Buzzer Routine Help
rrb011270
Buzzer Routine Help
PostPosted: Mon Dec 22, 2003 7:28 pm     Reply with quote
Mabuhay!
My buzzer routine below:
output_high(BUZZER);
delay_ms(200);
output_low(BUZZER);
delay_ms(450);
Is there another way such that I can use interrupt driven o reduce the instruction cycle of this routine?
My application is an RF reader which use an #int_ext2 to capture the ID from the badge. When it is successfull a buzzer will sound for success.
most of my code use the interrupt handler routine like the clock which use the #int_timer0 such it will capture the time and date and added to a complete packet of data which are compose of date, time, RFid, etc...
Any help will do?
Tenkyu
Mark
PostPosted: Mon Dec 22, 2003 8:05 pm     Reply with quote
In the previous post, you were bit banging the output.
http://www.ccsinfo.com/forum/viewtopic.php?t=17853
Are you saying now that you only need to output for a duration?
rrb011270
PostPosted: Tue Dec 23, 2003 12:24 am     Reply with quote
Yes would output for a duration only? Need Help?
Mark
PostPosted: Tue Dec 23, 2003 8:01 am     Reply with quote
I like to use timer2 as a 1ms tick. Most of my software timers are based in milliseconds.
#include <18F452.h>              // Target PIC Microcontroller IC
#device  *=16                    // use a 16-bit pointer
#device ICD=TRUE
#fuses HS,NOPROTECT,NOLVP,NOWDT        // PIC MCU Configuration
#use delay(clock=20000000)       // 20MHz Crystal clock speed
// Configure PortA4 for buzzer output
#bit BUZZER=0xF80.4
int Buzzer_Timer = 0;
#int_timer2
void tick(void)
  if (Buzzer_Timer)
    Buzzer_Timer--;
     if (!Buzzer_Timer)
void Beep(void)
  Buzzer_Timer = 200;
  output_low(BUZZER);
main()
  // Setup timer2 for 1ms intervals
  setup_timer_2(T2_DIV_BY_4,250,5);
  enable_interrupts(int_timer2);
  enable_interrupts(global);
  Beep();
  while (1) ;
rrb011270
PostPosted: Sun Dec 28, 2003 6:56 pm     Reply with quote
This is what I did for timer2:
#fuses HS,NOPROTECT,NOWDT        // PIC MCU Configuration
#define BUZZER PIN_A4            // buzzer to PortA4
#int_timer2
timer2_isr()
   if (glBuzzerFlag)    // check if buzzer flag bit enable
      if (buzzcnt >= 11)
         output_high(BUZZER);       // buzzer turn-off
         glBuzzerFlag = 0;          // reset flag bit
      buzzcnt++;
   if (glBuzzerError)   // check if buzzer error flag bit enable
      if ((buzzcnt >=11) && (buzzcnt < 21))
         output_high(BUZZER);       // turn-off buzzer for ~130msec.
      if ((buzzcnt >= 21) && (buzzcnt < 31))
         output_low(BUZZER);        // turn-on buzzer for ~130msec.
      if (buzzcnt >= 31)
         glBuzzerError = 0;         // reset flag bit
      buzzcnt++;
void buzzSound()        // buzzer sounder routine
   output_low(BUZZER);  // turn ON buzzer
   buzzcnt = 0;         // set buzzer time in 100mS per count
void init_chip() {   // Initialize the MCU Chip
   setup_adc_ports(NO_ANALOGS);
   setup_timer_2(T2_DIV_BY_16,0xFF,16);   // 6.56mS interupt interval
   enable_interrupts(int_timer2);   // Enable timer2 interrupt
   enable_interrupts(GLOBAL);     // Enable Global interrupt
Thank u for the help...
