pwm phase shift
ledman1
pwm phase shift
PostPosted: Tue Apr 25, 2017 2:21 am     Reply with quote
Hi..I'm a begginer in c and ccs. How to phase shift pwm wave ? I'm using pic16f877a.
Thank you
PostPosted: Tue Apr 25, 2017 4:38 am     Reply with quote
your question is too vague.
PWM is easy.....
'phase shift'... of you mean the output (PWM signal) is to be some time from the original start signal, simply
'look for ' start signl'
delay 'sometime'
send PWM to I/O pin
BTW the 877 is almost obsolete, so you should choose a more modern PIC. You'll find lots of them cheaper with MORE features !
Jay
ledman1
PostPosted: Tue Apr 25, 2017 5:31 am     Reply with quote
PWM is easy.....
delay 'sometime'
send PWM to I/O pin
Jay
i have 20 khz pwm signal and i want use this signal on other pin with 120 degree phase shift
ledman1
PostPosted: Tue Apr 25, 2017 6:26 am     Reply with quote
Jay
whats your offer?
PostPosted: Tue Apr 25, 2017 7:37 am     Reply with quote
rough math...
20KHz = 50us
1/3=16.6us
... idea.
read input pin level ( 20KHz signal)
delay 16us
write 1 to output pin
the idea is the outpit pin 'follows' the input pin ,though delayed.
with some real code you'll have to account for actual code times(depends on PIC and speed..)
there is another hardware trick (really old school) where you start with 6x the clock signal, run into counter and get 3 phases exactly 120* apart.
as more which PIC.. the 16F887 I believe is an upgrade, currently I use the 18F46K22 as my 'goto' PIC. 40 pins, 2 HW UARTS, lots of mem,etc.
Jay
PostPosted: Tue Apr 25, 2017 11:43 am     Reply with quote
You would normally never phase shift the PWM. What you would phase shift is the waveform being synthesised _by_ the PWM.
So you have perhaps an xxHz, sinusoid (or another waveform, but a sinusoid is the commonest), synthesised using modulated PWM, and you then generate another waveform at a phase shift from this.
Look on the Microchip site. They give a lot of examples of this. Most are fairly easy to port.
You just use a lookup table for the values to feed to the PWM controller, with values for a cycle, and output the value at a pointer to PWM#1, and at 1/3rd the way further through the table for PWM#2.
ledman1
PostPosted: Tue Apr 25, 2017 1:45 pm     Reply with quote
temtronic wrote:
rough math...
Jay
Is there any way except capture pwm pin there?
ledman1
PostPosted: Tue Apr 25, 2017 1:52 pm     Reply with quote
I create this table:
#define Step_delay 1000 //micro second
const int pwmSin[] = {127, 138, 149, 160, 170, 181, 191, 200, 209, 217, 224, 231, 237, 242, 246, 250, 252, 254, 254, 254, 252, 250, 246, 242, 237, 231, 224, 217, 209, 200, 191, 181, 170, 160, 149, 138, 127, 116, 105, 94, 84, 73, 64, 54, 45, 37, 30, 23, 17, 12, 8, 4, 2, 0, 0, 0, 2, 4, 8, 12, 17, 23, 30, 37, 45, 54, 64, 73, 84, 94, 105, 116 };
and create sine wave with this method:
       set_pwm_duty(1,pwmsin[PWM]);
       PWM++;
       delay_us(Step_delay);
       if (pwm>71){pwm=0;}
and its work very well...now my focus is on phase shift method.
PostPosted: Wed Apr 26, 2017 12:29 am     Reply with quote
OK.
Beware of your 'mixed case'. If PWM is upper case, it should always be upper case. This will catch you later if you are not careful....
There is also a 'standard' in C to reserve declarations in all upper case, for macros etc.. It makes debugging easier.
#define STEP_DELAY 1000 //micro second
        //obviously the second PWM will need setting up somewhere.
       int8 PWMvalue2; //in your declarations
       int8 PWMvalue1; //using this instead of just PWM
       //then for the loop:
       PWMvalue2=PWMvalue1+24;
       if (PWMvalue2>71)
           PWMvalue2-=72;
       set_pwm_duty(1,pwmsin[PWMvalue1]);
       set_pwm_duty(2,pwmsin[(PWMvalue2]);
       PWMvalue1++;
       if (PWMvalue1>71)
           PWMvalue1=0;
       delay_us(STEP_DELAY);
To give a really accurate time, you might want to consider using a timer, instead of just the delay. This then means the timings won't be upset by time used for the maths and array lookup. Depends how accurate your frequency needs to be, and what else the code must do.
ledman1
PostPosted: Wed Apr 26, 2017 6:21 am     Reply with quote
Ttelmah wrote:
OK.
       if (PWMvalue2>71)
           PWMvalue2-=72;
       PWMvalue1++;
       if (PWMvalue1>71)
           PWMvalue1=0;
I did not understand, but I try to get noticed...thank you
