TI CC1101
Goto page Previous  1, 2, 3  Next
Post new topic   Reply to topic    CCS Forum Index -> Code Library
lscantillo
Serial monitor
PostPosted: Thu May 25, 2017 8:51 pm     Reply with quote
guy wrote:
Did you start with the code I sent for TX & RX? Did it work?
Yes, it works.
RX code
#include <16F1827.h>
#include <stdio.h>
#include <stdlib.h>
#fuses INTRC_IO,XT,PUT,NOPROTECT,BROWNOUT,NOLVP,NOWDT,NOMCLR
//#fuses XT,PUT,NOPROTECT,BROWNOUT,NOLVP,NOWDT
#use delay(clock=8000000)   // internal 8MHz
#use rs232(baud=2400, xmit=PIN_B2, rcv=PIN_B5, PARITY=N, BITS=8, STOP=1, stream=PC) //B2 pin 8 pic; B5 pin 11 pic
#bit TXCKSEL = 0x11e.0
//Pin connections
#define   LED    PIN_B7    //pin 13 pic
#define   MOSI   PIN_B6    //pin 12 pic, pin 3 cc1101
#define   MISO   PIN_B4    //pin 10 pic,pin 5 cc1101
#define   SCK    PIN_B3    //pin 9 pic, pin 4 cc1101
#define   CS     PIN_B1    //pin 7 pic, pin 7 cc1101
#define   GDO2   PIN_A2    //pin 1 pic ,pin 6 cc1101
#define   GDO0   PIN_A3    //Output temperature GDO0 from CC1101 & input A/D channel 0 //pin 17 pic, pin 8 cc1101
#DEFINE   BUF_SIZE   100
byte txBuffer[BUF_SIZE];
byte rxBuffer[BUF_SIZE];
byte rxPacketLen=0;
#define WRITE_BURST     0x40
#define READ_SINGLE     0x80
#define READ_BURST      0xC0
// Defines
#define CRC_OK              0x80
#define RSSI                0
#define LQI                 1
#define BYTES_IN_RXFIFO     0x7F
// CCxxxx STROBE, CONTROL AND STATUS REGSITERS
#define CCxxx0_IOCFG2 0x00 // GDO2 output pin configuration
#define CCxxx0_IOCFG1 0x01 // GDO1 output pin configuration
#define CCxxx0_IOCFG0 0x02 // GDO0 output pin configuration
#define CCxxx0_FIFOTHR 0x03 // RX FIFO and TX FIFO thresholds
#define CCxxx0_SYNC1 0x04 // Sync word, high int8
#define CCxxx0_SYNC0 0x05 // Sync word, low int8
#define CCxxx0_PKTLEN 0x06 // Packet length
#define CCxxx0_PKTCTRL1 0x07 // Packet automation control
#define CCxxx0_PKTCTRL0 0x08 // Packet automation control
#define CCxxx0_ADDR 0x09 // Device address
#define CCxxx0_CHANNR 0x0A // Channel number
#define CCxxx0_FSCTRL1 0x0B // Frequency synthesizer control
#define CCxxx0_FSCTRL0 0x0C // Frequency synthesizer control
#define CCxxx0_FREQ2 0x0D // Frequency control word, high int8
#define CCxxx0_FREQ1 0x0E // Frequency control word, middle int8
#define CCxxx0_FREQ0 0x0F // Frequency control word, low int8
#define CCxxx0_MDMCFG4 0x10 // Modem configuration
#define CCxxx0_MDMCFG3 0x11 // Modem configuration
#define CCxxx0_MDMCFG2 0x12 // Modem configuration
#define CCxxx0_MDMCFG1 0x13 // Modem configuration
#define CCxxx0_MDMCFG0 0x14 // Modem configuration
#define CCxxx0_DEVIATN 0x15 // Modem deviation setting
#define CCxxx0_MCSM2 0x16 // Main Radio Control State Machine configuration
