PIC16F877 to PIC18F4550 code migration
beaker404
PostPosted: Tue Aug 09, 2016 1:56 pm     Reply with quote
Any gotchas on this topic? I have code that runs fine on 16F877, moving to 18F4550 for more ram for improvements. I have stripped the code down to looping and sending a serial stream to hyperterminal. Scope shows waveform for sending, hyperterminal displays nothing. PCB works with '877 programmed with old code, so I think the hardware is ok. changed the crystal from 4MHZ to 20MHZ and 15pf caps for the '4550. I am set for 9600 8 N 1.
Code snippet of start of code:
main loop consists of a continuous while loop using fprintf. No interrupts are being enabled at this time, stripped all that out.
* INCLUDES and CONTROLLER SETTINGS
#include <18f4550.h>
#DEVICE ADC=10
#include <stdlib.h>
//#fuses XT,NOWDT,NOPROTECT,NOLVP
#FUSES HS,NOWDT,NOPROTECT,PUT,NOBROWNOUT,NOLVP,NODEBUG
#use rs232(baud=9600,xmit=PIN_C6, rcv=PIN_C7,stream=USB_SERIAL,ERRORS)
#use rs232(baud=4800,xmit=pin_b1,rcv=pin_b0,stream=CTRL)   // serial comm w/ down hole power module.
*  DEFINES
#DEFINE INTS_PER_SEC 15
#DEFINE TICKER_CLICKS 1
#DEFINE U_D_CNTRL      PIN_C0
#DEFINE INC_CNTRL      PIN_B6
#DEFINE CS_CNTRL       PIN_B5
#DEFINE A_CNTRL        PIN_B4
#DEFINE B_CNTRL        PIN_B3
#DEFINE PWR_CNTRL      PIN_B2
#DEFINE I_SENSE        PIN_A0
#DEFINE POT_DELAY      1                    // one ms delay
#DEFINE S_LENGTH 15
#DEFINE M_LENGTH 25
#DEFINE L_LENGTH 40
#DEFINE ALARM_ZERO     PIN_B7              // alarm zero control
#USE FAST_IO(C)
PostPosted: Tue Aug 09, 2016 2:12 pm     Reply with quote
Are you intending to use USB?. The fact your are calling the serial 'USB_SERIAL', suggests this. If so, the clock needs a lot more setting up:
#FUSES HS, NOWDT, NOPROTECT, PUT, NOBROWNOUT, NOLVP, NODEBUG
#FUSES PLL5, CPUDIV1, NOPBADEN, VREGEN
This says to setup the USB to run from the oscillator/5 (it requires 4MHz), and to run the CPU directly from the crystal. It also says to wake with PORT B setup for digital.
Currently your CPU will probably be running at 5MHz (the default CPUDIV fuse is /4), so the serials will be running at 1/4 the clock rate they should be. Also PORT B, defaults set for analog unless you are changing this. Also 'be aware' that C3. 4 & 5 are all reserved for the USB.
The VREGEN fuse enables the USB Vreg. This requires the capacitor on the Vusb pin (the capacitor is required anyway, even if the regulator is not used).
beaker404
PostPosted: Tue Aug 09, 2016 2:17 pm     Reply with quote
Not using the USB ports on the chip. Poor naming on my part, there is an adapter that goes from TTL to USB on the board. This all works with '877 code. I suspect it is something to do with the 18F chip setup but I have been unable to find anything on the topic. I am using C6 and C7 for serial as the USE statement states.
beaker404
PostPosted: Tue Aug 09, 2016 2:19 pm     Reply with quote
One additional observation, my timing may be off from the crystal, a .5 sec delay seems to be allot longer when observed. Does the CPUDIV still need to be set up? does it influence the hardware UART on pins C6 and C7?
beaker404
PostPosted: Tue Aug 09, 2016 2:46 pm     Reply with quote
UPDATE, figured this one out, needed the CPUDIV1 callout in the #FUSE. That got my timing right and the serial started working again. You were right, default was CPUDIV4 causing my clock to be slow and serial to be way off.
