PIC24EP and I2C issue
Goto page 1, 2  Next
BeeElectronic
PostPosted: Wed Jul 19, 2017 4:05 am     Reply with quote
I try to implement a communication between a PIC24EP256GU810 and a 24AA512 EERPOM with a 400kHz I2C bus but I have a few issues.
Compiler:
- 5.073
Hardware:
- SDA2 (PIN_F4) to SDA pin of the EEPROM
- SCL2 (PIN_F5) to SCL pin of the EEPROM
- A 1.5kOhms pullup resistor to 3.3VDC on SDA and SCL
- WP to GND
- A0, A1, A2 to GND
Fuses:
#include <24EP256GU810.h>
#device ICSP=3
#use delay(internal=47905000,restart_wdt)
#FUSES WDT                      //Watch Dog Timer
#FUSES WPRES32                  //Watch Dog Timer PreScalar 1:32
#FUSES WPOSTS11                 //Watch Dog Timer PostScalar 1:1024
#FUSES OSCIO                    //OSC2 is general purpose output
#FUSES GSSK                     //General Segment Key bits, use if using either WRT or PROTECT fuses
#FUSES NOIOL1WAY                //Allows multiple reconfigurations of peripheral pins
#FUSES CKSFSM                   //Clock Switching is enabled, fail Safe clock monitor is enabled
#FUSES PLLWAIT                  //Clock switch to PLL will wait until the PLL lock signal is valid
#FUSES WINDIS                   //Watch Dog Timer in non-Window mode
#FUSES PUT32                    //Power On Reset Timer value 32ms
#FUSES NOALTI2C1                //I2C1 mapped to SDA1/SCL1 pins
#FUSES NOALTI2C2                //I2C2 mapped to SDA2/SCL2 pins
#FUSES RESET_PRIMARY            //Device will reset to Primary Flash Reset location
#FUSES NOJTAG                   //JTAG disabled
#FUSES NOAWRT                   //Auxiliary program memory is not write-protected
#FUSES NOAPROTECT               //Auxiliary program memory is not code-protected
#FUSES APLK                     //Auxiliary Segment Key bits, use if using either AWRT or APROTECT fuses
#use i2c(MASTER, I2C2, FAST, RESTART_WDT, stream=BUS_I2C)
#endif
Main:
      i2c_start(BUS_I2C);
      i2c_write(BUS_I2C, 0);
      i2c_stop(BUS_I2C);
When I put the scope on the SDA and SCL pin nothing appears (no communication at all).
It's the same if I use this definition:
#define EEPARA_SCL            PIN_F5     // SCL
#define EEPARA_SDA            PIN_F4     // SDA
#use i2c(MASTER, SCL=EEPARA_SCL, SDA=EEPARA_SDA, FAST, RESTART_WDT, stream=BUS_I2C)
But if I reverse the SDA and SCL pin or if I use another pin for SDA or SCL the PIC start the communication.
#define EEPARA_SCL            PIN_F4     // SCL
#define EEPARA_SDA            PIN_F5     // SDA
// OR
#define EEPARA_SDA            PIN_F3     // SDA
// OR
#define EEPARA_SCL            PIN_F3     // SCL
On the device editor I change the I2C-2 pin from F5/A2, F4/A3 to F5/F4. MASTER and SLAVE = TRUE. And still this issue.
I think I forgot something but I don't know what. Do you have an idea?
BeeElectronic
PostPosted: Wed Jul 19, 2017 4:45 am     Reply with quote
If I put
#use i2c(MASTER, I2C2, FAST, RESTART_WDT, stream=BUS_I2C, FORCE_SW)
The bus work well... so strange...
PostPosted: Wed Jul 19, 2017 5:06 am     Reply with quote
I had a very, very quick look at the PICs datasheet and it appears that F5 is the I2C #2 clock, F4 is the I2C #2 data lines.
I suspect in your various tries you're NOT using the internal I2C peripheral, rather a compiler generated I2C driver. The listing would confirm/deny this. Also look in the manual for the correct 'use I2C (....options...) and syntax.
The other problem for me is the WDT. Disable it...NOT required...maybe useful WHEN your complete, 100 % operational program is 'up and running', but until then get rid of it. It'll cause you a lot of headaches.
Also whenever using I2C peripherals, download/compile/run PCM P's I2C scanner program from the 'code library' before cutting your own code ! It'll find all I2C devices on the bus and report them !! It works great and wil confirm your hardware is operational, saving you hours...or days of debugging time.
