PIC12F675+PCF8574+LCD 16x2+ RTC DS1307
Goto page 1, 2, 3  Next
mahatia
PostPosted: Tue Nov 15, 2016 2:41 am     Reply with quote
Hello everybody! Is someone could help me to display date and time from RTC DS1307 on LCD ? I have to use PIC12F675 and my LCD is connected with PCF8574! What should I do! I have already used the code that someone has posted here to display something on lcd by using PCF8574 and PIC12F675 and its works, but now, I have to display time and date, what should I do?
Mike Walne
PostPosted: Tue Nov 15, 2016 3:15 am     Reply with quote
Work out what you want to put on the display, then write your own code.
Mike
mahatia
PostPosted: Tue Nov 15, 2016 4:13 am     Reply with quote
Ok! This is my schematic capture from Proteus.
[https://drive.google.com/file/d/0BwhZ3_I-f9gham9iMExDUjBNbHc/view?usp=sharing]
and this is my code:
[https://drive.google.com/drive/folders/0BwhZ3_I-f9ghUGFpY3kzeGQyd1k?usp=sharing]
Thank you.
PostPosted: Tue Nov 15, 2016 5:57 am     Reply with quote
Well I'd use the 'search' feature of this forum and find the DS1307 'driver'. There's 2 or 3 ... 2 for sure, I know they both work though I modified one for my use. If the Ext_int pin of the 12F675 is available, I'd connect the DS1307 to it and use an ISR to display the date/time information. I use the 1Hz interrupt from the 1307 this way.
Jay
Mike Walne
PostPosted: Tue Nov 15, 2016 6:25 am     Reply with quote
Your link expects me to create or sign in to an account.
I'm not going to do it.
Mike
mahatia
PostPosted: Tue Nov 15, 2016 10:11 am     Reply with quote
I'm so sorry, I'll post it here soon,thanks
mahatia
PostPosted: Tue Nov 15, 2016 1:11 pm     Reply with quote
these are my code, i saw them in this forum and I want to add an RTC ds1307.
I2C_LCD.c
#include <12F675.h>
#device *= 16
#fuses NOWDT, PROTECT, CPD, NOMCLR, INTRC_IO, BROWNOUT, PUT
#use delay (internal = 4MHz)
#include "lcd.c"
void setup();
   unsigned char i = 0;
    char txt1[] = {"RAMANANTSOA"};
   char txt2[] = {"Projet 2"};
    //char txt[6];
    setup();
        LCD_clear_home();
       for(i = 0; i <= 10; i++)
           LCD_goto((i), 0);
           LCD_putchar(txt1[i]);
           delay_ms(99);
       for(i = 0; i <= 9; i++)
           LCD_goto((i), 1);
           LCD_putchar(txt2[i]);
          // delay_ms(99);
void setup()
    disable_interrupts(GLOBAL);
    setup_ADC(ADC_off);
    setup_ADC_ports(no_analogs);
    setup_timer_0(T0_internal);
    setup_timer_1(T1_disabled);
    set_timer0(0);
    set_timer1(0);
    LCD_init();
lcd.c
#include "lcd.h"
void LCD_init()
    unsigned char t = 0x1A;
    data_value = 0x08;
    PCF8574_write(data_value);
    while(t > 0x00)
            delay_ms(dly);
            t--;
    data_value = 0x30;
    data_value |= 0x08;
    delay_ms(dly);
    data_value &= 0xF7;
    delay_ms(dly);
    data_value = 0x30;
    data_value |= 0x08;
    delay_ms(dly);
    data_value &= 0xF7;
    delay_ms(dly);
    data_value = 0x30;
    data_value |= 0x08;
    delay_ms(dly);
    data_value &= 0xF7;
    delay_ms(dly);
    data_value = 0x20;
    data_value |= 0x08;
    delay_ms(dly);
    data_value &= 0xF7;
    delay_ms(dly);
    LCD_command(_4_pin_interface | _2_row_display | _5x7_dots);
    LCD_command(display_on | cursor_off | blink_off);
    LCD_command(clear_display);