#define CCxxx0_MCSM1 0x17 // Main Radio Control State Machine configuration
#define CCxxx0_MCSM0 0x18 // Main Radio Control State Machine configuration
#define CCxxx0_FOCCFG 0x19 // Frequency Offset Compensation configuration
#define CCxxx0_BSCFG 0x1A // Bit Synchronization configuration
#define CCxxx0_AGCCTRL2 0x1B // AGC control
#define CCxxx0_AGCCTRL1 0x1C // AGC control
#define CCxxx0_AGCCTRL0 0x1D // AGC control
#define CCxxx0_WOREVT1 0x1E // High int8 Event 0 timeout
#define CCxxx0_WOREVT0 0x1F // Low int8 Event 0 timeout
#define CCxxx0_WORCTRL 0x20 // Wake On Radio control
#define CCxxx0_FREND1 0x21 // Front end RX configuration
#define CCxxx0_FREND0 0x22 // Front end TX configuration
#define CCxxx0_FSCAL3 0x23 // Frequency synthesizer calibration
#define CCxxx0_FSCAL2 0x24 // Frequency synthesizer calibration
#define CCxxx0_FSCAL1 0x25 // Frequency synthesizer calibration
#define CCxxx0_FSCAL0 0x26 // Frequency synthesizer calibration
#define CCxxx0_RCCTRL1 0x27 // RC oscillator configuration
#define CCxxx0_RCCTRL0 0x28 // RC oscillator configuration
#define CCxxx0_FSTEST 0x29 // Frequency synthesizer calibration control
#define CCxxx0_PTEST 0x2A // Production test
#define CCxxx0_AGCTEST 0x2B // AGC test
#define CCxxx0_TEST2 0x2C // Various test settings
#define CCxxx0_TEST1 0x2D // Various test settings
#define CCxxx0_TEST0 0x2E // Various test settings
// Strobe commands
#define CCxxx0_SRES 0x30 // Reset chip.
#define CCxxx0_SFSTXON 0x31 // Enable and calibrate frequency synthesizer (if MCSM0.FS_AUTOCAL = 1).
// If in RX / TX: Go to a wait state where only the synthesizer is
// Running (for quick RX / TX turnaround).
#define CCxxx0_SXOFF 0x32 // Turn off crystal oscillator.
#define CCxxx0_SCAL 0x33 // Calibrate frequency synthesizer and turn it off
// (Enables quick start).
#define CCxxx0_SRX 0x34 // Enable RX. Perform calibration first if coming from IDLE and
// MCSM0.FS_AUTOCAL = 1.
#define CCxxx0_STX 0x35 // In IDLE state: Enable TX. Perform calibration first if
// MCSM0.FS_AUTOCAL = 1. If in RX state and CCA is enabled:
// Only go to TX if channel is clear.
#define CCxxx0_SIDLE 0x36 // Exit RX / TX, turn off frequency synthesizer and exit
// Wake-On-Radio mode if applicable.
#define CCxxx0_SAFC 0x37 // Perform AFC adjustment of the frequency synthesizer
#define CCxxx0_SWOR 0x38 // Start automatic RX polling sequence (Wake-on-Radio)
#define CCxxx0_SPWD 0x39 // Enter power down mode when CSn goes high.
#define CCxxx0_SFRX 0x3A // Flush the RX FIFO buffer.
#define CCxxx0_SFTX 0x3B // Flush the TX FIFO buffer.
#define CCxxx0_SWORRST 0x3C // Reset real time clock.
#define CCxxx0_SNOP 0x3D // No operation. May be used to pad strobe commands to two
// int8s for simpler software.
