,0x08,0x08,0x08,0x10,0x10,0x20,0x20,0x20,0x40,0x40,
0x00,0x1E,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x1E,0x00,
0x00,0x38,0x44,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,
0x00,0x06,0x08,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x42,0x78,0x44,0x42,0x42,0xFC,0x00,0x00,
0x00,0x00,0x00,0x03,0x02,0x02,0x02,0x1A,0x26,0x42,0x42,0x42,0x26,0x1A,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x38,0x44,0x02,0x02,0x02,0x44,0x38,0x00,0x00,
0x00,0x00,0x00,0x60,0x40,0x40,0x40,0x78,0x44,0x42,0x42,0x42,0x64,0xD8,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x42,0x7E,0x02,0x02,0x42,0x3C,0x00,0x00,
0x00,0x00,0x00,0xF0,0x88,0x08,0x08,0x7E,0x08,0x08,0x08,0x08,0x08,0x3E,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7C,0x22,0x22,0x1C,0x02,0x3C,0x42,0x42,0x3C,
0x00,0x00,0x00,0x03,0x02,0x02,0x02,0x3A,0x46,0x42,0x42,0x42,0x42,0xE7,0x00,0x00,
0x00,0x00,0x00,0x0C,0x0C,0x00,0x00,0x0E,0x08,0x08,0x08,0x08,0x08,0x3E,0x00,0x00,
0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x38,0x20,0x20,0x20,0x20,0x20,0x20,0x22,0x1E,
0x00,0x00,0x00,0x03,0x02,0x02,0x02,0x72,0x12,0x0A,0x16,0x12,0x22,0x77,0x00,0x00,
0x00,0x00,0x00,0x0E,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x08,0x3E,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0x92,0x92,0x92,0x92,0x92,0xB7,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3B,0x46,0x42,0x42,0x42,0x42,0xE7,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x42,0x42,0x42,0x42,0x42,0x3C,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1B,0x26,0x42,0x42,0x42,0x22,0x1E,0x02,0x07,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x78,0x44,0x42,0x42,0x42,0x44,0x78,0x40,0xE0,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x77,0x4C,0x04,0x04,0x04,0x04,0x1F,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7C,0x42,0x02,0x3C,0x40,0x42,0x3E,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x08,0x08,0x3E,0x08,0x08,0x08,0x08,0x08,0x30,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x63,0x42,0x42,0x42,0x42,0x62,0xDC,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE7,0x42,0x24,0x24,0x14,0x08,0x08,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xEB,0x49,0x49,0x55,0x55,0x22,0x22,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x76,0x24,0x18,0x18,0x18,0x24,0x6E,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xE7,0x42,0x24,0x24,0x14,0x18,0x08,0x08,0x07,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7E,0x22,0x10,0x08,0x08,0x44,0x7E,0x00,0x00,
0x00,0xC0,0x20,0x20,0x20,0x20,0x20,0x10,0x20,0x20,0x20,0x20,0x20,0x20,0xC0,0x00,
0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,
0x00,0x06,0x08,0x08,0x08,0x08,0x08,0x10,0x08,0x08,0x08,0x08,0x08,0x08,0x06,0x00,
0x0C,0x32,0xC2,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
fonts_tft320.c file
GOOD LUCK
huynhhai
Posted: Sat Sep 09, 2017 9:48 am |
touch7843.c file
#include <touch7843.h>
int16 vx=15489,vy=11106;
int16 chx=199,chy=3871;
struct tp_pix_ tp_pixad,tp_pixlcd;
int8 tpstate(void)
return Penirq;
void spistar(void)