The other possible problem is this PIC has 144 pins !! It'd be real easy to 'solder bridge' a pin or two...so best to ring out every pin...
Jay
BeeElectronic
PostPosted: Wed Jul 19, 2017 7:00 am     Reply with quote
Thank you for your reply
Yes , it's true
Yes I think so. I probably miss something.
With this #use
The I2C scanner code in debug mode return:
- Count = 1
- i = 0xA0
And my I2C communication work perfectly. I write "123" in the EEPROM at the address 0 and when I read the address 0 I2C_read() return me 123.
But if I use this #use
The I2C scanner code return nothing. And my I2C bus don't work.
BeeElectronic
PostPosted: Wed Jul 19, 2017 7:03 am     Reply with quote
With FORCE_SW
CCS PCD C Compiler, Version 5.073, xxxxx               19-juil.-17 14:59
               Filename:   C:\Users\BE1\Desktop\Programmes - Copie\main.lst
               ROM used:   1424 bytes (1%)
                           Largest free fragment is 65536
               RAM used:   116 (0%) at main() level
                           119 (0%) worst case
               Stack used: 24 locations
               Stack size: 112
00000:  GOTO    48E
.................... #include <main.h>
.................... #ifndef MAIN_H
.................... #define MAIN_H
.................... #include <24EP256GU810.h>
.................... //////////// Standard Header file for the PIC24EP256GU810 device ////////////////
.................... ////        (C) Copyright 1996, 2014 Custom Computer Services          ////
.................... //// This source code may only be used by licensed users of the CCS C  ////
.................... //// compiler.  This source code may only be distributed to other      ////
.................... //// licensed users of the CCS C compiler.  No other use, reproduction ////
.................... //// or distribution is permitted without written permission.          ////
.................... //// Derivative programs created using this software in object code    ////
.................... //// form are not restricted in any way.                               ////
.................... #device PIC24EP256GU810
00200:  CLR     54
00202:  MOV     #20C,W3
00204:  ADD     W3,W0,W0
00206:  TBLRDL.B[W0],W0L
00208:  CLR.B   1
0020A:  RETURN
0020C:  DATA    0A,0D,00
0020E:  DATA    53,74,00
00210:  DATA    61,72,00
00212:  DATA    74,3A,00
00214:  DATA    0A,0D,00
00216:  DATA    00,00,00
00218:  CLR     54
0021A:  MOV     #224,W3
0021C:  ADD     W3,W0,W0
0021E:  TBLRDL.B[W0],W0L
00220:  CLR.B   1
00222:  RETURN
00224:  DATA    41,43,00
00226:  DATA    4B,20,00
00228:  DATA    61,64,00
0022A:  DATA    64,72,00
0022C:  DATA    3A,20,00
0022E:  DATA    25,58,00
00230:  DATA    0A,0D,00
00232:  DATA    00,00,00
00234:  CLR     54
00236:  MOV     #240,W3
00238:  ADD     W3,W0,W0
0023A:  TBLRDL.B[W0],W0L
0023C:  CLR.B   1
0023E:  RETURN
00240:  DATA    0A,0D,00
00242:  DATA    4E,6F,00
00244:  DATA    74,68,00
00246:  DATA    69,6E,00
00248:  DATA    67,20,00
0024A:  DATA    46,6F,00
0024C:  DATA    75,6E,00
0024E:  DATA    64,00,00