#define CCxxx0_PARTNUM 0x30
#define CCxxx0_VERSION 0x31
#define CCxxx0_FREQEST 0x32
#define CCxxx0_LQI 0x33
#define CCxxx0_RSSI 0x34
#define CCxxx0_MARCSTATE 0x35
#define CCxxx0_WORTIME1 0x36
#define CCxxx0_WORTIME0 0x37
#define CCxxx0_PKTSTATUS 0x38
#define CCxxx0_VCO_VC_DAC 0x39
#define CCxxx0_TXBYTES 0x3A
#define CCxxx0_RXBYTES 0x3B
#define CCxxx0_PATABLE 0x3E
#define CCxxx0_TXFIFO 0x3F
#define CCxxx0_RXFIFO 0x3F
//Configure the CC1101 module by reading or writing to configuration
//register through SPI interface. SPI serial interface consists of four lines:
//MOSI: Master Output Slave Input (master write)
//MISO: Master Input Slave Output (master read)
//SCK: Serial clock signal, controlled by master
//CSN: chip select signal, low active
// <SPI write and read Code>
int8 SpiTxRxByte (int8 dat) {
   int8 i, temp;
   temp = 0;
   output_low(SCK);   //SCK = 0;
   for (i = 0; i <8; i ++) {
      if (dat & 0x80) output_high(MOSI);
      else output_low(MOSI);
      dat <<= 1;
      delay_us(1);
      output_high(SCK);
      temp <<= 1;
      if (input(MISO)) temp ++;
      delay_us(1);
      output_low(SCK);
   return temp;
// Configure the CC1101 module through the SPI interface, reading and writing
//into configuration register>
int8 halSpiReadReg (int8 addr) {
   int8 temp, value;
   temp = addr | READ_SINGLE; // read register command
   output_low(CS);
   while (input(MISO));
   SpiTxRxByte (temp);
   value = SpiTxRxByte (0);
   output_high(CS);
   return value;
//void halSpiWriteReg (int8 addr, int8 value)
void halRfWriteReg (int8 addr, int8 value) {
   output_low(CS);
   SpiTxRxByte (addr); // write address
   SpiTxRxByte (value); // write configuration
   output_high(CS);
void halSpiWriteBurstReg(BYTE addr, BYTE count) {
    INT8 i;
   output_low(CS);
    SpiTxRxByte(addr | WRITE_BURST);
    delay_us(10);
    for (i = 0; i < count; i++) {
      SpiTxRxByte(txBuffer[i]);
        //SPI_WAIT();
        delay_us(10);   //???
   output_high(CS);
void halSpiStrobe(BYTE strobe) {
   output_low(CS);
   SpiTxRxByte (strobe); // write address
   output_high(CS);
BYTE halSpiReadStatus(BYTE addr) {
    INT8 x;
   output_low(CS);
   SpiTxRxByte (addr|READ_BURST);
   // SPI_WAIT
   x=SpiTxRxByte (0);
   // SPI_WAIT
   output_high(CS);
    return x;
void halSpiReadBurstReg(BYTE addr, BYTE count) {
    INT8 i;
    byte x;
   output_low(CS);
//    SPI_WAIT();
   if(count>(BUF_SIZE-5)) count=BUF_SIZE-5;
       x=SpiTxRxByte (0);
        //SPI_WAIT();
        rxBuffer[i] = x;
   output_high(CS);
// Configure CC1101
void halRfWriteRfSettings (void) {
// Rf settings for CC1101