output_high(CS);
output_high(DCLK);
output_high(DIN);
output_high(DCLK);
void WriteCharTo7843(unsigned char num)
unsigned char count=0;
output_low(DCLK);
for(count=0;count<8;count++)
num<<=1;
//DIN=CY;
if(carry_flag==1){output_high(DIN);}
if(carry_flag==0){output_low(DIN);}
output_low(DCLK);
delay_cycles(3);
output_high(DCLK);
delay_cycles(3);
int16 ReadFromCharFrom7843()
int8 count=0;
int16 Num=0;
for(count=0;count<12;count++)
Num<<=1;
output_high(DCLK);
delay_cycles(3);
output_low(DCLK);
delay_cycles(3);
if(input(DOUT))
Num|=1;
return(Num);
//7846/7843/XPT2046/UH7843/UH7846 0x90=y 0xd0-x
int16 ADS_Read_AD(unsigned char CMD)
int16 l;
output_low(CS);
WriteCharTo7843(CMD);
output_high(DCLK);
delay_cycles(4);
output_low(DCLK);
delay_cycles(4);
l=ReadFromCharFrom7843();
output_high(CS);
return l;
#define READ_TIMES 15
#define LOST_VAL 5
int16 ADS_Read_XY(int8 xy)
int16 i, j;
int16 buf[READ_TIMES];
int16 sum=0;
int16 temp;
for(i=0;i<READ_TIMES;i++)
buf[i]=ADS_Read_AD(xy);
for(i=0;i<READ_TIMES-1; i++)
for(j=i+1;j<READ_TIMES;j++)
if(buf[i]>buf[j])
temp=buf[i];
buf[i]=buf[j];
buf[j]=temp;
sum=0;
for(i=LOST_VAL;i<READ_TIMES-LOST_VAL;i++)sum+=buf[i];
temp=sum/(READ_TIMES-2*LOST_VAL);
return temp;
int8 Read_ADS(int16 *x,int16 *y)
int16 xtemp,ytemp;
xtemp=ADS_Read_XY(CMD_RDX);
ytemp=ADS_Read_XY(CMD_RDY);
if(xtemp<100||ytemp<100)return 0;
*x=xtemp;
*y=ytemp;
return 1;
#define ERR_RANGE 20
int8 Read_ADS2(int16 *x,int16 *y)
int16 x1,y1;
int16 x2,y2;
int8 flag;
flag=Read_ADS(&x1,&y1);
if(flag==0)return(0);
flag=Read_ADS(&x2,&y2);
if(((x2<=x1&&x1<x2+ERR_RANGE)||(x1<=x2&&x2<x1+ERR_RANGE))
&&((y2<=y1&&y1<y2+ERR_RANGE)||(y1<=y2&&y2<y1+ERR_RANGE)))
*x=(x1+x2)>>1;
*y=(y1+y2)>>1;
return 1;
}else return 0;
int8 Read_TP_Once(void)
int8 re=0;
int16 x1,y1;
while(re==0)
while(!Read_ADS2(&tp_pixad.x,&tp_pixad.y));
delay_ms(10);
while(!Read_ADS2(&x1,&y1));
if(tp_pixad.x==x1&&tp_pixad.y==y1)
re=1;
return re;
void Drow_Touch_Point(int16 x,int16 y)
LCD_DrawLine(x-12,y,x+13,y);
LCD_DrawLine(x,y-12,x,y+13);
LCD_DrawPoint(x+1,y+1);
LCD_DrawPoint(x-1,y+1);
LCD_DrawPoint(x+1,y-1);
LCD_DrawPoint(x-1,y-1);
//Draw_Circle(x,y,6);
int32 Convert_Pos(void) //---> defaut int64
int8 l=0;
if(Read_ADS2(&tp_pixad.x,&tp_pixad.y))
l=1;
tp_pixlcd.x=tp_pixad.x>chx?((int32)tp_pixad.x-(int32)chx)*1000/vx:((int32)chx-(int32)tp_pixad.x)*1000/vx;
tp_pixlcd.y=tp_pixad.y>chy?((int32)tp_pixad.y-(int32)chy)*1000/vy:((int32)chy-(int32)tp_pixad.y)*1000/vy;
return l;
#define tp_pianyi 50
#define tp_xiaozhun 1000
void Touch_Adjust(void)
float32 vx1,vx2,vy1,vy2;
int16 chx1,chx2,chy1,chy2;
int16 lx,ly;
struct tp_pixu32_ p[4];
int8 cnt=0;
cnt=0;
POINT_COLOR=BLUE;
BACK_COLOR =WHITE;
LCD_Clear(WHITE);
POINT_COLOR=RED;
LCD_Clear(WHITE);
Drow_Touch_Point(tp_pianyi,tp_pianyi);
while(true)
if(input(Penirq)==0)
if(Read_TP_Once())
p[cnt].x=tp_pixad.x;
p[cnt].y=tp_pixad.y;
cnt++;
switch(cnt)
case 1:
LCD_Clear(WHITE);
while(!input(Penirq))
Drow_Touch_Point(LCD_W-tp_pianyi-1,tp_pianyi);
case 2:
LCD_Clear(WHITE);