00250:  CLR     54
00252:  MOV     #25C,W3
00254:  ADD     W3,W0,W0
00256:  TBLRDL.B[W0],W0L
00258:  CLR.B   1
0025A:  RETURN
0025C:  DATA    0A,0D,00
0025E:  DATA    4E,75,00
00260:  DATA    6D,62,00
00262:  DATA    65,72,00
00264:  DATA    20,6F,00
00266:  DATA    66,20,00
00268:  DATA    69,32,00
0026A:  DATA    63,20,00
0026C:  DATA    63,68,00
0026E:  DATA    69,70,00
00270:  DATA    73,20,00
00272:  DATA    66,6F,00
00274:  DATA    75,6E,00
00276:  DATA    64,3A,00
00278:  DATA    20,25,00
0027A:  DATA    75,00,00
00374:  MOV     W0,W3
00376:  SWAP    W1
00378:  MOV.B   #5,W4L
0037A:  DEC.B   0003
0037C:  DEC.B   0008
0037E:  BRA     Z,3B2
00380:  MOV     W3,W0
00382:  SL      W3,#4,W3
00384:  LSR     W0,#C,W0
00386:  AND     #F,W0
00388:  BRA     NZ,392
0038A:  CP.B    W4L,#1
0038C:  BRA     Z,392
0038E:  BTSS.B  3.7
00390:  BRA     37A
00392:  ADD     #30,W0
00394:  MOV     #3A,W2
00396:  CP      W0,W2
00398:  BRA     NC,39C
0039A:  ADD.B   2,W0L
0039C:  MOV     W1,[W15++]
0039E:  MOV     W3,[W15++]
003A0:  MOV     W4,[W15++]
003A2:  MOV.B   W0L,1060
003A4:  CALL    27C
003A8:  MOV     [--W15],W4
003AA:  MOV     [--W15],W3
003AC:  MOV     [--W15],W1
003AE:  BSET.B  3.7
003B0:  BRA     37A
003B2:  RETURN
003B4:  MOV     W5,[W15++]
003B6:  MOV     #C,W5
003B8:  REPEAT  #3
003BA:  MOV     [W5++],[W15++]
003BC:  MOV     W0,W7
003BE:  MOV     W4,W9
003C0:  BCLR    W4.F
003C2:  CP0     W4
003C4:  BRA     NZ,3D2
003C6:  BTSC    W9.F
003C8:  BRA     3CE
003CA:  MOV     #0,W5
003CC:  BRA     3FC
003CE:  MOV     #0,W5
003D0:  BRA     3FC
003D2:  SUB.B   W4L,#6,W5L
003D4:  BRA     NC,3FA
003D6:  MOV     #30,W0
003D8:  BTSS    W9.F
003DA:  MOV     #20,W0
003DC:  MOV     W0,[W15++]
003DE:  MOV     W1,[W15++]
003E0:  MOV.D   W2,[W15++]
003E2:  MOV     W4,[W15++]
003E4:  MOV.B   W0L,1060
003E6:  CALL    27C
003EA:  MOV     [--W15],W4
003EC:  MOV.D   [--W15],W2
003EE:  MOV     [--W15],W1
003F0:  MOV     [--W15],W0
003F2:  DEC     W5,W5
003F4:  BRA     NN,3DC
003F6:  MOV     #5,W5
003F8:  BRA     3FC
003FA:  MOV     W4,W5
003FC:  MOV     #6,W4
003FE:  BSET    W5.E
00400:  BTSC    W9.F
00402:  BSET    W5.F
00404:  MOV     #2710,W8
00406:  REPEAT  #11
00408:  DIV.U   W7,W8
0040A:  CALL    44A
0040E:  MOV     W1,W7
00410:  MOV     #3E8,W8
00412:  REPEAT  #11
00414:  DIV.U   W7,W8
00416:  CALL    44A
0041A:  MOV     W1,W7
0041C:  MOV     #64,W8
0041E:  REPEAT  #11
00420:  DIV.U   W7,W8
00422:  CALL    44A
00426:  MOV     W1,W7
00428:  MOV     #A,W8
0042A:  REPEAT  #11
0042C:  DIV.U   W7,W8
0042E:  CALL    44A
00432:  MOV     #30,W0
00434:  ADD.B   W1L,W0L,W0L
00436:  MOV     W1,[W15++]
00438:  MOV.D   W2,[W15++]
0043A:  MOV     W4,[W15++]
0043C:  MOV.B   W0L,1060
0043E:  CALL    27C
00442:  MOV     [--W15],W4
00444:  MOV.D   [--W15],W2
00446:  MOV     [--W15],W1
00448:  BRA     484
0044A:  MOV     #30,W6
0044C:  CP0     W0
0044E:  BRA     NZ,46C
00450:  BTSS    W5.E
00452:  BRA     46E
00454:  DEC     W4,W4
00456:  CP.B    W4L,W5L
00458:  BRA     Z,45E
0045A:  BTSC.B  42.0
0045C:  RETURN
0045E:  CP0     W0