// export from SmartRF studio
// 433.92MHz 1.2Kbaud, 10dB
// GFSK, dev. 5KHz, RX filter BW 58KHz
   halRfWriteReg(CCxxx0_IOCFG2,0x06);  //GDO0 Output Pin Configuration
   halRfWriteReg(CCxxx0_FIFOTHR,0x47); //RX FIFO and TX FIFO Thresholds
   halRfWriteReg(CCxxx0_SYNC1,0x7A);   //Sync Word, High Byte
   halRfWriteReg(CCxxx0_SYNC0,0x0E);   //Sync Word, Low Byte
   halRfWriteReg(CCxxx0_PKTLEN,0x14);  //Packet Length
   halRfWriteReg(CCxxx0_PKTCTRL0,0x05);//Packet Automation Control
   halRfWriteReg(CCxxx0_FSCTRL1,0x06); //Frequency Synthesizer Control
   halRfWriteReg(CCxxx0_FREQ2,0x10);   //Frequency Control Word, High Byte
   halRfWriteReg(CCxxx0_FREQ1,0xB0);   //Frequency Control Word, Middle Byte
   halRfWriteReg(CCxxx0_FREQ0,0x73);   //Frequency Control Word, Low Byte
   halRfWriteReg(CCxxx0_MDMCFG4,0xF5); //Modem Configuration
   halRfWriteReg(CCxxx0_MDMCFG3,0x83); //Modem Configuration
   halRfWriteReg(CCxxx0_MDMCFG2,0x12); //Modem Configuration
   halRfWriteReg(CCxxx0_MDMCFG1,0x21); //Modem Configuration
   halRfWriteReg(CCxxx0_DEVIATN,0x15); //Modem Deviation Setting
   halRfWriteReg(CCxxx0_MCSM0,0x18);   //Main Radio Control State Machine Configuration
   halRfWriteReg(CCxxx0_FOCCFG,0x16);  //Frequency Offset Compensation Configuration
   halRfWriteReg(CCxxx0_AGCCTRL2,0x43);//AGC Control
   halRfWriteReg(CCxxx0_AGCCTRL1,0x49);//AGC Control
   halRfWriteReg(CCxxx0_WORCTRL,0xFB); //Wake On Radio Control
   halRfWriteReg(CCxxx0_FSCAL3,0xE9);  //Frequency Synthesizer Calibration
   halRfWriteReg(CCxxx0_FSCAL2,0x2A);  //Frequency Synthesizer Calibration
   halRfWriteReg(CCxxx0_FSCAL1,0x00);  //Frequency Synthesizer Calibration
   halRfWriteReg(CCxxx0_FSCAL0,0x1F);  //Frequency Synthesizer Calibration
   halRfWriteReg(CCxxx0_TEST2,0x81);   //Various Test Settings
   halRfWriteReg(CCxxx0_TEST1,0x35);   //Various Test Settings
   halRfWriteReg(CCxxx0_TEST0,0x09);   //Various Test Settings
   halRfWriteReg(CCxxx0_PATABLE,0xC0);   // 10dB
   //halRfWriteReg(CCxxx0_PATABLE,0x60);   // 0dB
void halRfSendPacket (int8 size) {
// put data in txBuffer
   halRfWriteReg (CCxxx0_TXFIFO, size);
      halSpiWriteBurstReg (CCxxx0_TXFIFO, size); // write the data to be sent
   halSpiStrobe (CCxxx0_STX); // send data into the transmit mode
   // Wait for GDO0 to be set -> sync transmitted
   while(!input(GDO2)) {
//      halSpiStrobe(CCxxx0_SNOP); possible
   // Wait for GDO0 to be cleared -> end of packet
   while(input(GDO2)) {
//      halSpiStrobe(CCxxx0_SNOP); interrupts
   halSpiStrobe (CCxxx0_SFTX);
int8 halRfReceivePacket () {
// before calling set rxPacketLen!
