ADC does not work with external reference
Goto page Previous  1, 2, 3
PostPosted: Mon Jul 31, 2017 2:31 pm     Reply with quote
Good.
I have to agree with Temtronic on this. It's so pointless not to have a few of these adapters in stock. I also keep a couple of serial LCD's for the same reason.
I use the boards rather than cables:
<http://www.ebay.co.uk/itm/CH340G-RS232-Upgrade-To-USB-TTL-Auto-Converter-Adapter-STC-Brush-Module/252424791118?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D555018%26algo%3DPL.SIM%26ao%3D2%26asc%3D20140122125356%26meid%3D3ac58bba8c2b4630a24d9914f065cb96%26pid%3D100005%26rk%3D3%26rkt%3D6%26sd%3D252461894405>
These are great since they operate on 3.3v or 5v, and at under £1 each in the UK (including delivery!), you can't even buy half the parts for the price!...
Great thing is that while for full I/O a proper UART is best, for simple 'got here' messages, a software UART on the PIC is easy to send debug messages, and a simple 5pin socket on the board, or a line on a plug in breadboard, makes connection quick... Smile. You only actually need just one pin on the PIC to send this type of message.
PostPosted: Fri Aug 04, 2017 3:39 pm     Reply with quote
Regarding the Vref+ bug in set_adc_channel() for the 16F914, 16F917, and 16F946, which was discussed earlier in this thread:
CCS emailed me and said it will be fixed in the next release, vs. 5.075.
bjcolo@comcast.net
PostPosted: Mon Aug 07, 2017 11:25 am     Reply with quote
I'm compiling for the 18F87J50 and using an external Vref for the 1st time.
My CCS version is 4,3,0,332
The Vref don't work. It appears to be turned off by set_adc_channel(0);
Failing code:
setup_adc_ports(san0 | san1 | san2 | san4, vss_vref);
set_adc_channel(0);
A look at the .LST file shows:
... set_adc_channel(0);
00234: MOVLW 00
00236: MOVWF 01
00238: MOVF FC2,W
0023A: ANDLW 83 // My comnt: Anding 0x80 turns off bit6 and bit6 allows the external Vref
0023C: IORWF 01,W
0023E: MOVWF FC2
The problem goes away when I code this:
set_adc_channel(0);
The second setup restores ADCON0 bit6.
This appears to be a compiler bug. Should AND the ADCON0 with 0xC0.
Bob
PostPosted: Mon Aug 07, 2017 11:41 am     Reply with quote
You have CCS vs. 4.xxxx. I tested it with vs. 5.071, and it's fixed by
that time. The 0xC3 mask shown below is correct:
.................... set_adc_channel(0);
0003C:  MOVLW  00
0003E:  MOVWF  @01
00040:  MOVF   ANCON1,W
00042:  ANDLW  C3
00044:  IORWF  @01,W
00046:  MOVWF  ANCON1
CCS won't offer a patch to an old version.
bjcolo@comcast.net
PostPosted: Mon Aug 07, 2017 12:24 pm     Reply with quote
Thanks PCM Programmer. Yes, I understand that I have an old version.
Bob
Page 3 of 3
