SHT3x i2c code using 16F877A
Spezi
PostPosted: Wed Nov 02, 2016 7:09 am     Reply with quote
Hello, I need your help! In a former project I used SHT2x with a 16F877, but now I would like to change to SHT3x. Does anybody have a code running with SHT3x?
RF_Developer
PostPosted: Wed Nov 02, 2016 7:14 am     Reply with quote
As you have successfully used the SHT2, I'd think you were one of the best placed to write code for the SHT3. Indeed, I'd hope you, or someone like you, would be the one to answer this question rather than ask it. It can't be all that different from the SHT2, can it?
We don't usually supply code for people. We help people to write their own code.
PostPosted: Wed Nov 02, 2016 8:47 am     Reply with quote
It's really, really help if you posted a link to the device !
Googled 'sht3' and came up with lots of interesting stuff but nothing jumps out as a peripheral device...
Jay
ezflyr
PostPosted: Wed Nov 02, 2016 10:24 am     Reply with quote
Here is what the OP is apparently referring to: https://www.sensirion.com/en/products/humidity-sensors/digital-humidity-sensors-for-various-applications/
John
If it's worth doing, it's worth doing in real hardware!
PostPosted: Wed Nov 02, 2016 10:37 am     Reply with quote
Gee, humidity sensor seems easy enough to code. The datasheet is well laid out, probably very similar to the dash2 version ?
The good thing is it's 5v so no nasty interface to 877, simple wiring !
The obvious place to start is to see if PCM P's I2C scanner program sees it. After that maybe see if the dash2 driver is similar enough to work or modify as required?
Without real parts to test, I'm not willing to cut code.
Jay
