capture mode in pic18F13K22
hemnath
PostPosted: Mon Jul 10, 2017 2:41 am     Reply with quote
Earlier I used capture mode with pic18F2520. It was working good. For some reasons, I have to change the controller to 18F13K22.
Using Internal oscillator.
I tried to debug the code using Pickit3. Though i don't apply any frequency, the tm3_variable is not zero. Any help please.
#include "18f13k22.h"
#FUSES INTRC_IO, PLLEN
#use delay(clock = 64000000)
#BYTE INTCON       = 0xFF2
#BYTE TMR0H       = 0xFD7
#BYTE TMR0L       = 0xFD6
#BYTE TRISB        = 0xF93
#BYTE PORTA        = 0xF80
#BYTE PORTB       = 0xF81
#BYTE PORTC      = 0xF82
#BYTE T3CON        = 0xFB1
#BYTE TMR3H        = 0xFB3
#BYTE TMR3L        = 0xFB2
#BYTE T0CON       = 0xFD5
#BIT    TMR0IF       = INTCON.2
#BIT    TMR0IE       = INTCON.5
#BIT    TMR0ON     =  T0CON.7
#BIT   TMR3ON  = T3CON.0
#define CAL_LED1   PIN_C7      // Material Present Status
#define LED1   PIN_C0         // Relay LED status
#define MAX_SAMPLE    100                // Sets No of period samples
// Variable Declaration
unsigned int8 sample = 0;                // Current sample
unsigned int32 total_period;             // Total period count in machine cycles
unsigned int16 new_ccp_value;            //
unsigned int16 old_ccp_value;            //
unsigned int16 new_period_value;         // latest period value = difference between ccp values
unsigned int16 frequency;
float capacitance, disp_value;
unsigned int16 delay_ms_flag = 0;
unsigned int16 seconds;
unsigned int seconds1 = 0;
int1 flag_500ms = 0, flag1_500ms = 0;
unsigned int16 flag = 0;
unsigned int16 tm3_Variable;
float read_capacitance();
void timer0_init();
#int_ccp1
void ccp1_isr()
   new_ccp_value = CCP_1;      // captures the timer value
   if ((sample > 0)&&(sample<MAX_SAMPLE+1))              // Ignores sample zero!
      new_period_value = new_ccp_value - old_ccp_value;  //
      total_period+=new_period_value;                    //
   old_ccp_value = new_ccp_value;                        // ready for next sample
   if (sample < (MAX_SAMPLE+1))                          // stops overflow when done
      sample++;            // Increment the variable
#INT_TIMER0
void timer0_isr()
   if(TMR0IF == 1)
      delay_ms_flag++;   // increment variable
      seconds++;
      if(flag >= 500)      // for 500 ms
         flag_500ms = 0;
      if(flag >= 1000)   // for 1second
         flag = 0;      // reset variable to 0
         flag_500ms = 1;
      if(seconds >= 1000)      // every 1 second
         seconds = 0;
         SECONDS1++;         // Variables are incremented
      TMR0IF = 0;         // clear flag
      TMR0IE = 1;         // enable interrupt
      TMR0H = 0xC1;      // 1ms for 64Mhz
      TMR0L = 0x7F;
   TRISB = 0b01110000;
   PORTA = 0;      // configure PORTA as low
   PORTB = 0;      // configure PORTB as low
   PORTC = 0;
   setup_comparator (NC_NC_NC_NC);                 //   Disable comparator
   setup_ccp1(CCP_CAPTURE_RE);                     //   Looks for Rising edge
   setup_timer_1(T1_INTERNAL | T1_DIV_BY_1);       //   Timer1 internal & 1:1 Prescaler
   timer0_init();                                  //   Timer0 Initialization
   enable_interrupts(INT_CCP1);                   //   enables the CCP2 Interupt
   enable_interrupts(GLOBAL);                     //   Enables global interrupt
   T3CON = 0b10000110;                        //   16 bit, external clock input, TMR3 OFF
      TMR3H = 0;         // Values are reset to 0
      TMR3L = 0;
      TMR3ON = 1;         // Timer 3 ON
      delay_ms(10);      // 10 ms delay
      TMR3ON = 0;         // Timer 3 OFF
      tm3_Variable = TMR3H << 8 | TMR3L;      // Get the values
      if(tm3_Variable == 0)      // if the values are 0
         output_low(CAL_LED1);
         delay_ms(50);
         output_high(CAL_LED1);
         delay_ms(50);
         TMR3L = 0;
         output_low(LED1);
         read_capacitance();         //   Read the capacitance.