PostPosted: Tue Aug 09, 2016 3:26 pm     Reply with quote
glad to see you got it 'up and running' ! I remember the 'fun' using it, ended up printing the 'possibe clock data paths' diagram and HIGHLIGHTING exactly what I needed. THAT helped me see what bits in which registers had to be set.
One of those 'picture worth 1000 words' moments !!
Jay
gjs_rsdi
PostPosted: Tue Aug 09, 2016 10:18 pm     Reply with quote
Migrating from 16F877 to 18F4520 is strait forward, pin to pin replacement, done it in the past.
If you are not using USB, why the 18F4550?
Best wishes
Joe
PostPosted: Wed Aug 10, 2016 12:35 am     Reply with quote
As I said the default for the CPUDIV is /4... Smile
Have to agree wholeheartedly with gjs_rsdi's comment.
Unless you intend to switch to using the PIC USB in the future, using the 4550, costs you three I/O pins & extra power (the USB PLL permanently runs).
Pointless. There are much easier 'straight swap' chips, and some the offer
extra features (like an extra serial etc..).
The 4550, is a poor choice as an straight upgrade to the 877.
For a modern chip, the 18F45K22, has extra serials, more RAM, more ROM, etc. etc.. It is also half the money!...
The 4520, is also more money now than the more modern chip, though is otherwise a good alternative.
PostPosted: Wed Aug 10, 2016 4:55 am     Reply with quote
Like others, I did the 877 to 4550 thing, when I found out the USB drivers used up 1/3 code space, re thought the PIC choice. I'm now using the 18F46K22 for 99% of projects. Yes, overkill for 99% of them, but 2 HW UARTS, lots of mem and I/O pins! For USB I use a $2 TTL<>USB module.
When you consider PIC4550<>USB, you need to price out connector, caps, resistors, pcb space, etc. That will chew up a good part of $2 ! Then there's the driver space and PCb layout (D+, D- <> D-,D+ !) That $2 module frees up code space, has a couple LEDs, properly connected AND it works !
While there may be a 'better' PIC today, unless you're ordering 10,000 pieces, the additional cost per PIC isn't great compared to R&D costs ( seldom considered) or TIME wasted on 'internal USB issues'.
Jay
PostPosted: Wed Aug 10, 2016 8:04 am     Reply with quote
i want to strongly second jay- 18F46K22 is your friend and so easily back compatible to 4620, 4525 etc etc.
my most recent design was K22 but built with 4525 in production. Just avoid the higher numbered timers for back compatibility.....
(only used the 4525 because we had hundreds unused in old stock .)
4550 is antique history IMHO
PostPosted: Wed Aug 10, 2016 8:50 am     Reply with quote
Just to triple the comment, the 45K22 I mentioned, is the same chip but only half the ROM. I should have said 45K22/46K22. Very Happy
gjs_rsdi
PostPosted: Thu Aug 11, 2016 6:33 am     Reply with quote
As all the veterans have stated, 18F26K22 & 18F46K22 is the way to go.
Still for someone who works with 16F877 will be much easier to move to 18F4520 or 18F45K20 and then to learn how to work with 18F46K22.
I had not small difficulties to migrate from 18F25K20 to 18F26K22
Best wishes
Joe
dan king
PostPosted: Thu Aug 11, 2016 6:36 am     Reply with quote
not to hijack the thread but ....
is anyone aware of a good breakout board with the 46k22 mounted? I have been using the 18f2553 because the Sparkfun breakout board with USB is so convenient. I would consider the 46k22 using an ftdi if a nice breakout was available.
Dan
PostPosted: Thu Aug 11, 2016 6:59 am     Reply with quote
nice inexpensive module
http://www.futurlec.com/PIC18F46K22_Controller.shtml
plus
http://www.ftdichip.com/Support/Documents/DataSheets/Modules/DS_UM232R.pdf
dan king
PostPosted: Thu Aug 11, 2016 7:01 am     Reply with quote
thanks for the links, I'll check it out.
Dan