00460:  BRA     NZ,46C
00462:  BTSS    W5.E
00464:  BRA     46E
00466:  BTSS    W5.F
00468:  MOV     #20,W6
0046A:  BRA     46E
0046C:  BCLR    W5.E
0046E:  ADD.B   W6L,W0L,W0L
00470:  MOV     W1,[W15++]
00472:  MOV     W2,[W15++]
00474:  MOV     W4,[W15++]
00476:  MOV.B   W0L,1060
00478:  CALL    27C
0047C:  MOV     [--W15],W4
0047E:  MOV     [--W15],W2
00480:  MOV     [--W15],W1
00482:  RETURN
00484:  MOV     #12,W5
00486:  REPEAT  #3
00488:  MOV     [--W15],[W5--]
0048A:  MOV     [--W15],W5
0048C:  RETURN
.................... #list
.................... #device ADC=12
.................... #device ICSP=3
.................... #use delay(internal=47905000,restart_wdt)
002A0:  CP0     W0
002A2:  BTSC.B  42.1
002A4:  BRA     2B2
002A6:  REPEAT  #1D8B
002A8:  CLRWDT
002AA:  REPEAT  #3FFE
002AC:  CLRWDT
002AE:  DEC     W0,W0
002B0:  BRA     NZ,2A6
002B2:  RETURN
.................... #FUSES WDT                      //Watch Dog Timer
.................... #FUSES WPRES32                  //Watch Dog Timer PreScalar 1:32
.................... #FUSES WPOSTS11                 //Watch Dog Timer PostScalar 1:1024
.................... #FUSES OSCIO                    //OSC2 is general purpose output
.................... #FUSES NOWRT                    //Program memory not write protected
.................... #FUSES NOPROTECT                //Code not protected from reading
.................... #FUSES GSSK                     //General Segment Key bits, use if using either WRT or PROTECT fuses
.................... #FUSES IESO                     //Internal External Switch Over mode enabled
.................... #FUSES NOIOL1WAY                //Allows multiple reconfigurations of peripheral pins
.................... #FUSES CKSFSM                   //Clock Switching is enabled, fail Safe clock monitor is enabled
.................... #FUSES PLLWAIT                  //Clock switch to PLL will wait until the PLL lock signal is valid
.................... #FUSES WINDIS                   //Watch Dog Timer in non-Window mode
.................... #FUSES PUT32                    //Power On Reset Timer value 32ms
.................... #FUSES BROWNOUT                 //Reset when brownout detected
.................... #FUSES NOALTI2C1                //I2C1 mapped to SDA1/SCL1 pins
.................... #FUSES NOALTI2C2                //I2C2 mapped to SDA2/SCL2 pins
.................... #FUSES RESET_PRIMARY            //Device will reset to Primary Flash Reset location
.................... #FUSES JTAG                     //JTAG
.................... #FUSES NOAWRT                   //Auxiliary program memory is not write-protected
.................... #FUSES NOAPROTECT               //Auxiliary program memory is not code-protected
.................... #FUSES APLK                     //Auxiliary Segment Key bits, use if using either AWRT or APROTECT fuses
.................... #use i2c(MASTER, I2C2, FAST, RESTART_WDT, stream=BUS_I2C, FORCE_SW)
002BA:  MOV     #8,W2
002BC:  CLRWDT
002BE:  REPEAT  #10
002C0:  CLRWDT
002C2:  BCLR.B  E54.5
