Please do not post bug Reports on this forum. Send them to support@ccsinfo.com
AM2320 I2C Relative Humidity & Temperature by Hugo Silva
Post new topic   Reply to topic    CCS Forum Index -> Code Library
younder
PostPosted: Mon Aug 08, 2016 6:19 pm     Reply with quote
Hi guys,
I'm Just sharing this driver for anyone that needs it...
Enjoy!
Hugo
AM2320.h
///                               AM2320.h                                   ///
///        AM2320 I2C Relative Humidity and Temperature Sensor Driver        ///
// Date:          Aug-2015                                                   ///
// Ver.:          1.0                                                        ///
// Author:        Hugo Silva (sergio-hugo@bol.com.br)                        ///
#define AM2320_address                            0xB8
#define I2C_write_cmd                             0x00
#define I2C_read_cmd                              0x01
#define Read_Fct_Code                             0x03
#define Start_address                             0x00
#define Nr_of_Registers                           0x04
const unsigned char read_cmd[3]={Read_Fct_Code,Start_address,Nr_of_Registers};
unsigned char Sensor_data_buffer[8],s;
void AM2320_init() {
     for(s = 0; s< 8; s++) Sensor_data_buffer[s] = 0x00;
void Step_1_Wake_Sensor()
     I2C_Start();
     I2C_Write(AM2320_address| I2C_write_cmd);
     delay_us(800);
     I2C_Stop();
void Step_2_Send_Read_Cmd()
     I2C_Start();
     I2C_Write(AM2320_address | I2C_write_cmd);
     for (s=0; s<(sizeof(read_cmd)); s++) I2C_Write(read_cmd[s]);
     I2C_Stop();
void Step_3_Receive_Sensor_Data()
     I2C_Start();
     I2C_Write(AM2320_address | I2C_read_cmd);
     delay_us(30);
     for (s=0; s<(sizeof(Sensor_data_buffer)-1); s++) Sensor_data_buffer[s] = I2C_read(1);   //data = i2c_read(ack); ack - Optional, defaults to 1. ->1 indicates to ack.
     Sensor_data_buffer[(sizeof(Sensor_data_buffer)-1)]=I2C_read(0);
     I2C_Stop();
void Get_Sensor_Data()
     Step_1_Wake_Sensor();
     Step_2_Send_Read_Cmd();
     delay_us(1500);
     Step_3_Receive_Sensor_Data();
unsigned int16 get_RH () {
     static unsigned int16 RH;
     RH = ((unsigned int16)((Sensor_data_buffer[2] << 8) | Sensor_data_buffer[3]));
     return RH;
signed int16 get_Temperature () {
     static signed int16 Temperature;
     Temperature = ((signed int16)((Sensor_data_buffer[4] << 8) | Sensor_data_buffer[5]));
     return Temperature;
unsigned int16 get_CRC() {
     static unsigned int16 CRC_data;
     CRC_data = ((unsigned int16)((Sensor_data_buffer[7] << 8) | Sensor_data_buffer[6]));
     return CRC_data;
unsigned int16 CRC16(unsigned char *ptr, unsigned char length)
      unsigned int16 crc = 0xFFFF;
      unsigned char s = 0x00;
      while(length--)
        crc ^= *ptr++;
        for(s = 0; s < 8; s++)
          if((crc & 0x01) != 0)
            crc >>= 1;
            crc ^= 0xA001;
            crc >>= 1;
      return crc;
AM2320.c
#include <30F4012.h>
#device ADC=10
#use delay(Internal=117964800)
#use i2c(MASTER, SCL=PIN_E5, SDA=PIN_E4, FAST, FORCE_SW)      //Software selectable I2C
#fuses FRC_PLL16,NOPROTECT,NOWRT,MCLR,PUT64,NOCKSFSM,BORV27,NODEBUG,NOWDT
#include <AM2320.h>
Signed int16 Air_Temperature=0;
Unsigned int16 Relative_Humidity=0;
void Main() {
// Initialize Temperature & RH Sensor data
   AM2320_init();
   while(1) {
         Get_Sensor_Data();
         Air_Temperature=get_temperature();
         Relative_Humidity=get_RH();
Hugo Silva
Post new topic   Reply to topic    CCS Forum Index -> Code Library All times are GMT - 6 Hours
