Tom-H-PIC
Joined: 08 Sep 2003 Posts: 105 Location: New Castle, DE
| dsPIC33EP512GP506 WDT and Configuration Bit?? |
Posted: Wed Jun 14, 2017 7:59 am |
I'm working with the dsPIC33EP512GP506, CCS 5.072 and CCSLoad 5.42.
I'm really confused I thought I was in the know on how the WDT work but that is turning out to delusion! Ha
Ok so first things I'm using CCSLoad and a ICD-64U.
In the old CCSload software there was a way to read the configuration bits.
But now all I can find is the “File” tab and “Configuration/ID” ok so that shows the config on the left and the hex for the config bits on the right.
But I'm totally confused how I link the 1L,1H,2L,2H,etc to the address in the Microchip manual for this. (Table on page 380)
The information on the left side of the window is just wrong.
I also don’t see a way of read the bits to check them.
What am I missing?
So on the WDT I'm trying to set it to ~1s.
This is the config fuses I have set.
#use delay(clock=140MHz,crystal=16MHz)
//#use delay(clock=140MHz,crystal=16MHz,restart_wdt)
//#FUSES NOWINDIS //Watch Dog Timer in Window mode
#FUSES WPRES32 //Watch Dog Timer PreScalar 1:32
//#FUSES WPOSTS9 //Watch Dog Timer PostScalar 1:256 = 256ms
#FUSES WPOSTS11 //Watch Dog Timer PostScalar 1:1024 = 1s
#FUSES WDT //Watch Dog Timer
#FUSES CKSFSM //Clock Switching is enabled, fail Safe clock monitor is enabled
#FUSES NOJTAG //JTAG disabled
I have the following in my startup code.
setup_wdt(WDT_32MS);
setup_wdt(WDT_OFF);
Then below in other code I turn it on with the “WDT_ON”
So all of this is not giving me the 1s I think that it should.
The only way I can get anything to work at all is to set fuses “WPOSTS11” to” WPOSTS16”.
Would someone please explain how this WDT works to me?
Tom |
Posted: Wed Jun 14, 2017 9:07 am |
First thing is you need the fuse NOWDT!.....
On these chips, once you configure the watchdog with the fuses, this overrides the software control. So the setup_wdt functions can't turn off the watchdog if it is enabled in the fuses. This is Note2, on the RCON register in the data sheet.
So NOWDT.
Then in your code:
setup_wdt(WDT_1S);
setup_wdt(WDT_ON);
Remember if you are using the ICD, the watchdog will be turned off. Has to be for ICD operation.
'L' and 'H' are simply the high and low words of the 32bit configuration word. The easiest place to look is the end of the .lst file generated when you compile. This has the fuses both in 'word' form, and in text. So:
Configuration Fuses:
Word 1L: 365F WPOSTS16 WDT128 WINDIS NOWDT ICSP2 DEBUG NOWRT NOPROTECT NOJTAG
H: 0000
Word 2L: 9318 EC DISUVREG IOL1WAY OSCIO CKSFSM PR_PLL PLL2 IESO
H: 0000
Word 3L: FFFF WPFP WPDIS NOWPCFG WPEND
H: 0000
Word 4L: 0000
H: 0000
Tom-H-PIC
Posted: Wed Jun 14, 2017 11:14 am |
Thanks Ttelmah!
All working and have a better understanding.
Tom |