002C4:  BCLR.B  E50.5
002C6:  CLRWDT
002C8:  REPEAT  #12
002CA:  CLRWDT
002CC:  RLC.B   W1L,W1L
002CE:  BCLR.B  E54.4
002D0:  BTSC.B  42.0
002D2:  BSET.B  E50.4
002D4:  BTSS.B  42.0
002D6:  BCLR.B  E50.4
002D8:  BSET.B  E50.5
002DA:  BTSS.B  E52.5
002DC:  BRA     2DA
002DE:  DEC     W2,W2
002E0:  BRA     NZ,2BC
002E2:  CLRWDT
002E4:  REPEAT  #10
002E6:  CLRWDT
002E8:  BCLR.B  E54.5
002EA:  BCLR.B  E50.5
002EC:  NOP
002EE:  BSET.B  E50.4
002F0:  CLRWDT
002F2:  REPEAT  #12
002F4:  CLRWDT
002F6:  CLRWDT
002F8:  REPEAT  #12
002FA:  CLRWDT
002FC:  BSET.B  E50.5
002FE:  BTSS.B  E52.5
00300:  BRA     2FE
00302:  CLRWDT
00304:  REPEAT  #12
00306:  CLRWDT
00308:  MOV     #0,W0
0030A:  BTSC.B  E52.4
0030C:  BSET    W0.0
0030E:  BCLR.B  E54.5
00310:  BCLR.B  E50.5
00312:  BCLR.B  E54.4
00314:  BCLR.B  E50.4
00316:  RETURN
.................... #use rs232(xmit=PIN_C1, rcv=PIN_C2, baud=9600, errors)
0027C:  BCLR.B  E20.1
0027E:  BCLR.B  E24.1
00280:  MOV     #8,W3
00282:  REPEAT  #9BB
00284:  CLRWDT
00286:  RRC.B   1060
00288:  BTSC.B  42.0
0028A:  BSET.B  E24.1
0028C:  BTSS.B  42.0
0028E:  BCLR.B  E24.1
00290:  REPEAT  #9B6
00292:  CLRWDT
00294:  DEC     W3,W3
00296:  BRA     NZ,286
00298:  BSET.B  E24.1
0029A:  REPEAT  #9BD
0029C:  CLRWDT
0029E:  RETURN
.................... #endif
BeeElectronic
PostPosted: Wed Jul 19, 2017 7:05 am     Reply with quote
With FORCE_SW
                           119 (0%) worst case
               Stack size: 112
00000:  GOTO    48E
00200:  CLR     54
00202:  MOV     #20C,W3
00204:  ADD     W3,W0,W0
00208:  CLR.B   1
0020A:  RETURN
00218:  CLR     54
0021A:  MOV     #224,W3
0021C:  ADD     W3,W0,W0
00220:  CLR.B   1
00222:  RETURN
00234:  CLR     54
00236:  MOV     #240,W3
00238:  ADD     W3,W0,W0
0023C:  CLR.B   1
0023E:  RETURN
00250:  CLR     54
00252:  MOV     #25C,W3
00254:  ADD     W3,W0,W0
00258:  CLR.B   1
0025A:  RETURN
00374:  MOV     W0,W3
00376:  SWAP    W1
00378:  MOV.B   #5,W4L
0037A:  DEC.B   0003
0037C:  DEC.B   0008
0037E:  BRA     Z,3B2
00380:  MOV     W3,W0
00382:  SL      W3,#4,W3
00384:  LSR     W0,#C,W0
00386:  AND     #F,W0
00388:  BRA     NZ,392
0038A:  CP.B    W4L,#1
0038C:  BRA     Z,392
0038E:  BTSS.B  3.7
00390:  BRA     37A
00392:  ADD     #30,W0
00394:  MOV     #3A,W2
00396:  CP      W0,W2
00398:  BRA     NC,39C
0039A:  ADD.B   2,W0L
003A4:  CALL    27C
003AE:  BSET.B  3.7
003B0:  BRA     37A
003B2:  RETURN
003B6:  MOV     #C,W5
003B8:  REPEAT  #3
003BC:  MOV     W0,W7
003BE:  MOV     W4,W9
003C0:  BCLR    W4.F
003C2:  CP0     W4
003C4:  BRA     NZ,3D2
003C6:  BTSC    W9.F
003C8:  BRA     3CE
003CA:  MOV     #0,W5
003CC:  BRA     3FC
003CE:  MOV     #0,W5
003D0:  BRA     3FC
003D4:  BRA     NC,3FA
003D6:  MOV     #30,W0
003D8:  BTSS    W9.F
003DA:  MOV     #20,W0
003E6:  CALL    27C
003F2:  DEC     W5,W5
003F4:  BRA     NN,3DC
003F6:  MOV     #5,W5
003F8:  BRA     3FC
003FA:  MOV     W4,W5
003FC:  MOV     #6,W4
003FE:  BSET    W5.E
00400:  BTSC    W9.F
00402:  BSET    W5.F
00404:  MOV     #2710,W8
00406:  REPEAT  #11
00408:  DIV.U   W7,W8