Drow_Touch_Point(tp_pianyi,LCD_H-tp_pianyi-1);
case 3:
LCD_Clear(WHITE);
Drow_Touch_Point(LCD_W-tp_pianyi-1,LCD_H-tp_pianyi-1);
case 4:
LCD_Clear(WHITE);
vx1=p[1].x>p[0].x?(p[1].x-p[0].x+1)*1000/(LCD_W-tp_pianyi-tp_pianyi):(p[0].x-p[1].x-1)*1000/(LCD_W-tp_pianyi-tp_pianyi);
chx1=p[1].x>p[0].x?p[0].x-(vx1*tp_pianyi)/1000:p[0].x+(vx1*tp_pianyi)/1000;
vy1=p[2].y>p[0].y?(p[2].y-p[0].y-1)*1000/(LCD_H-tp_pianyi-tp_pianyi):(p[0].y-p[2].y-1)*1000/(LCD_H-tp_pianyi-tp_pianyi);
chy1=p[2].y>p[0].y?p[0].y-(vy1*tp_pianyi)/1000:p[0].y+(vy1*tp_pianyi)/1000;
vx2=p[3].x>p[2].x?(p[3].x-p[2].x+1)*1000/(LCD_W-tp_pianyi-tp_pianyi):(p[2].x-p[3].x-1)*1000/(LCD_W-tp_pianyi-tp_pianyi);
chx2=p[3].x>p[2].x?p[2].x-(vx2*tp_pianyi)/1000:p[2].x+(vx2*tp_pianyi)/1000;
vy2=p[3].y>p[1].y?(p[3].y-p[1].y-1)*1000/(LCD_H-tp_pianyi-tp_pianyi):(p[1].y-p[3].y-1)*1000/(LCD_H-tp_pianyi-tp_pianyi);
chy2=p[3].y>p[1].y?p[1].y-(vy2*tp_pianyi)/1000:p[1].y+(vy2*tp_pianyi)/1000;
if((vx1>vx2&&vx1>vx2+tp_xiaozhun)||(vx1<vx2&&vx1<vx2-tp_xiaozhun)||(vy1>vy2&&vy1>vy2+tp_xiaozhun)||(vy1<vy2&&vy1<vy2-tp_xiaozhun))
cnt=0;
LCD_Clear(WHITE);
continue;
vx=(vx1+vx2)/2;
vy=(vy1+vy2)/2;
chx=(chx1+chx2)/2;
chy=(chy1+chy2)/2;
LCD_Clear(WHITE);
POINT_COLOR=BLUE;
BACK_COLOR=WHITE;
lx=0;ly=50;
LCD_ShowString(lx,ly,"VX1:");
lx+=40;
LCD_ShowNum(lx,ly,vx1,4);
lx=0;ly+=20;
LCD_ShowString(lx,ly,"Vy1:");
lx+=40;LCD_ShowNum(lx,ly,vy1,4);
lx=0;ly+=20;
LCD_ShowString(lx,ly,"CHX1:");
lx+=40;LCD_ShowNum(lx,ly,chx1,4);
lx=0;ly+=20;
LCD_ShowString(lx,ly,"CHY1:");
lx+=40;LCD_ShowNum(lx,ly,chy1,4);
lx=100;ly=50;
LCD_ShowString(lx,ly,"VX2:");lx+=40;
LCD_ShowNum(lx,ly,vx2,4);
lx=100;ly+=20;
LCD_ShowString(lx,ly,"Vy2:");lx+=40;
LCD_ShowNum(lx,ly,vy2,4);
lx=100;ly+=20;
LCD_ShowString(lx,ly,"CHX2:");lx+=40;
LCD_ShowNum(lx,ly,chx2,4);
lx=100;ly+=20;
LCD_ShowString(lx,ly,"CHY2:");lx+=40;
LCD_ShowNum(lx,ly,chy2,4);
lx=50;ly=150;
LCD_ShowNum(lx,ly,vx,4);
lx=50;ly+=20;
LCD_ShowNum(lx,ly,vy,4);
lx=50;ly+=20;
LCD_ShowNum(lx,ly,chx,4);
lx=50;ly+=20;
LCD_ShowNum(lx,ly,chy,4);
lx=30;ly+=30;
LCD_ShowString(lx,ly,"Adjust OK! Touch Anywhere To Continue");
Read_TP_Once();
LCD_Clear(WHITE);
return;
void point(void)
int32 t=0; // double t=0;
while(true)
t=0;
if(Convert_Pos())
//LCD_ShowString(10,250,"X:");LCD_ShowNum(30,250,(u32)tp_pixad.x,6);
//LCD_ShowString(180,250,"Y:");LCD_ShowNum(200,250,(u32)tp_pixad.y,6);
LCD_ShowNum(30,250,tp_pixad.x,4);
LCD_ShowNum(200,250,tp_pixad.y,4);
LCD_DrawPoint_big(tp_pixlcd.x,tp_pixlcd.y);
t++;
if(t>65000)
return;
touch7843.h file
#ifndef __TOUCH7843_H
#define __TOUCH7843_H
/* touch panel interface define */
#define CMD_RDX 0xD0 //
#define CMD_RDY 0x90
//khai bao spi giao tiep - dung software
#define DCLK PIN_D0
#define CS PIN_D1
#define DIN PIN_D2
#define DOUT PIN_D3
struct tp_pix_
int16 x;
int16 y;
struct tp_pixu32_
int32 x;
int32 y;
extern struct tp_pix_; // tp_pixad,tp_pixlcd
extern int16 vx,vy;
extern int16 chx,chy;
int8 tpstate(void);
void spistar(void);
void Touch_Adjust(void);
void point(void);
int16 ReadFromCharFrom7843();
[/code] |
