curt2go
| Gyros, Accelerometers and quaternions |
Posted: Wed Oct 12, 2016 12:53 pm |
I have been beating my head against the wall for 2 weeks now. I am using a LSM6DS1 ACC and Gyro. I am getting proper readings from them and I am using a complimentary filter to put them together. I'm using a 24EP256GP206 running at 140MHz as well. BUT my filteredAngleZ keeps zeroing out. But I don't think that is my fundamental issue with the calculations.
I do have the option of adding a Mag sensor as well if I need to in the future. But I don't think I need it for what I am doing.
My project is to sense bat position and calculate swings. I have been reading on quaternions ALOT and think this is the way to go. I am struggling with the math on a few things.
Pitch, roll and Yaw. I have been using ATAN2 calculations and I am getting the proper x,y but z is not right.
I have been trying to go from Euler to quaternions but something is not right. I have used a simulator to track the x,y and if I don't use Z then those coordinates are right but obviously that does not really give me 3d space.
I am adding the gyro info every 0.01 seconds for the math.
My tau is 0.5.
Any help would be totally awesome.
| Code: | float cFilter(float newAngle, float newRate,float filteredAngle) {
float dtC = 0.010;//float(20)/1000.0;
a=tau/(tau+dtC);
filteredAngle = a* (filteredAngle + newRate * dtC) + (1-a) * (newAngle);
return filteredAngle;
//I do this in a timer every 0.01 seconds. Its very precise.
filteredAngleY = cFilter(roll,y_gyro,filteredAngleY);
filteredAngleX = cFilter(pitch,x_gyro,filteredAngleX);
//if(pitch < 1)//need to have something to multiply to...
// yaw = 1;
//if(yaw < 1)//need to have something to multiply to...
// yaw = 1;
filteredAngleZ = cFilter(yaw,z_gyro,filteredAngleZ);
roll,pitch and yaw calcs.
float Ax2ed = Ax*Ax;
float Ay2ed = Ay*Ay;
float Az2ed = Az*Az;
squareRootThis = sqrt((Az2ed) + (Ay2ed));
roll = (atan2(squareRootThis,Ax)) * 57.29;
squareRootThis = sqrt((Ax2ed) + (Az2ed));
pitch = (atan2(Ay,squareRootThis)) * 57.29;
yaw = (atan2(Az,squareRootThis)) * 57.29;
//tried this one as well //yaw =( atan2(Ay,Az) * 57.29);//radians to degrees
//the above notation of Az last in the Atan was taken from AN-1057 alalog devices. |
curt2go
Posted: Wed Oct 12, 2016 12:55 pm |
| I should add that I do have the quaternion calculations and I can verify that they work by substituting known numbers into them. |
Joined: 01 Jul 2010 Posts: 9651 Location: Greensville,Ontario
Posted: Wed Oct 12, 2016 2:44 pm |
OK, I don't use that 'fancy math' but ...probably stating the obvious....
hmm....
| Quote: | | Pitch , roll and Yaw. I have been using ATAN2 calculations and I am getting the proper x,y but z is not right. |
If Z is not right, do what needs to be done to get it right, as there is NO valid reason to proceed until X, Y AND Z are correct.
I don't have that sensor but read the datasheet (several times sometimes helps..), errata notes, Google for that device, app notes, etc. Remember you're NOT the first one using that device, scan the net for it.
Maybe your sensor has a bad Z axis ? It's one reason I buy as Noah did, 2 at a time.
No amount of 'fancy' math will solve a bad sensor output!
Jay |
curt2go
Posted: Wed Oct 12, 2016 3:21 pm |
I do agree with you on all fronts. I have done separate Accelerometer x,y,z measurements and all come out correct. I also do gyro x,y and z readings and they all come out. It is definitely working.
Does someone know the for sure Yaw ATAN2 calculation?
The trigonometry on this project is killing me.
But lets say I do end up with the correct roll. pitch and ,yaw. And then turn those into quaternions then multiply that by a new quaternion. What the heck does the output give me. As I read it , the output is the difference between the 2. So does that give me how far x has moved , y has moved and then z has moved? This is also where my visualisation is breaking down for this stuff.
I will do some tests again and show the results. I will add that my gyro is PIN 1 at the bottom left not at top left like datasheet. There is a gyro offset byte that can be set. I have done that. That also makes my roll, on the x axis and pitch on the y axis. z stays the same.
http://www.st.com/content/ccc/resource/technical/document/datasheet/group0/38/96/79/af/ab/62/42/c3/DM00229854/files/DM00229854.pdf/jcr:content/translations/en.DM00229854.pdf
page 17 shows the axis of rotation and the acc readings.
I have set it up with 010 for gyro readings.
pitch = Y roll = X yaw = Z
Orient [2:0] 000 001 010 011 100 101
Pitch X X Y Y Z Z
Roll Y Z X Z X Y
Yaw Z Y Z X Y X |
curt2go
Posted: Wed Oct 12, 2016 4:56 pm |
Here is the raw data form the XL.
X,Y,Z format.
Flat, Back.
0,0,1
90 to the right.
1,0,0
Flat front
0,0,-1
90 to the left
-1,0,0
Straight up
0,1,0
Straight down
0,-1,0
XL facing up but board down at 45
0,-0.7,0.7
XL facing up but board up at 45
0,0.7,0.7
90 to right and up at 45
0.7,0.7,0
90 to right and up and back at 45
-0.7,0.7,0
Here is the raw Gyro data.
I will rotate it on each axis..
X,Y,Z
Tilt up
-moves,0,0 (- moves means it moved in negative direction)
Tilt down
+moves,0,0
Roll right
0,+moves,0
Roll left
0,-moves,0
Yaw right
0,0,-moves
Yaw left
0,0,+moves.
I really hope someone can help.. It seems my hardware is working properly. |
curt2go
Posted: Wed Oct 12, 2016 8:47 pm |
Well it looks like I have accomplished something. I have made my euler angles work. I had a dumb issue with not using a float on my integration of the rate. Very dumb mistake!
Also I have found that my rotation is YZX not XYZ.
Now I have to translate all this into a swing and I thought the best way to do that is to convert to quaternions. Then take a sample every .2 seconds and multiply that quaternions by the last one and that should give me the difference. BUT the difference of what?
I will try on the simulator once I start outputting quaternions and see what I can come up with. But if anyone can help me with my next move it would be a great help. Thank you. |