// data will be stored in rxBuffer and rxPacketLen changed accordingly
   INT8 status [2];
   INT8 packetLength;
   byte tmp0,tmp1;
   halSpiStrobe (CCxxx0_SRX); // entry into the receiving state
   while (! input(GDO2));
   while (input(GDO2));
   if ((halSpiReadStatus (CCxxx0_RXBYTES) & BYTES_IN_RXFIFO)) // If the pick is not 0 bytes
      packetLength = halSpiReadReg (CCxxx0_RXFIFO);
      if (packetLength <= rxPacketLen) {
         halSpiReadBurstReg (CCxxx0_RXFIFO, packetLength);
         rxPacketLen = packetLength; // receive data to modify the length of the current data
         // Read the 2 appended status bytes (status [0] = RSSI, status [1] = LQI)
         tmp0=rxBuffer[0];
         tmp1=rxBuffer[1];
         halSpiReadBurstReg (CCxxx0_RXFIFO, 2); // read CRC, bit
         halSpiStrobe (CCxxx0_SFRX); // receive buffer wash
         status[0]=rxBuffer[0];
         status[1]=rxBuffer[1];
         // restore rxBuffer data:
         rxBuffer[0]=tmp0;
         rxBuffer[1]=tmp1;
         return (status[1] & CRC_OK); // return successfully received if the verification is successful
         return 0;
   return 0;
   byte i,bp;
   char C[5];
   float temperatura=rxbuffer[i];
   float T= temperatura;
   TXCKSEL = 1;
   // issue manual POR sequence and SRES:
   restart_wdt();
    fputc(T,PC);
     output_toggle(PIN_B0);
     delay_ms(10);
     printf("El valor de temperatura es = \r \n ");
     printf(" \r \n ");
     fputs(T);
     printf(" \r \n ");
     sprintf(c,"%0.2f\n",T);
     fputs(c, PC);
   output_high(LED);
   delay_ms(400);
   output_low(LED);
   output_high(CS);
   output_high(SCK);
   output_low(MOSI);
   // strobe CS low/high
   delay_us(10);
   output_low(CS);
   delay_us(10);
   output_high(CS);
   output_low(SCK);   // MY
   delay_us(40);
   output_low(CS);
   delay_us(10);
    fputc(T,PC);
     delay_ms(10);
     printf(" \r \n ");
     fputs(T);
     printf(" \r \n ");
     fputs(c, PC);
   // wait for CHIP_RDYn :
   // SRES:
   delay_us(10);
   halSpiStrobe(CCxxx0_SRES);
   delay_ms(1);
   halRfWriteRfSettings();
   //i=halSpiReadReg(CCxxx0_FREQ0); for write-read test
   delay_ms(1);
// RX:
   restart_wdt();
   while(1) {
// if(input(GDO0)) {
   for(i=0;i<20;i++) {
   rxBuffer[i]=3;    }
   rxPacketLen=10;
   i=halRfReceivePacket();
   bp=1;
   char C[5];
   TXCKSEL = 1;
   delay_ms(10);
  //test
   ///rlgjsgs
     fputc(T,PC);
     delay_ms(10);
     printf(" \r \n ");
     fputs(T);
     printf(" \r \n ");
     fputs(c, PC);
   ///gkrsrgi
  //test
  // TXCKSEL = 0;
   for(i=0;i<10;i++) {
   if(rxBuffer[i]!=i+0x10){bp=0;}
   if(bp==1) {
   restart_wdt();
   output_high(LED);
   delay_ms(25);
   output_low(LED);
   delay_ms(5);
   output_high(LED);
   delay_ms(25);
   output_low(LED);
   delay_ms(5);
   output_high(LED);
   delay_ms(25);
   output_low(LED);
   delay_ms(5);} /*}*/
Hi, have a nice day,
I'm trying to display the rxbuffer to a serial monitor. I'm receiving the packets because rx leds turns On. I have a code only for display characters and numbers and it work fine. But i can't display anything to the RS232 and rx code together. I need to display the rxbuffer wiith pic-rs232 and a serial monitor.
This is the main code tha works fine (just displays preset values). Other parameters are the same, fuses, define...et all.