0040A:  CALL    44A
0040E:  MOV     W1,W7
00410:  MOV     #3E8,W8
00412:  REPEAT  #11
00414:  DIV.U   W7,W8
00416:  CALL    44A
0041A:  MOV     W1,W7
0041C:  MOV     #64,W8
0041E:  REPEAT  #11
00420:  DIV.U   W7,W8
00422:  CALL    44A
00426:  MOV     W1,W7
00428:  MOV     #A,W8
0042A:  REPEAT  #11
0042C:  DIV.U   W7,W8
0042E:  CALL    44A
00432:  MOV     #30,W0
0043E:  CALL    27C
00448:  BRA     484
0044A:  MOV     #30,W6
0044C:  CP0     W0
0044E:  BRA     NZ,46C
00450:  BTSS    W5.E
00452:  BRA     46E
00454:  DEC     W4,W4
00456:  CP.B    W4L,W5L
00458:  BRA     Z,45E
0045A:  BTSC.B  42.0
0045C:  RETURN
0045E:  CP0     W0
00460:  BRA     NZ,46C
00462:  BTSS    W5.E
00464:  BRA     46E
00466:  BTSS    W5.F
00468:  MOV     #20,W6
0046A:  BRA     46E
0046C:  BCLR    W5.E
00478:  CALL    27C
00482:  RETURN
00484:  MOV     #12,W5
00486:  REPEAT  #3
0048C:  RETURN
002A0:  CP0     W0
002A2:  BTSC.B  42.1
002A4:  BRA     2B2
002A6:  REPEAT  #1D8B
002A8:  CLRWDT
002AA:  REPEAT  #3FFE
002AC:  CLRWDT
002AE:  DEC     W0,W0
002B0:  BRA     NZ,2A6
002B2:  RETURN
002BA:  MOV     #8,W2
002BC:  CLRWDT
002BE:  REPEAT  #10
002C0:  CLRWDT
002C2:  BCLR.B  E54.5
002C4:  BCLR.B  E50.5
002C6:  CLRWDT
002C8:  REPEAT  #12
002CA:  CLRWDT
002CE:  BCLR.B  E54.4
002D0:  BTSC.B  42.0
002D2:  BSET.B  E50.4
002D4:  BTSS.B  42.0
002D6:  BCLR.B  E50.4
002D8:  BSET.B  E50.5
002DA:  BTSS.B  E52.5
002DC:  BRA     2DA
002DE:  DEC     W2,W2
002E0:  BRA     NZ,2BC
002E2:  CLRWDT
002E4:  REPEAT  #10
002E6:  CLRWDT
002E8:  BCLR.B  E54.5
002EA:  BCLR.B  E50.5
002EC:  NOP
002EE:  BSET.B  E50.4
002F0:  CLRWDT
002F2:  REPEAT  #12
002F4:  CLRWDT
002F6:  CLRWDT
002F8:  REPEAT  #12
002FA:  CLRWDT
002FC:  BSET.B  E50.5
002FE:  BTSS.B  E52.5
00300:  BRA     2FE
00302:  CLRWDT
00304:  REPEAT  #12
00306:  CLRWDT
00308:  MOV     #0,W0
0030A:  BTSC.B  E52.4
0030C:  BSET    W0.0
0030E:  BCLR.B  E54.5
00310:  BCLR.B  E50.5
00312:  BCLR.B  E54.4
00314:  BCLR.B  E50.4
00316:  RETURN
0027C:  BCLR.B  E20.1
0027E:  BCLR.B  E24.1
00280:  MOV     #8,W3
00282:  REPEAT  #9BB
00284:  CLRWDT
00286:  RRC.B   1060
00288:  BTSC.B  42.0
0028A:  BSET.B  E24.1
0028C:  BTSS.B  42.0
0028E:  BCLR.B  E24.1
00290:  REPEAT  #9B6
00292:  CLRWDT
00294:  DEC     W3,W3
00296:  BRA     NZ,286
00298:  BSET.B  E24.1
0029A:  REPEAT  #9BD
0029C:  CLRWDT
0029E:  RETURN
Without FORCE_SW
CCS PCD C Compiler, Version 5.073, xxxxx               19-juil.-17 15:03
               ROM used:   1374 bytes (1%)
                           119 (0%) worst case
               Stack size: 112
00000:  GOTO    444
00200:  CLR     54
00202:  MOV     #20C,W3
00204:  ADD     W3,W0,W0
00208:  CLR.B   1
0020A:  RETURN
00218:  CLR     54
0021A:  MOV     #224,W3
0021C:  ADD     W3,W0,W0
00220:  CLR.B   1
00222:  RETURN
00234:  CLR     54
00236:  MOV     #240,W3
00238:  ADD     W3,W0,W0
0023C:  CLR.B   1
0023E:  RETURN
00250:  CLR     54
00252:  MOV     #25C,W3
00254:  ADD     W3,W0,W0
00258:  CLR.B   1
0025A:  RETURN
0032A:  MOV     W0,W3
0032C:  SWAP    W1
0032E:  MOV.B   #5,W4L
00330:  DEC.B   0003