    LCD_command(cursor_direction_inc | display_no_shift);
void LCD_command(unsigned char value)
    data_value &= 0xFB;
    LCD_4bit_send(value);
void LCD_send_data(unsigned char value)
    data_value |= 0x04;
void LCD_4bit_send(unsigned char lcd_data)
    unsigned char temp = 0x00;
    temp = (lcd_data & 0xF0);
    data_value &= 0x0F;
    data_value |= temp;
    data_value |= 0x08;
    delay_ms(dly);
    data_value &= 0xF7;
    delay_ms(dly);
    temp = (lcd_data & 0x0F);
    temp <<= 0x04;
    data_value &= 0x0F;
    data_value |= temp;
    data_value |= 0x08;
    delay_ms(dly);
    data_value &= 0xF7;
    delay_ms(dly);
void LCD_putstr(char *lcd_string)
    while (*lcd_string != '\0')
        LCD_send_data(*lcd_string);
        lcd_string++;
void LCD_putchar(char char_data)
    LCD_send_data(char_data);
void LCD_clear_home()
    LCD_command(goto_home);
void LCD_goto(unsigned char x_pos,unsigned char y_pos)
    if(y_pos == 0)
        LCD_command(0x80 | x_pos);
        LCD_command(0x80 | 0x40 | x_pos);
lcd.h
#include "PCF8574.c"
#define clear_display                           0x01
#define goto_home                               0x02
#define cursor_direction_inc                    (0x04 | 0x02)
#define cursor_direction_dec                    (0x04 | 0x00)
#define display_shift                           (0x04 | 0x01)
#define display_no_shift                        (0x04 | 0x00)
#define display_on                              (0x08 | 0x04)
#define display_off                             (0x08 | 0x02)
#define cursor_on                               (0x08 | 0x02)
#define cursor_off                              (0x08 | 0x00)
#define blink_on                                (0x08 | 0x01)
#define blink_off                               (0x08 | 0x00)
#define _8_pin_interface                        (0x20 | 0x10)
#define _4_pin_interface                        (0x20 | 0x00)
#define _2_row_display                          (0x20 | 0x08)
#define _1_row_display                          (0x20 | 0x00)
#define _5x10_dots                              (0x20 | 0x40)
#define _5x7_dots                               (0x20 | 0x00)
#define dly                                     0x01
unsigned char data_value = 0x00;
void LCD_init();
void LCD_command(unsigned char value);
void LCD_send_data(unsigned char value);
void LCD_4bit_send(unsigned char lcd_data);
void LCD_putstr(char *lcd_string);
void LCD_putchar(char char_data);
void LCD_clear_home();
void LCD_goto(unsigned char x_pos, unsigned char y_pos);
PCF8574.c
#include "PCF8574.h"
unsigned char PCF8574_read()
    unsigned char port_byte = 0;
    i2c_start();
    i2c_write(PCF8574_read_cmd);
    port_byte = i2c_read(0);
    i2c_stop();
    return port_byte;
void PCF8574_write(unsigned char data_byte)
    i2c_start();
    i2c_write(PCF8574_write_cmd);
    i2c_write(data_byte);
    i2c_stop();
PCF8574
#define PCF8574_address       0x40
#define PCF8574_write_cmd      PCF8574_address
#define PCF8574_read_cmd      (PCF8574_address + 1)
#define SDA_pin               pin_A5
#define SCL_pin                 pin_A4
#use I2C(Master, SDA = SDA_pin, SCL = SCL_pin)
unsigned char PCF8574_read();
void PCF8574_write(unsigned char data_byte);
I use PIC12F675, what should I do if I want to display date and time from RTC?