int i;
   double z=85.62;
   char b[5];
   TXCKSEL = 1;
     //start
   for(i=0;i<10;i++) {
   txBuffer[i]=i+0x10;}
  for(i=0;i<10;i++) {
  double a=txBuffer[i];
    //end
     fputc(a,PC);
     output_toggle(PIN_B3);
     delay_ms(10);
     fputc(z,PC);
     delay_ms(10);
     printf(" \r \n ");
     fputs(a);
     printf(" \r \n ");
     //if(a<99.00)
     sprintf(b,"%0.2f\n",a);
     fputs(b, PC);
     printf(" \r \n ");
     fputs(a);
     printf(" \r \n ");
     //if(a<99.00)
     sprintf(b,"%0.2f\n",z);
     fputs(b, PC);
guy
PostPosted: Sat May 27, 2017 3:16 pm     Reply with quote
Hi! I arranged the code a little bit for you - I took out the init code from the main() function. Here is TX & RX example:
void initCC1101() {
   restart_wdt();
   output_high(CS);
   output_high(SCK);
   output_low(MOSI);
   delay_us(10);
   output_low(CS);
   delay_us(10);
   output_high(CS);
   delay_us(40);
   output_low(CS);
   delay_us(10);
   // SRES:
   delay_us(10);
   delay_ms(1);
//   i=halSpiReadReg(CCxxx0_FREQ0); for write-read test
   delay_ms(1);
   byte i,bp;
   float f;
   initCC1101();
// TX:
   f=37.2;      // simulate temperature sensor // simular el sensor
   sprintf(txBuffer,"%0.2f",f);
   // txBuffer contains the characters // TxBuffer contiene los caracteres
   while(1) {
      output_high(LED);
      restart_wdt();
      halRfSendPacket(10);
      output_low(LED);
// RX:
   restart_wdt();
   while(1) {
      restart_wdt();
//      if(input(GDO0)) {   // unremark if you want to do more things in the main loop // Desmarca si quieres hacer mas cosas en el main loop
         rxPacketLen=10;
         // rxBuffer contains received temperature // RxBuffer contiene la temperatura recibida
         output_high(LED);
         delay_ms(50);
         output_low(LED);
         restart_wdt();
          fprintf(PC,"El valor de temperatura es = %s\r \n ",rxBuffer);
guy
PostPosted: Sat May 27, 2017 3:21 pm     Reply with quote
oh, one tip: The code contains lots of restart_wdt(); but if you enter halRfReceivePacket() without checking GDO0 first it will wait for a new packet without restarting the watchdog timer, which might trigger a reset.
The easiest is to disable the WDT completely.
lscantillo
Stop at HalfRFsendpacket //TX part
PostPosted: Mon May 29, 2017 9:51 am     Reply with quote
Hello friend, i tested your code, but in tx code stop at HalfRFsendpacket and i dont know why.
guy
PostPosted: Mon May 29, 2017 10:48 am     Reply with quote
halRfSendPacket() waits for GDO2 to go high (transmission starts), then low (transmission finished). Please check GDO2 with an oscilloscope or logic analyzer if this is happening.
lscantillo
It's working finally
PostPosted: Mon May 29, 2017 1:27 pm     Reply with quote
//Sensor Function
void LM335() {
byte i,bp;
setup_port_a( PIN_A0 );
setup_adc( ADC_CLOCK_INTERNAL );
set_adc_channel( 0 );
min=1024;
max=0;
for(i=0; i<=1; ++i) {
value_ADC = Read_ADC();
//if(value_ADC<min)
//min=value;
//if(value>max)
//max=value;
//printf("\n\rMin: %4LU Max: %4LU\n\r",min,max);
//sprintf(str,"%4lu",value_ADC);
//printf(str);
//Tx code the header and functions are the same
byte i,bp;
initCC1101();
while(1){
LM335();
//TX:
sprintf(txBuffer,"%4lu",value_ADC); // txBuffer contains the characters // TxBuffer contiene los caracteres
output_high(LED);
restart_wdt();
halRfSendpacket(10);
output_low(LED);
//restart_wdt();
//RX
byte i,bp;
initCC1101();
//RX:
restart_wdt();
while(1){
restart_wdt();
rxPacketLen=10;
i=halRfReceivePacket(); // rxBuffer contains received temperature // RxBuffer contiene la temperatura recibida
output_high(LED);
delay_ms(400);
output_low(LED);
restart_wdt();
sprintf(str,"%s\r\n",rxBuffer);
printf(str);
Thanks, for your help and time... I noticed some odd stuff, I nonticed that TX and RX have to be in synchrony to get a nueric value other wise I got random letters (Repeatedly) or black rxbuffer value.
How can I guarantee that the numbers are correct?
I'm thinking about an if condition until I read a number, so how can I do a softwware reset?
There are other ways to guarantee synchrony?
