pass-by-pointer not changing values
shson
PostPosted: Fri Nov 11, 2016 1:56 am     Reply with quote
I was writing a code for circular buffer to be used for handling incoming data packets on hardware UART on PIC18F25K80. The actual buffer seems to work perfectly, except buffer overflows randomly. After debugging, I found that the FIFO_Init() function does not initialise the variables to zero, but rather arbitary values like 253 etc.
Edit* I'm using CCS v5.064
#define UINT8 unsigned int8
#define FIFO_SIZE 128
typedef struct
   UINT8 Start;
   UINT8 End;
   volatile UINT8 NbBytes;   /* number of bytes stored in the FIFO, this count is increased by INT_RDA interrupt */
   UINT8 Buffer[FIFO_SIZE];
} TFIFO;
TFIFO RxFIFO;
void FIFO_Init(TFIFO *FIFO)
   FIFO->Start   = 0;
   FIFO->End     = 0;
   FIFO->NbBytes = 0;
   /* If I printf("%u", FIFO->NbBytes), it outputs '0', which is correct but */
   FIFO_Init(&RxFIFO);
   printf("%u", RxFIFO->NbBytes);
   /* if I print here, the value of NbBytes is non-zero value */
I would've thought passing a pointer to a function using '&' operator and using '*' to update the variable would work. But apparently, the variables aren't getting initialised.
Any ideas?
Thank you
Eric
PostPosted: Fri Nov 11, 2016 2:10 am     Reply with quote
In your main, you need to be printing RxFIFO.NbBytes. At this point RxFIFO is not a pointer.....
PostPosted: Fri Nov 11, 2016 2:24 am     Reply with quote
Here is a test program to explore this.
#include <18F25K80.h>
#fuses INTRC_IO,NOWDT,PUT,BROWNOUT
#use delay(clock=4M)
typedef struct
   UINT8 Start;
   UINT8 End;
} TFIFO;
TFIFO RxFIFO;
   FIFO->Start   = 0x01;
   FIFO->End     = 0x02;
   FIFO->NbBytes = 0x03;
int8 temp;
FIFO_Init(&RxFIFO);
temp = RxFIFO->NbBytes;  // Your method
printf("RxFIFO->NbBytes = %x \r", temp);
// Two better methods:
temp = &RxFIFO->NbBytes;
printf("&RxFIFO->NbBytes = %x \r", temp);
temp = RxFIFO.NbBytes;
printf("RxFIFO.NbBytes = %x \r", temp);
while(TRUE);
PostPosted: Fri Nov 11, 2016 3:48 am     Reply with quote
and (of course) going on from here, the actual problem in your original code is almost certainly that at some point you are getting this selection wrong, so something then talks to the wrong variable....