I found this driver in this forum but I get many errors when I use it with my code
DS1307.c
#define RTC_SDA  pin_A5
#define RTC_SCL  pin_A4
#use i2c(master, sda=RTC_SDA, scl=RTC_SCL)
BYTE bin2bcd(BYTE binary_value);
BYTE bcd2bin(BYTE bcd_value);
void ds1307_init(void)
   BYTE seconds = 0;
   i2c_start();
   i2c_write(0xD0);      // WR to RTC
   i2c_write(0x00);      // REG 0
   i2c_start();
   i2c_write(0xD1);      // RD from RTC
   seconds = bcd2bin(i2c_read(0)); // Read current "seconds" in DS1307
   i2c_stop();
   seconds &= 0x7F;
   delay_us(3);
   i2c_start();
   i2c_write(bin2bcd(seconds));     // Start oscillator with current "seconds value
   i2c_start();
   i2c_write(0x07);      // Control Register
   i2c_write(0x10);     // Disable squarewave output pin
   i2c_stop();
void ds1307_set_date_time(BYTE day, BYTE mth, BYTE year, BYTE dow, BYTE hr, BYTE min, BYTE sec)
  sec &= 0x7F;
  hr &= 0x3F;
  i2c_start();
  i2c_write(0xD0);            // I2C write address
  delay_us(1);
  i2c_write(0x00);            // Start at REG 0 - Seconds
  i2c_write(bin2bcd(sec));      // REG 0
  i2c_write(bin2bcd(min));      // REG 1
  i2c_write(bin2bcd(hr));      // REG 2
  i2c_write(bin2bcd(dow));      // REG 3
  i2c_write(bin2bcd(day));      // REG 4
  i2c_write(bin2bcd(mth));      // REG 5
  i2c_write(bin2bcd(year));      // REG 6
  //i2c_write(0x80);            // REG 7 - Disable squarewave output pin
  i2c_write(0x10);
  i2c_stop();
void ds1307_get_date(BYTE &day, BYTE &mth, BYTE &year, BYTE &dow)
  i2c_start();
  i2c_write(0xD0);
  delay_us(1);
  i2c_write(0x03);            // Start at REG 3 - Day of week
  i2c_start();
  i2c_write(0xD1);
  dow  = bcd2bin(i2c_read() & 0x7f);   // REG 3
  day  = bcd2bin(i2c_read() & 0x3f);   // REG 4
  mth  = bcd2bin(i2c_read() & 0x1f);   // REG 5
  year = bcd2bin(i2c_read(0));            // REG 6
  i2c_stop();
void ds1307_get_time(BYTE &hr, BYTE &min, BYTE &sec)
  i2c_start();
  i2c_write(0xD0);
  i2c_start();
  i2c_write(0xD1);
  sec = bcd2bin(i2c_read() & 0x7f);
  min = bcd2bin(i2c_read() & 0x7f);
  hr  = bcd2bin(i2c_read(0) & 0x3f);
  i2c_stop();
  BYTE temp;
  BYTE retval;
  temp = binary_value;
  retval = 0;
  //while(1) IO NO TEO
    // Get the tens digit by doing multiple subtraction
    // of 10 from the binary value.
    if(temp >= 10)
      temp -= 10;
      retval += 0x10;
    else // Get the ones digit by adding the remainder.
      retval += temp;
  return(retval);
// Input range - 00 to 99.
  BYTE temp;
  temp = bcd_value;
  // Shifting upper digit right by 1 is same as multiplying by 8.
  temp >>= 1;
  // Isolate the bits for the upper digit.
  temp &= 0x78;
  // Now return: (Tens * 8) + (Tens * 2) + Ones
  return(temp + (temp >> 2) + (bcd_value & 0x0f));
DS1307.h
#ifndef __DS1307_H
#define __DS1307_H
// Define DS1307 i2c device address
#define Device_Address_DS1307_EEPROM   0xD0
// Define Time Modes
#define AM_Time               0
#define PM_Time               1
#define TwentyFourHoursMode      2
// Define days
#define Monday      1
#define Tuesday      2
#define Wednesday   3
#define Thursday   4
#define Friday      5
#define Saturday   6
#define Sunday      7
// Function Declarations
void Write_Byte_To_DS1307_RTC(unsigned char, unsigned char);
unsigned char Read_Byte_From_DS1307_RTC(unsigned char);
void Write_Bytes_To_DS1307_RTC(unsigned char,unsigned char*,unsigned char);
void Read_Bytes_From_DS1307_RTC(unsigned char,unsigned char*,unsigned int);
void Set_DS1307_RTC_Time(unsigned char,unsigned char,unsigned char,unsigned char);
unsigned char* Get_DS1307_RTC_Time(void);
void Set_DS1307_RTC_Date(unsigned char,unsigned char,unsigned char,unsigned char);
unsigned char* Get_DS1307_RTC_Date(void);
#endif
Thank you!