Thanks a lot again for your wisdom and time.
lscantillo
Re: It's working finally
PostPosted: Mon May 29, 2017 1:49 pm     Reply with quote
//Sensor Function
void LM335() {
byte i,bp;
min=1024;
max=0;
//if(value_ADC<min)
//min=value;
//if(value>max)
//max=value;
//printf(str);
byte i,bp;
initCC1101();
while(1){
LM335();
//TX:
output_high(LED);
restart_wdt();
output_low(LED);
//restart_wdt();
//RX
byte i,bp;
initCC1101();
//RX:
restart_wdt();
while(1){
restart_wdt();
rxPacketLen=10;
output_high(LED);
delay_ms(400);
output_low(LED);
restart_wdt();
printf(str);
¿how can I guarantee that the numbers are correct?
¿I'm thinking about an if condition until I read a number, so how can I do a softwware reset?
¿there are other ways to guarantee synchrony?
another question I forgot...
How can I add two more TX circuits, adding another buffer lie txBuffer1 and so on or should I add a header in the sending packet identifying the source ?
guy
PostPosted: Mon May 29, 2017 2:21 pm     Reply with quote
What do you mean 'in synchrony' ?
According to the code TX transmit every ~1 second, and RX waits for a new packet, blinks the LED for 400ms and then prints it.
Maybe you want to make the delay_ms(400) in RX shorter? so that it will receive better if TX has higher rate?
guy
PostPosted: Mon May 29, 2017 2:26 pm     Reply with quote
The default for the CC1101 is that all transmitters work in Broadcast and all receivers pick all transmitters. If this is good for you don't make any changes, just build another identical transmitter. Each transmitter can add a different ID to the data so the receiver will display for example:
TX1 36.4
TX3 35.8
TX2 35.3
guy
PostPosted: Mon May 29, 2017 2:30 pm     Reply with quote
PS. you can substitute
printf(str);
with
printf("%s\r\n",rxBuffer);
this is what printf is for...
lscantillo
PostPosted: Mon May 29, 2017 3:07 pm     Reply with quote
Ok, I should lower the (400ms) delay, because sometimes I can get the buffer for example I got, "#%%%FGHJ... repeat and I got to restart (Hardware).
guy
PostPosted: Mon May 29, 2017 3:11 pm     Reply with quote
the code could use some improvements...
lscantillo
PostPosted: Mon May 29, 2017 3:12 pm     Reply with quote
printf(str);
with
Yes I know sir, but I need to do an app of the Network so I thought that would be easier to name the packet. How can I add the id to the other transceivers? Like the example you said:
TX1 36.4
TX3 35.8
TX2 35.3
guy
PostPosted: Tue May 30, 2017 12:59 am     Reply with quote
For transmitter #1 change your code to
sprintf(txBuffer,"TX1 %4lu",value_ADC);
Ffor transmitter #2 change your code to
sprintf(txBuffer,"TX2 %4lu",value_ADC);
etc.
vmetal2020
Re: TI CC1101
PostPosted: Sat Apr 25, 2020 3:14 am     Reply with quote
Hi! Thank you for sharing. I try to run your code with 18f25k20 but it stops in the while(!input(GDO2)):
void halRfSendPacket (int8 size) { // put data in txBuffer
   halSpiStrobe (CCxxx0_STX);// send data into the transmit mode
   //halSpiStrobe(CCxxx0_SNOP); possible
   } // Wait for GDO0 to be cleared -> end of packet
   //halSpiStrobe(CCxxx0_SNOP); interrupts
What I write wrong?
attached all code.
