diode_blade
Joined: 18 Aug 2014 Posts: 56 Location: Sheffield, South Yorkshire
| Device selection and MPLAB 8.92 |
Posted: Mon Aug 14, 2017 2:01 am |
Hi Guys,
Hope you might be able to help.
I have just upgraded to PCM and PCH compiler from 5.020 to 5.074. I have installed everything using administrator rights. When I run MPLAB 8.92 and I go to select device or even create a new project it does not list the 18F67K40 device. Is this an MPLAB issue ? I know this is not directly a compiler question but am wondering if anyone else has had this issue before.
I can select it in MPLABX, is because 8.92 is a bit old for this device?
Kind regards
Dave |
Posted: Mon Aug 14, 2017 2:30 am |
Yes.
8.92, does not support the device. |
diode_blade
Posted: Mon Aug 14, 2017 3:18 am |
Thanks Ttelmah.
Had an inkling that might be the case.
Regards
Dave
Case closed delete thread please. |
Posted: Mon Aug 14, 2017 3:25 am |
Inklings are remarkably often right....
It is a pity, that devices can't be added to 8.92. It is still a far superior product to MPLAB-X. |