00332:  DEC.B   0008
00334:  BRA     Z,368
00336:  MOV     W3,W0
00338:  SL      W3,#4,W3
0033A:  LSR     W0,#C,W0
0033C:  AND     #F,W0
0033E:  BRA     NZ,348
00340:  CP.B    W4L,#1
00342:  BRA     Z,348
00344:  BTSS.B  3.7
00346:  BRA     330
00348:  ADD     #30,W0
0034A:  MOV     #3A,W2
0034C:  CP      W0,W2
0034E:  BRA     NC,352
00350:  ADD.B   2,W0L
00352:  MOV     W1,[W15++]
00354:  MOV     W3,[W15++]
00356:  MOV     W4,[W15++]
00358:  MOV.B   W0L,1060
0035A:  CALL    27C
0035E:  MOV     [--W15],W4
00360:  MOV     [--W15],W3
00362:  MOV     [--W15],W1
00364:  BSET.B  3.7
00366:  BRA     330
00368:  RETURN
0036A:  MOV     W5,[W15++]
0036C:  MOV     #C,W5
0036E:  REPEAT  #3
00370:  MOV     [W5++],[W15++]
00372:  MOV     W0,W7
00374:  MOV     W4,W9
00376:  BCLR    W4.F
00378:  CP0     W4
0037A:  BRA     NZ,388
0037C:  BTSC    W9.F
0037E:  BRA     384
00380:  MOV     #0,W5
00382:  BRA     3B2
00384:  MOV     #0,W5
00386:  BRA     3B2
00388:  SUB.B   W4L,#6,W5L
0038A:  BRA     NC,3B0
0038C:  MOV     #30,W0
0038E:  BTSS    W9.F
00390:  MOV     #20,W0
00392:  MOV     W0,[W15++]
00394:  MOV     W1,[W15++]
00396:  MOV.D   W2,[W15++]
00398:  MOV     W4,[W15++]
0039A:  MOV.B   W0L,1060
0039C:  CALL    27C
003A0:  MOV     [--W15],W4
003A2:  MOV.D   [--W15],W2
003A4:  MOV     [--W15],W1
003A6:  MOV     [--W15],W0
003A8:  DEC     W5,W5
003AA:  BRA     NN,392
003AC:  MOV     #5,W5
003AE:  BRA     3B2
003B0:  MOV     W4,W5
003B2:  MOV     #6,W4
003B4:  BSET    W5.E
003B6:  BTSC    W9.F
003B8:  BSET    W5.F
003BA:  MOV     #2710,W8
003BC:  REPEAT  #11
003BE:  DIV.U   W7,W8
003C0:  CALL    400
003C4:  MOV     W1,W7
003C6:  MOV     #3E8,W8
003C8:  REPEAT  #11
003CA:  DIV.U   W7,W8
003CC:  CALL    400
003D0:  MOV     W1,W7
003D2:  MOV     #64,W8
003D4:  REPEAT  #11
003D6:  DIV.U   W7,W8
003D8:  CALL    400
003DC:  MOV     W1,W7
003DE:  MOV     #A,W8
003E0:  REPEAT  #11
003E2:  DIV.U   W7,W8
003E4:  CALL    400
003E8:  MOV     #30,W0
003EA:  ADD.B   W1L,W0L,W0L
003EC:  MOV     W1,[W15++]
003EE:  MOV.D   W2,[W15++]
003F0:  MOV     W4,[W15++]
003F2:  MOV.B   W0L,1060
003F4:  CALL    27C
003F8:  MOV     [--W15],W4
003FA:  MOV.D   [--W15],W2
003FC:  MOV     [--W15],W1
003FE:  BRA     43A
00400:  MOV     #30,W6
00402:  CP0     W0
00404:  BRA     NZ,422
00406:  BTSS    W5.E
00408:  BRA     424
0040A:  DEC     W4,W4
0040C:  CP.B    W4L,W5L
0040E:  BRA     Z,414
00410:  BTSC.B  42.0
00412:  RETURN
00414:  CP0     W0
00416:  BRA     NZ,422
00418:  BTSS    W5.E
0041A:  BRA     424
0041C:  BTSS    W5.F
0041E:  MOV     #20,W6
00420:  BRA     424
00422:  BCLR    W5.E
00424:  ADD.B   W6L,W0L,W0L
00426:  MOV     W1,[W15++]
00428:  MOV     W2,[W15++]
0042A:  MOV     W4,[W15++]
0042C:  MOV.B   W0L,1060
0042E:  CALL    27C
00432:  MOV     [--W15],W4
00434:  MOV     [--W15],W2
00436:  MOV     [--W15],W1
00438:  RETURN
0043A:  MOV     #12,W5
0043C:  REPEAT  #3
0043E:  MOV     [--W15],[W5--]
00440:  MOV     [--W15],W5
00442:  RETURN
002A0:  CP0     W0
002A2:  BTSC.B  42.1
002A4:  BRA     2B2
002A6:  REPEAT  #1D8B
002A8:  CLRWDT
