rs-232 simple HELLO print
POPE19
PostPosted: Fri Aug 04, 2017 12:01 pm     Reply with quote
Hello Guys,
I have got PIC16F887 prototype board from CCS. I am trying to print "hello" on my serial monitor of CCS compiler. I am using CCS PCWH 5.074. I am not getting output.
I have used TTL to USB cable to connect the DB9 connector of (serial PC to prototype board cable) that came with the kit . Here are my connections
TTL-usb adapter DB-9
RXD 1- RXD
TXD 3- TXD
GND 5 -GND
Here is my code.
#include  <16f877.h>
#fuses HS,NOLVP,NOWDT,PUT
#include <input.c>
    printf("\n hello");
I am a beginner and really need to display PIC output on serial monitor. Please help.
PostPosted: Fri Aug 04, 2017 1:03 pm     Reply with quote
The prototype board using the DB9, contains a MAX232. So generates RS232, not TTL serial....
You need to disconnect the MAX232, and connect directly to the TTL level pins not the DB9. The schematic with the card shows how to do this.
The old board had jumpers for this. Not sure about the one you have.
POPE19
PostPosted: Sat Aug 05, 2017 5:13 pm     Reply with quote
It is working fine. Thanks Ttelmah !!
