Operations with bits
cvargcal
PostPosted: Fri Apr 14, 2017 8:11 am     Reply with quote
Hi, I have this problem, I read the 8 bits from a port:
var=A7 A6 A5 A4 A3 A2 A1 A0
I want get this A0 A1 A2 A3 A4 A5 A6 A7
and after, 0 0 0 0 A0 A1 A2 A3
so, the result is invert and move.
I know its possible with
temp = input_a();
if (bit_test(temp,0)) bit_set(var,7)
but, this take on many time, and this steep running at the interruption ext
someone idea? thanks
PostPosted: Fri Apr 14, 2017 9:39 am     Reply with quote
Code library post comparing several methods of bit reversal:
http://www.ccsinfo.com/forum/viewtopic.php?t=23364
Followup comments:
http://www.ccsinfo.com/forum/viewtopic.php?t=42151
Note that FvM's method requires a RAM array of 256 bytes. It's the
Purdick method, but in RAM instead of in ROM. You need a PIC with
enough RAM to use this method.
cvargcal
PostPosted: Fri Apr 14, 2017 10:42 am     Reply with quote
Followup comments:
thanks
I use this, but I see is similar
 DTMF_CMD = 0x0;
   Temp = input_b();
   if (bit_test(Temp,1)) bit_set(DTMF_CMD,3);  // Leer bit 1 (B1) de Temp y guardar en el bit 3 DTMF_CMD   3---
   if (bit_test(Temp,2)) bit_set(DTMF_CMD,2);  // Leer bit 2 (B2) de Temp y guardar en el bit 2 DTMF_CMD   -2--
   if (bit_test(Temp,3)) bit_set(DTMF_CMD,1);  // Leer bit 3 (B3) de Temp y guardar en el bit 1 DTMF_CMD   --1-
   if (bit_test(Temp,4)) bit_set(DTMF_CMD,0);  // Leer bit 4 (B4) de Temp y guardar en el bit 0 DTMF_CMD   ---0
But this take many time Sad
Its similar to:
int8 reverse( int8 backwards )
  int8 result=0;
  int8 x;
  x = 8;
  do
    if (bit_test(backwards,7))
      bit_set(result,0);
     rotate_left( &backwards,1);
     rotate_right( &result, 1);
  } while (--x);
  return result;
Well, I thought this was more easy... jejeje
PostPosted: Fri Apr 14, 2017 11:11 am     Reply with quote
the version like this:
 DTMF_CMD = 0x0;
   Temp = input_b();
Will execute much faster.
You need to look at the actual execution time, rather than the code size.
The 'looped' version gives a very similar size, but takes several times as long to execute....
PostPosted: Fri Apr 14, 2017 1:40 pm     Reply with quote
OK, a possible hardware solution...
Since I see 'DTMF', is it possible to rewire the peripherals attached to the PIC to get the bits 'right way round'??
Jay
newguy
PostPosted: Fri Apr 14, 2017 1:56 pm     Reply with quote
Jay
I was going to suggest the same thing. If this is such an issue, it may be worth a revised PCB.
cvargcal
PostPosted: Fri Apr 14, 2017 9:46 pm     Reply with quote
Jay
Yes, the better option is fixed the PCB... :( I no wanted do... but read the bits this way is not good.
PostPosted: Fri Apr 14, 2017 11:44 pm     Reply with quote
A lot also depends on what chip is involved.
The fastest solution is the 256 entry lookup table already mentioned.
Now on any of the larger chips this is not a terrible cost, and honestly in an interrupt handler is probably the only solution to consider.....