         disp_value = capacitance;
         if(flag_500ms == 0)
         else if(flag_500ms == 1)
   total_period = 0;                        // Ensure variables are reset
   sample = 0;                              //
   while (sample<(MAX_SAMPLE+1)){}                // waits here 'til done sampling
   frequency = (int32)((16000000*MAX_SAMPLE)/(total_period));      // calculates the frequency which is non-linear ,
   capacitance = 2467917.077/frequency;      // frequency converted to capacitance. to make it linear
   return capacitance;
void timer0_init()
   T0CON = 0b00001000;      // 16 bit, prescaler not assigned
   TMR0L = 0x7F;
   TMR0ON = 1;               // Timer1 ON
   TMR0IF = 0;               // set Timer1 Interrupt Flag as zero
   TMR0IE = 1;               // Set Timer1 Interrupt Enable = 1
PostPosted: Mon Jul 10, 2017 10:35 am     Reply with quote
Run a 1 Hz LED blink test. I suspect that your PIC is not really running
at 64 MHz. There may be other problems, but that one should be
checked first.
hemnath
PostPosted: Mon Jul 10, 2017 9:31 pm     Reply with quote
Thank you. I used the same code to test the LED blinking. By applying the frequency input, the main code goes into else statement where it has a blinking of LED for 500 ms. It is working.
PostPosted: Mon Jul 10, 2017 9:57 pm     Reply with quote
So is your whole program now working correctly, or is just the LED part
working ? Do you still have a problem ?
PostPosted: Tue Jul 11, 2017 6:52 am     Reply with quote
Some comments on just one routine:
#INT_TIMER0
void timer0_isr()
   if(TMR0IF == 1)
   //Pointless. Wasted instructions. The interrupt handler is only
   //called if the interrupt flag _is_ set....
      seconds++;
         flag_500ms = 0;
         flag_500ms = 1;
         seconds = 0;
      //Pointless. The compiler will always clear the flag for you
      //unless you specify for it not to...
      //Pointless. How can the code get here unless the interrupt
      //is already enabled....
      TMR0L = 0x7F;
      //These values should be loaded ASAP in the routine.
//So lets do the same routine using the compiler...
#define TIMER0_PRELOAD 0xC17F
#INT_TIMER0
void timer0_isr(void)
    set_timer0(TIMER0_PRELOAD); //set the timer
    seconds++;
        flag_500ms = 0;
       flag_500ms = 1;
       seconds = 0;
However 'think again'. Why not use timer2?.
Set this to use the /16 prescaler. Count to 250 (249 in PR2), and to interrupt every fourth time. Result, an accurate 1mSec interrupt.
setup_timer_2(T2_DIV_BY_16,249,4); //16MHz/(16*250*4) = 1000Hz
No need to load timer values etc..
Now another comment. The 32bit value being reset in the read routine "total_period=0". What happens if an interrupt occurs during this load?...
For any variable larger than 8bit, that is externally and is changed inside an interrupt, you need to disable interrupts during the load.
Now, like PCM_programmer, I'm surprised if your chip really is clocking correctly at 64MHz. A bit of a fluke. Use this syntax:
#use delay(INTERNAL = 64MHz)
#FUSES INTRC_IO
The 'internal' setting ensures the compiler sets up the PLL, and selects the 16MHz clock branch and PLL. Having the INTRC_IO fuse _after_ this, then ensures the IO pin is set correctly as well.