#include <pruebaccs_sensorpuerta.h>
//#fuses MCLR,WDT512,NOPROTECT,INTRC_IO,BROWNOUT
//#fuses PUT,NOLVP
//#use delay(clock=8000000)   // internal 8MHz
#define   LED      PIN_A3
// manual/software SPI
#define MOSI   PIN_C5
#define   MISO   PIN_C4
#define   SCK      PIN_C3
#define   GDO2   PIN_B0// unused
#define   CS      PIN_A5
#define   GDO0   PIN_B1
/*//Registers
#byte lcd=0x00D //PORTB
#byte TRIS_lcd=0x08D  //TRISB
#bit rs=0x00C.2 //PORTA A2
#bit en=0x00C.3 //PORTA A3
#bit TRIS_rs=0x08C.2
#bit TRIS_en=0x08C.3*/
byte rxPacketLen=0;
// Defines
#define CRC_OK              0x80
#define RSSI                0
#define LQI                 1
// Strobe commands
//Variables
long int adc_value,real_value;
int i;
char value[4];
float adj = 2.048;
int adj2 = 1;
char Trs[4];
//SPI write and read Code
   int8 i, temp;
   temp = 0;
   output_low(SCK);   //SCK = 0; if SCK=1 data tx cancelled
   for (i = 0; i <8; i ++) { //burst mode
      dat <<= 1;
      delay_us(1);
      output_high(SCK);
      temp <<= 1;
      delay_us(1);
      output_low(SCK); }
   return temp; }
   int8 temp, value;
   output_low(CS);
   SpiTxRxByte (temp);
   output_high(CS);
   return value; }
   output_low(CS);
   output_high(CS); }
   INT8 i;
   output_low(CS);
   delay_us(10);
   delay_us(10); }
   output_high(CS);}
   output_low(CS);
   SpiTxRxByte (strobe); //write address
   output_high(CS); }
   INT8 x;
   output_low(CS);
   x=SpiTxRxByte (0);
   output_high(CS);
   return x; }
   INT8 i;
   byte x;
   output_low(CS);
   x=SpiTxRxByte (0);
   rxBuffer[i] = x; }
   output_high(CS); }
// Configure CC1101
   halRfWriteReg(CCxxx0_PATABLE,0x84);   // 10dB
   //output_low(PIN_A2);
   /*// Wait for GDO0 to be set -> sync transmitted
   delay_ms(1000);//Lo he puesto para suprimir lo de arriba
   INT8 status [2];
   INT8 packetLength;
   byte tmp0,tmp1;
   { packetLength = halSpiReadReg (CCxxx0_RXFIFO);
   tmp0=rxBuffer[0];
   tmp1=rxBuffer[1];
   rxBuffer[0]=tmp0;
   rxBuffer[1]=tmp1;
   } else {
   return 0;
   } } else
   return 0;}
output_high(PIN_A2);
output_high(LED);
   //Temperature();
   byte i; // issue manual POR sequence and SRES:
   restart_wdt();
   output_high(LED);
   delay_ms(400);
  // output_low(LED);
   output_high(CS);
   output_high(SCK);
   output_low(MOSI); // strobe CS low/high
   delay_us(10);
   output_low(CS);
   delay_us(10);
   output_high(CS);
   output_low(SCK);
   delay_us(40);
   output_low(CS);
   delay_us(10); // wait for CHIP_RDYn :
   while (input(MISO)); // SRES:   //se bloque aqui ver el porque
   delay_us(10);
   delay_ms(1);
   halRfWriteRfSettings(); //i=halSpiReadReg(CCxxx0_FREQ0); for write-read test
   delay_ms(1);
// TX:
   //for(i=0;i<10;i++) {
   //txBuffer[i]=i+0x10;}
   //while(1) {
   //delay_ms(1000);
  // halRfSendPacket(10);
   //restart_wdt();}}
   for(i=0;i<10;i++) {
   while(1) {
            output_low(LED);
           // output_high(PIN_A2);
            delay_ms(2000);
            //output_high(LED);
           // output_low(PIN_A2);
            delay_ms(2000);
           // restart_wdt();
.h
#include <18F25K20.h>
#device ADC=10
#use delay(internal=16MHz)
#use FIXED_IO( A_outputs=PIN_A3,PIN_A2 )
//#use FIXED_IO( A_outputs=PIN_A5 )
//#use FIXED_IO( C_outputs=PIN_C5,PIN_C3 )
#define Ledrojo   PIN_A2
//#define Ledverde   PIN_A3
//Se activan cuando están en LOW
Thank you
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
Page 2 of 3