002AA:  REPEAT  #3FFE
002AC:  CLRWDT
002AE:  DEC     W0,W0
002B0:  BRA     NZ,2A6
002B2:  RETURN
.................... #use i2c(MASTER, I2C2, FAST, RESTART_WDT, stream=BUS_I2C)
002D2:  MOV     #FFFF,W0
002D4:  BTSS.B  218.3
002D6:  BRA     2E2
002D8:  BTSC.B  219.6
002DA:  BRA     2D8
002DC:  MOV     W1,212
002DE:  BTSC.B  219.6
002E0:  BRA     2DE
002E2:  MOV     #0,W0
002E4:  BTSC.B  219.7
002E6:  INC     W0,W0
002E8:  RETURN
0027C:  BCLR.B  E20.1
0027E:  BCLR.B  E24.1
00280:  MOV     #8,W3
00282:  REPEAT  #9BB
00284:  CLRWDT
00286:  RRC.B   1060
00288:  BTSC.B  42.0
0028A:  BSET.B  E24.1
0028C:  BTSS.B  42.0
0028E:  BCLR.B  E24.1
00290:  REPEAT  #9B6
00292:  CLRWDT
00294:  DEC     W3,W3
00296:  BRA     NZ,286
00298:  BSET.B  E24.1
0029A:  REPEAT  #9BD
0029C:  CLRWDT
0029E:  RETURN
PostPosted: Wed Jul 19, 2017 7:35 am     Reply with quote
Please get rid of the WDT, recompile and test. It's NOT required and may 'complicate' things...
As the listing shows the compiler does create SW I2C code and when using the HW the code looks OK.. (address 0x218 is an I2C #2 register).
Others who use that PIC may be able to help but the fact some code DOES work comfirms HW is OK so it may be a syntax or code style problem.
Jay
BeeElectronic
PostPosted: Wed Jul 19, 2017 7:46 am     Reply with quote
I already try without WDT. Same problem...
PostPosted: Wed Jul 19, 2017 8:59 am     Reply with quote
Try turning off the PMP.
This has priority over the I2C interface, but not over normal pin I/O.
So:
setup_pmp(PAR_DISABLE,0);
Depending on how your compiler version is configuring things, this could stop the I2C from running.
BeeElectronic
PostPosted: Wed Jul 19, 2017 9:47 am     Reply with quote
It's not better.
PostPosted: Wed Jul 19, 2017 3:26 pm     Reply with quote
You should post your small test program maybe someone can see what's happening....
Jay
PostPosted: Thu Jul 20, 2017 12:58 am     Reply with quote
You need to talk to CCS.
I just compiled the original program, and the fault is obvious.
For some reason, it thinks I2C2CON is at the wrong address.
So a fault in the device database for the second I2C.
Interestingly it is at the right location in the register map
from the device editor, but for some reason the code it talking
to the wrong location....
They should fix this in a matter of hours only.
BeeElectronic
PostPosted: Thu Jul 20, 2017 2:18 am     Reply with quote
OK, I do that.
BeeElectronic
PostPosted: Fri Jul 21, 2017 2:36 am     Reply with quote
It's a known issue with v5.073 of the compiler. It has been fixed which will be available in the next compiler release we do.
Richard
CCS Support
So I wait for the new release
oxo
PostPosted: Mon Jul 24, 2017 8:52 am     Reply with quote
I informed CCS of this problem a few weeks ago.
The latest update, 5.074 says they have fixed it. I have not tried it yet - usually CCS updates break something else and I'm at a tight part of the project, so sticking with 5.070 for a few more weeks.
If 5.074 fixes your problem, please let us know Smile
Goto page 1, 2  Next
Page 1 of 2
