Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
Temperature sensor and display with PIC16F690
Post new topic   Reply to topic    CCS Forum Index -> Code Library
Arakel
View user's profile Send private message Visit poster's website AIM Address
PostPosted: Sat Dec 03, 2016 5:42 am     Reply with quote
I thank to: Ttelmah, temtronic !
The program starts a heater(LED) if the value of a potentiometer is higher than the value of a sensor. It shows from -20 to 50 degrees Centigrade temperature on a 7segment display. If the temperature is in minus degrees a second "Minus_LED" is started to indicate that the display shows minus degrees.
Theoretically it can show from -50 to 59 but I do not think the electronics will survive!
//A program to scan the values of an ADC and potentiometer and start a heater if they are different with the debouncing routine
//The difference is that the minus degrees on the display are with a different coding realization
#include <16F690.h>
#device ADC=10
#fuses NOMCLR, NOWDT, NOPROTECT, INTRC_IO
#use delay(clock=4M)
#define Minus_LED PIN_B5
   /**********Initiasization*************/
   int i,z;     //Local variables
   unsigned int16 ADC_10bit_Sensor;
   unsigned int16 ADC_10bit_Potentiometer;
   unsigned int16 OutputDigit;  //This digit is only used to be put inside FinalFormOfThePORTCOutput so we know which element number of the array to use
   unsigned int8 FinalFormOfThePORTCOutput[80] =
      0b00000000, // 0
      0b00000001,
      0b00000010,
      0b00000011,
      0b00000100,
      0b00000101,
      0b00000110,
      0b00000111,
      0b00001000,
      0b00001001,
      0b00010000, // 10
      0b00010001,
      0b00010010,
      0b00010011,
      0b00010100,
      0b00010101,
      0b00010110,
      0b00010111,
      0b00011000,
      0b00011001,
      0b00100000, // 20
      0b00100001,
      0b00100010,
      0b00100011,
      0b00100100,
      0b00100101,
      0b00100110,
      0b00100111,
      0b00101000,
      0b00101001,
      0b00110000, // 30
      0b00110001,
      0b00110010,
      0b00110011,
      0b00110100,
      0b00110101,
      0b00110110,
      0b00110111,
      0b00111000,
      0b00111001,
      0b01000000, // 40
      0b01000001,
      0b01000010,
      0b01000011,
      0b01000100,
      0b01000101,
      0b01000110,
      0b01000111,
      0b01001000,
      0b01001001,
      0b01010000, // 50
      0b01010001,
      0b01010010,
      0b01010011,
      0b01010100,
      0b01010101,
      0b01010110,
      0b01010111,
      0b01011000,
      0b01011001,
   setup_comparator(NC_NC_NC_NC); //We disable the comparators so we can use the PINs
   setup_adc_ports( sAN0 | sAN1 );   //Adc functions
   setup_adc( ADC_CLOCK_DIV_16 );
    /**********We set and read from the ADC channels, meaning from the potentiometer and sensor*************/
   set_adc_channel( 0 );   //We set the ADC to read from CHANNEL 0 (Where the potentiometer is connected)
   for(i=0; i<15; i++)
      delay_ms(1);         //The ADC is 10 bit so we have "2 to Grade 10" values, meaning 1024
      ADC_10bit_Potentiometer = read_adc(); //So for 5 volts we have: 5/1024 = 0.0048828125 Volts per ADC tick!
         if(ADC_10bit_Potentiometer != ADC_10bit_Potentiometer)// Meaning that for an ADC value of 600 we have: 600 x 0.0048828125 Volts
            i=0;
   set_adc_channel( 1 );   //We set the ADC to read from CHANNEL 1 (Where the sensor is connected)
   for (i=0; i<15; i++)
      delay_ms(1);
      ADC_10bit_Sensor = read_adc();
      if (ADC_10bit_Sensor != ADC_10bit_Sensor)
         i=0;
         if (ADC_10bit_Sensor <= ADC_10bit_Potentiometer)    //If the sensor is lower than the potentiometer turn ON the heater
          delay_ms(1);
          output_b(0b00010000);
       } else {                                        //If the sensor is higher than the potentiometer turn OFF the heater
         output_b(0b00000000);
         if (ADC_10bit_Sensor >= 578) //578 from the ADC equals zero degrees("2.82276"Volts). This "if statement" is only for the positive degrees plus the zero
         OutputDigit = ((ADC_10bit_Sensor*0.0048828125) - 2.82276)/ 0.01163;
         output_c(FinalFormOfThePORTCOutput[OutputDigit]);
      if (ADC_10bit_Sensor < 578)     //This "if statement" is only for the negative degrees(under "2.82276"Volts)
      {   //When we get a positive result we use the same "FinalFormOfThePORTCOutput" table but we start a LED( "Minus_LED") to indicate its minus degrees
         OutputDigit = ((ADC_10bit_Sensor*0.0048828125) - 2.82276)/ (-0.01163); //We divide by "-0.01163" in order to get a positive result because "minus/minus = plus"
         delay_ms(1);
         output_high(Minus_LED);    //If the ADC for the Sensor is under 578 we have minus degrees so we output "high" the "Minus_LED".
         delay_ms(1);
 }//Close while
Yo! I love learning and technology! I just do not have experience so do not be angry if I ask a stupid question about a detail! From so much to remember sometimes I forget the details in order to remember the big problems!
asmboy
PostPosted: Mon Dec 05, 2016 5:14 pm     Reply with quote
why or why are you using those floats with a
10 bit integer ADC reading ??
you are losing vast numbers of cpu cycles
and code space to the floating point math .
OMG what a slow poke program
Arakel
PostPosted: Mon Dec 05, 2016 5:19 pm     Reply with quote
It works perfect! Plus I need the float math in order to do the accuracy so I can get 1 degree difference!
I do not have float variables only constants, it should not be a problem for the coding and the processor is fast enough.
If you can give me another way to make the accuracy, I am listening?
After all I am learning here and miracles will not happen with the first program. After 20 years I might be able to do it perfect but not yet!
I welcome all critiques! The more I learn the better!
Gabriel
PostPosted: Wed Dec 07, 2016 6:13 am     Reply with quote
35.56 float vs. 3556 int.
Ask yourself: What is the accuracy diference?
G.
CCS PCM 4.135 & CCS PCH 5.013
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
