Const struct
in_nursery
Const struct
PostPosted: Thu May 26, 2016 11:12 am     Reply with quote
Hi all
I use this kind of code with older CCS compiler (<5.50) without any issue.
But with latest version 5.59 I get no error but the code is not working any more.
I point out the default at this point
const struct TypeMenu MenuTest[ALL_MENU]
The const struct is not working just struct is working with the last version of ccs.
Is this a compiler error or did I miss something?
#include <18f46k20.h>
#use delay(clock=16000000)
#fuses INTRC_IO, NOWDT, PUT, NOPROTECT, NOBROWNOUT
#use fast_io(c)
#use fast_io(d)
#include "HDM64GS12.C"   // driver GLCD
#include "GRAPHICS.C"   // graphics
#define VAL_TRIS_C 0b00000000   // PORTC
#define VAL_TRIS_E 0b00000000
#define UP     PIN_A1
#define DOWN   PIN_A2
#define ENTER  PIN_A3
#define POWER  PIN_A4   //
#define CANCEL PIN_C0
#define BACKLIGHT  PIN_E2   //
 * Def menu
#define MENU      0      // defaut start
#define ALL_MENU    4
// Tree menu
enum ids{   _BEGIN,
            _MAIN,
            _MAIN1,
                _MAIN11,
                _MAIN12
struct TypeMenu {
             int8 MenuID;
             int8 SubMenu;
             char MenuName[18];
int8 ContainMenu, STATE = _BEGIN, PAGE = 0, LEVEL[7], LevelPtr=0;
Boolean  AccessENTER = TRUE, AccessCANCEL=TRUE;
//const struct TypeMenu MenuTest[ALL_MENU]
        {_MAIN, _BEGIN,"Menu1"},
        {_MAIN1,_BEGIN,"Menu2"},
            {_MAIN11,_MAIN1,"Menu2 sub1"},
            {_MAIN12,_MAIN1,"Menu2 sub2"}
struct TypeMenu MenuPointer[2];
unsigned char SelectFrom(int8 from) {
    int8 i, NumMenu = 0,k=0, i0;
    for(i=0; i<ALL_MENU; i++) {
        if(MenuTest[i].SubMenu == STATE) {
            if(NumMenu == 0) i0 = i;
                NumMenu++;
            if(NumMenu>from && k < 2 ) { //  if(NumMenu>from && k < 2)
                MenuPointer[k] =  MenuTest[i];
                k++;
            if(k == 1) MenuPointer[1] = MenuTest[i0];
    return NumMenu;
int8 QueryLastMenu() {
    int8 i;
        if(MenuTest[i].MenuID == MenuPointer[0].SubMenu)
            return MenuTest[i].SubMenu;
    return 0x00;
short HasSubMenu() {
    char i;
        if(STATE == MenuTest[i].SubMenu)
            return TRUE;
    return FALSE;
 * Init PIC
void PIC_init(void){
    set_tris_c(VAL_TRIS_C);        // graphic lcd control lines all output
    set_tris_d(0x00);         //Set PortD to output
    set_tris_e(VAL_TRIS_E);
    //---- PIC init ------------------------------------------------
    setup_oscillator(OSC_16MHZ);
 * Fonction Menu
void ProcessMenu() {
    if(PAGE > ContainMenu-1) PAGE = 0;
    if(PAGE == 0xFF) PAGE = ContainMenu - 2;
        ContainMenu = SelectFrom(PAGE);
    glcd_fillScreen(OFF);            //Display clear
    glcd_text57(3, 40, MenuPointer[0].MenuName, 1, ON);
 * Fonction quit Menu
void Quit(){
    if(!AccessCANCEL) break;
    if(LevelPtr) LevelPtr--;
    PAGE = LEVEL[LevelPtr];
    if(!HasSubMenu()) {
        AccessENTER = TRUE;
        STATE = MenuPointer[0].SubMenu;
    } else {
        STATE = QueryLastMenu();
    ContainMenu = SelectFrom(0);
    ProcessMenu();
 * Fonction Action Menu
void ProcessAction(long Key) {
    int1 faux;
    faux = FALSE;
    if(STATE == _BEGIN) AccessCANCEL = FALSE;
    else  AccessCANCEL = TRUE;
    switch(Key) {
        case ENTER:
            if(!AccessENTER) break;
            LEVEL[LevelPtr] = PAGE;
            LevelPtr++;
            STATE = MenuPointer[0].MenuID;
            PAGE = 0;
            if(ContainMenu) {
                 ProcessMenu();
            }else {
                AccessENTER = FALSE;
                switch(STATE){
                    case _MAIN:                   //Bat
                        Delay_ms(1000);
                        Quit();
                    case _MAIN1:       //Backlight ON
                        output_toggle(BACKLIGHT);
                        Delay_ms(100);
                        Quit();
            case UP:
                 if(PAGE == 0) PAGE = ContainMenu;
                 PAGE --;
                 ProcessMenu();
            case DOWN:
                 PAGE ++;
                 ProcessMenu();
            case CANCEL:
                if(!HasSubMenu()) {
                    AccessENTER = TRUE;
                } else {
                    ProcessMenu();
            case MENU:
                ProcessMenu();
                Break;
//Main
    //Setup Pic
    PIC_init();
    //Setup LCD
    glcd_init(ON);
    glcd_fillScreen(OFF);            //   Display clear
    STATE = _BEGIN;
    processAction(MENU);
        if(input(DOWN) == 1)
            while(input(DOWN) == 1) {}; // wait for releasing Button1
            processAction(DOWN);
        if(input(UP) == 1)
            while(input(UP) == 1) {}; // wait for releasing Button1
            processAction(UP);
        if(input(ENTER) == 0)
            while(input(ENTER) == 0) {}; // wait for releasing Button1
            processAction(ENTER);
        if(input(CANCEL) == 1)
            while(input(CANCEL) == 1) {}; // wait for releasing Button1
            processAction(CANCEL);
PostPosted: Thu May 26, 2016 12:49 pm     Reply with quote
stuff like this is silly oddly-coded.
