Stream Switching - (SOLVED)
Gabriel
PostPosted: Mon Mar 20, 2017 6:20 pm     Reply with quote
Hi All,
I have an application where i am using WiFi and a GPRS backup connection.
In a particularly remote scenario I'm faced with, there is no WiFi available so I figured i would just throw in a second GPRS modem each using a different service provider for redundancy. The internet must be available always.
I have developed a driver for a particular modem, of which i have over 20 deployed throughout my city since 2015... it works.
In this case both modems would be identical except for the SIM... i don't feel like loading 2 copies of the same driver is "efficient" if the only hardware difference is the TX/RX pins they are connected to.
Is there a way to simply tell the driver to use a different stream? or am I limited to using a Flag to control which fprintf statement to use on each of the different functions?... this would suck.
Or change which stream corresponds to what UART?
I would like to simply flip a bit and the same single driver now operates on a different UART.
G.
CCS PCM 5.078 & CCS PCH 5.093
PostPosted: Mon Mar 20, 2017 8:17 pm     Reply with quote
This topic was discussed in the following thread:
Use STREAM 'type' as function parameter.
http://www.ccsinfo.com/forum/viewtopic.php?t=55473
You will need a flag, but not on every printf statement. Ttelmah provides
a more global solution.
Gabriel
PostPosted: Tue Mar 21, 2017 6:24 am     Reply with quote
PCM, thank you!
Ttelmah...creative code as always!
G.
