Communication between LabView and CCS.
Aayush13
PostPosted: Fri Aug 12, 2016 9:42 am     Reply with quote
Hey guys, I am trying to get a floating point number from labview to calculate power. However, my program in labview only accepts chars and strings. Here is my code in CCS so far:
   float V, P;
      V = 25;
      char res[50];
      float P = (V * V)/(getc());
      ftoa(P, res, 1)
      puts(res);
If I enter, for example, } for the resistor value I get the correct answer. But if I were to put 125 instead then I do not get the correct answer. Can anyone help me on this? Thanks!
PostPosted: Fri Aug 12, 2016 10:45 am     Reply with quote
Basic C. Get a textbook!...
You need to read a sequence of characters, decode these to a number, and then do the maths.
gets, rather than getc, and then look at atof and it's other derivatives.
Aayush13
PostPosted: Fri Aug 12, 2016 12:17 pm     Reply with quote
I am new to C which is why I have trouble figuring this out haha