PostPosted: Tue Nov 15, 2016 2:12 pm     Reply with quote
This block of code will display the date and time from the ds1307 on an lcd:
ds1307_get_date(day,month,yr,dow);  // Read date
ds1307_get_time(hrs,min,sec);    // Read Time
lcd_gotoxy(1,1);
printf(lcd_Putc,"\%02d/\%02d/\%02d",day,month,yr); // Display date
lcd_gotoxy(1,2);
printf(lcd_Putc," %02d:\%02d:\%02d", hrs,min,sec); // Display time
mahatia
PostPosted: Tue Nov 15, 2016 5:18 pm     Reply with quote
Thank you for helping me; I have tried the code, I do it like that
I2C_LCD.c
#include "DS1307.c"
#include <12F675.h>
#device *= 16
#include "lcd.c"
void setup();
    //char txt[6];
    setup();
        LCD_clear_home();
           LCD_goto((i), 0);
           delay_ms(99);
           LCD_goto((i), 1);
          // delay_ms(99);
    ds1307_init();
   lcd_goto(1,1);
   printf(lcd_putchar,"\%02d/\%02d/\%02d",day,month,yr); // Display date
   lcd_goto(1,2);
   printf(lcd_putchar," %02d:\%02d:\%02d", hrs,min,sec); // Display time
void setup()
    setup_ADC(ADC_off);
    set_timer0(0);
    set_timer1(0);
    LCD_init();
DS1307.c
   BYTE seconds = 0;
   i2c_start();
   i2c_start();
   i2c_stop();
   seconds &= 0x7F;
   delay_us(3);
   i2c_start();
   i2c_start();
   i2c_stop();
  sec &= 0x7F;
  hr &= 0x3F;
  i2c_start();
  delay_us(1);
  i2c_write(0x10);
  i2c_stop();
  i2c_start();
  i2c_write(0xD0);
  delay_us(1);
  i2c_start();
  i2c_write(0xD1);
  i2c_stop();
  i2c_start();
  i2c_write(0xD0);
  i2c_start();
  i2c_write(0xD1);
  i2c_stop();
  BYTE temp;
  BYTE retval;
  retval = 0;
    if(temp >= 10)
      temp -= 10;
      retval += 0x10;
      retval += temp;
  return(retval);
  BYTE temp;
  temp = bcd_value;
  temp >>= 1;
  temp &= 0x78;
And after compiling, he asked me to put #DEVICE before this line
thank you! I am losed Crying or Very sad Crying or Very sad
jeremiah
PostPosted: Wed Nov 16, 2016 7:58 am     Reply with quote
Your program's first include MUST always be the the chip's header file. In your posted code it is not. General order:
Chip include file
#device statments
#fuses
#use delay() setup
other #use or includes
remaining code.
mahatia
PostPosted: Wed Nov 16, 2016 9:19 am     Reply with quote
ok! let me try it! thank you very much for the idea!
mahatia
PostPosted: Wed Nov 16, 2016 3:02 pm     Reply with quote
I have done what you suggest me to do:
I2C_LCD.c
#include <12F675.h>
#device *= 16
#include "lcd.c"
#include "DS1307.c"
 void setup();
    char txt1[] = {"hello"};
         byte day;
        byte mth;
        byte year;
        byte dow;
        byte hr;
        byte min;
        byte sec;
    setup();
        LCD_clear_home();
           LCD_goto((i), 0);
           delay_ms(99);
           LCD_goto((i), 1);
           delay_ms(99);
    ds1307_init();
   ds1307_get_date(day,mth,year,dow);  // Read date
   ds1307_get_time(hr,min,sec);    // Read Time
   LCD_goto(1,1);
   printf(LCD_putchar,"\%02d/\%02d/\%02d",day,mth,year); // Display date
   LCD_goto(1,2);
   printf(LCD_putchar," %02d:\%02d:\%02d",hr,min,sec); // Display time
 void setup()
    setup_ADC(ADC_off);
    set_timer0(0);
    set_timer1(0);
    LCD_init();
After running and building, they send me this error message: Functions may not be nested. He underlines in red the void setup(); and void main() and setup();
I have tried to solve the problem but I couldn't find it! I am a beginner in CCS, could you help me for the last time please?