case DOWN:
case CANCEL:
that the argument driving the decisions is a pin number designator
is pretty unusual.
in_nursery
PostPosted: Thu May 26, 2016 1:52 pm     Reply with quote
I use this https://www.ccsinfo.com/forum/viewtopic.php?p=123206 since a long time and it has always worked
PostPosted: Thu May 26, 2016 6:58 pm     Reply with quote
What did your code do when it was working correctly, and what is it doing now ?
Example:
"My program used to scroll through the menu when the up/down keys
were pressed. But now it only shows the first menu. The up/down keys
do not cause it to scroll".
or
"My program used to display the menu text. Now it displays garbage".
(Then post the text that it should display, and post the garbage text that
it now displays).
Give us a detailed explanation of how it's failing. Tell us what you see.
in_nursery
PostPosted: Fri May 27, 2016 5:52 am     Reply with quote
on a simple menu like on the example
do not cause it to scroll. It stays stuck at the first menu position. The first position menu is working when I press enter (clear screen and go back to menu after delay)
In more complicated menu key do not scroll and text is garbage.
working : Menu
default : ꟻꟻꟻꟻꟻꟻꟻꟻꟻꟻꟻꟻꟻꟻ
When I only declare
instead of
it work but only with small menu. with big menu I get not enough ram size.
PostPosted: Fri May 27, 2016 6:14 am     Reply with quote
this..
.. should be a clue.
Look at the end of the listing and see what resources are used
ROM%
RAM%
STACK.
'not enough RAM' means there isn't enough RAM to run your program !
The fact you're using a GLCD means you probably ave a HUGE mount of RAM given to the driver's db of 'fonts'. This is not shown in the program you've given us.
Since your 'menu' system/functions worked before, simply go back xx versions, and see what you've done since then. THAT is probably why 'it doesn't work'.
Jay
in_nursery
PostPosted: Fri May 27, 2016 6:19 am     Reply with quote
Hi Jay
I made no change, if a build a version with 5.50 it works if a build a version 5.59 it doesn't.
PostPosted: Fri May 27, 2016 8:53 am     Reply with quote
OK, I copied your program, remarked out the GLCD code and it compiles fine, NO errors. Uses 2% ROM, 3-4% RAM.
One glaring issue I just saw is that you have the interrupts enabled with NO ISRs ! That is very, very bad and will lead to unpredictable problems like crashes, 'funny' results, etc.
Jay
in_nursery
PostPosted: Mon May 30, 2016 6:24 am     Reply with quote
Hi Jay
Your right living the interrupt enable is not a good idea for my sample prog but it's not the cause of the problem I get.
As I told you I have no build error so I suppose it's a buggy version of CCS
PostPosted: Fri Jun 17, 2016 7:20 am     Reply with quote
It is a bug. I finally had time to investigate this thoroughly. There is
a problem with copying an array element from one array to another
when the source is a structure declared as 'const'. There are a few lines
of generated ASM code that are incorrect, starting with compiler vs. 5.057.
I did a complete write-up of the bug and sent it to CCS just now.
PostPosted: Fri Jun 17, 2016 10:54 am     Reply with quote
CCS quickly emailed me a new PCH.DLL file. I used it to replace the one
in the DLL\5.059\ subdirectory in the CCS folder. It fixed the problem.
When I ran the test program shown below in MPLAB vs. 8.92 simulator
it displayed the following results in the Output Window. This is the correct output:
> Menu1
> Menu2
> Menu2 sub1
> Menu2 sub2
Test program:
#include <18F46K20.h>
#use delay(clock=16M)
#define ALL_MENU  4
enum ids{   _BEGIN,
            _MAIN,
            _MAIN1,
            _MAIN11,
            _MAIN12
struct TypeMenu {
             int8 MenuID;
             int8 SubMenu;
             char MenuName[18];
int8 i;
int8 k;
k = 0;
for(i = 0; i < ALL_MENU; i++)
    printf("> %s \r", MenuPointer[0].MenuName);
while(TRUE);
After installing the new PCH.DLL file, the compiler reports its version as
5.060. If you need this DLL file, contact CCS (if you own the compiler)
or wait for vs. 5.060 to be released.
in_nursery
PostPosted: Mon Jun 20, 2016 5:45 am     Reply with quote
thanks PCM programmer for your time and support.
I will contact ccs.
younder
PostPosted: Sun Oct 09, 2016 8:56 pm     Reply with quote
Hi in_nursery
I'm still facing the same problem as yours. With latest CCS Compiler version this menu code doesn't work! Were you able to found a solution for this other than compile the code with 5.50?
Hugo
Hugo Silva
PostPosted: Mon Oct 10, 2016 3:22 am     Reply with quote
I don't think you have the same problem.
The fix, is there in 5.061, 5.062, and 5.064 (just tested all of them, and they run fine).
