Watchdog timer on PIC24F
Vern Hardingham
PostPosted: Fri Jan 27, 2017 2:32 pm     Reply with quote
I have:
#fuses WPOSTS4, NOWINDIS, NOWDT, ICSP1, NODEBUG, NOWRT, NOPROTECT, NOJTAG
#fuses HS, DISUVREG, NOIOL1WAY, OSCI0, NOCKSFSM, PR, PLL3, NOIESO
#use delay(crystal =12M, clock=32M, USB_FULL)
setup_wdt(WDT_512MS);
   restart_wdt();
   delay_us(1);
When I compile and run, the processor just keeps resetting.
Can someone help me with this?
PostPosted: Fri Jan 27, 2017 3:08 pm     Reply with quote
Some more basic info needed:
What actual processor?.
What compiler version?.
Show the basic 'main' containing the code.
Vern Hardingham
PostPosted: Fri Jan 27, 2017 5:01 pm     Reply with quote
The processor is PIC24FJ256GB106
Compiler is CCS PCD IDE v 5.067
   extern GeneratorStates curState;
   initialize();
   GATE = OFF;
   TXKEY = OFF;
   PWRCTL = ON;
   init_SPI();
   ad9833Reset();
   init_UART();
   displayInit();
   displayClear();
   delay_ms(1);//without delay here first line does not indent properly
   displayCurOff();
   displayStartup();
   delay_ms(144);
   usbstate = USB_INST;
   TRISC = 0b10010000;
   CS_DAC = 1;
   CS_MEM = 1;
   SPI_SCK = 1;
   delay_ms(1000); // hold startup screen for 1 second
   displayClrLn(3);
   displaySetcurpos(3, 4);
   printf(displayWrite, "Calibrating");
   DACcal();
   DACunbufsetlvl2(0x00);
   reset_FLASH();
   unlock_FLASH();
   beep(100);
   pwrTmr = PWRTIMEOUT;
   SECONDS_TMR = ON;
   curState = GEN_STARTUP_DISPLAY;
// Enable Watchdog timer here
   while (TRUE)
   // Reset the watchdog timer here
      restart_wdt();
      delay_us(1);
//      StateMachine_Update();
PostPosted: Fri Jan 27, 2017 5:32 pm     Reply with quote
Also, are you running this with an ICD in Debug mode ?
jeremiah
PostPosted: Fri Jan 27, 2017 9:03 pm     Reply with quote
Replace #FUSES NOWINDIS with #FUSES WINDIS
Otherwise, just about every time you call the WDT reset, you will reset the PIC. NOWINDIS enables windowed mode for the WDT. You normally don't want that.
PostPosted: Sat Jan 28, 2017 1:42 am     Reply with quote
As a comment:
TRISC = 0b10010000;
You are aware that the registers on a PIC24, are 16bit wide, not 8bit?.
Vern Hardingham
PostPosted: Mon Jan 30, 2017 11:50 am     Reply with quote
Thanks Jeremiah, changing to WINDIS got it working. I guess I was thinking that NOWINDIS meant no windowing but actually means no windowing disable whereas WINDIS means disable windowing.
Also thanks Ttelmah, I'll look into the TRISC. I guess I must only be using the low 8 bits otherwise this would cause problems. Where I want to access just 8 bits of TRISB I have defined TRISBH and TRISBL as the 8 bit portions of the register.