PostPosted: Wed Nov 16, 2016 4:59 pm     Reply with quote
Look at this function at the end of ds1307.c
You left off the ending brace on that function. You left off this:
mahatia
PostPosted: Mon Nov 21, 2016 10:32 am     Reply with quote
thank you PCM programmer. I have tried the code and it works! But could tell me why the seconds takes a long time to increments when I simulate it with proteus? this is my code:
I2C_LCD.c
#include <12F675.h>
#device *= 16
#include "lcd.c"
#include "DS1307.c"
 void setup();
 byte day;
        byte mth;
        byte year;
        byte hr;
        byte min;
        byte sec;
    setup();
    ds1307_init();
   ds1307_get_date(day,mth,year);  // Read date
   LCD_goto(0,0);
   LCD_goto(0,1);
   printf(LCD_putchar,"\%02d/\%02d/20\%02d",day,mth,year); // Display date
 void setup()
    setup_ADC(ADC_off);
    set_timer0(0);
    set_timer1(0);
    LCD_init();
lcd.c
#include "lcd.h"
void LCD_init()
data_value = 0x30;
 data_value = 0x20;
    data_value |= 0x08;
    delay_ms(dly);
    data_value &= 0xF7;
    delay_ms(dly);
    data_value &= 0xFB;
    data_value |= 0x04;
    data_value &= 0x0F;
    data_value |= temp;
    data_value |= 0x08;
    delay_ms(dly);
    data_value &= 0xF7;
    delay_ms(dly);
    temp <<= 0x04;
    data_value &= 0x0F;
    data_value |= temp;
     data_value |= 0x08;
    delay_ms(dly);
    data_value &= 0xF7;
    delay_ms(dly);
//void LCD_putstr(char *lcd_string)
   // while (*lcd_string != '\0')
       // LCD_send_data(*lcd_string);
       // lcd_string++;
    if(y_pos == 0)
lcd.h
#define dly                                     0x01
void LCD_init();
PCF8574.c
    i2c_start();
    i2c_stop();
    return port_byte;
    i2c_start();
    i2c_stop();
PCF8574.h
#define PCF8574_address       0x40 //A2, A1, A0, vers la masse
DS1307.C
#include <DS1307.h>
byte bin2bcd(byte binary_value);
byte bcd2bin(byte bcd_value);
 output_float(RTC_SCL);
   output_float(RTC_SDA);
void ds1307_get_date(byte &day, byte &mth, byte &year)
  i2c_start();
  i2c_write(0xD0);
  delay_us(1);
  i2c_write(0x04);            // Start at REG 3 - Day of week
  i2c_start();
  i2c_write(0xD1);
 // dow  = bcd2bin(i2c_read(1) & 0x7f);   // REG 3
  day  = bcd2bin(i2c_read(1) & 0x3f);   // REG 4
  mth  = bcd2bin(i2c_read(1) & 0x1f);   // REG 5
  i2c_stop();
void ds1307_get_time(byte &hr, byte &min, byte &sec)
  i2c_start();
  i2c_write(0xD0);
  i2c_start();
  i2c_write(0xD1);
  sec = bcd2bin(i2c_read(1) & 0x7f);
  min = bcd2bin(i2c_read(1) & 0x7f);
  i2c_stop();
  byte temp;
  byte retval;
  retval = 0;
    if(temp >= 10)
      temp -= 10;
      retval += 0x10;
      retval += temp;
  return(retval);
  byte temp;
  temp = bcd_value;
  temp >>= 1;
  temp &= 0x78;
DS1307.h
#ifndef __DS1307_H
#define __DS1307_H
#endif
Any help is appreciated! thank you!
And what should I do if I want to add some push button connected to the PIC to adjust time and date?
mahatia
PostPosted: Mon Nov 21, 2016 10:38 am     Reply with quote
Crying or Very sad Crying or Very sad Crying or Very sad Rolling Eyes
Page 1 of 3
