Will Guest
| Software UART on hardware pins? |
Posted: Fri Dec 12, 2003 10:21 am |
Is it possible to set up a software UART using the hardware UART pins? I would like to use the "invert" option but this isn't available using the hardware UART. I can't see how to tell the compiler not to use the hardware USART.
Will |
Posted: Fri Dec 12, 2003 3:35 pm |
| Quote: | | Is it possible to set up a software UART using the hardware UART pins? |
After some experimentation, I found that by using two separate
#use rs232 statements, you can force the compiler to generate
software USART code on the hardware pins. Example:
#include <16F877.h>
#use delay(clock = 4000000)
#use rs232(baud = 9600, xmit=PIN_C6, INVERT)
#use rs232(baud = 9600, rcv=PIN_C7, INVERT)
main()
char c;
putc(0x55);
c = getc();
This was tested with PCM vs. 3.180. I checked the .LST file
to verify that software USART code has been generated. |
Will Guest
Posted: Sat Dec 13, 2003 5:17 am |
Superb. The only slight problem is I am using streams, but this I have solved myself by assigning an OUT and IN stream to the two #use commands:
#use rs232(baud=9600,parity=N,xmit=PIN_C6,bits=8,stream=OUT,INVERT)
#use rs232(baud=9600,parity=N,rcv=PIN_C7,bits=8,stream=IN,INVERT)
#use rs232(baud=38400,parity=N,xmit=PIN_C1,rcv=PIN_C0,bits=8,stream=VFD)
works a dream, thanks. It’s a shame I hadn’t got the hardware the right way as now I have to work in software without the nice hardware buffer/interrupt! Nothing like a software fix to a hardware problem J
Thanks again,
Will |
