skelzer
| Using fat.c |
Posted: Tue Apr 26, 2016 5:58 am |
Hello there,
Could I get any example using the library fat.c where the SD is written via SPI?(http://www.ccsinfo.com/forum/viewtopic.php?t=53787)
I usually like to take my time reading and experimenting, but this time I'm in a bit of a hurry, so...
Thank you very much. |
Joined: 01 Jul 2010 Posts: 9627 Location: Greensville,Ontario
Posted: Tue Apr 26, 2016 6:46 am |
well first place to look is in the 'code library' here...
or general search 'SD'...
also
You MUST use a 3 volt( 'L' series) PIC OR proper logic level translation between the 3 volt SD card and a 5 volt PIC. If you don't .it won't work correctly !!
skelzer
Posted: Tue Apr 26, 2016 7:43 am |
| temtronic wrote: | well first place to look is in the 'code library' here...
also
Hey, thanks for the quick reply
I've tried to use the search and won't return any results when I use SD as the keyword. Anyways, thanks for the tip about the code library, found a few threads there that are being really helpful .
And yes, I'm using a 3 volt PIC, I don't want to fry the SD!
The thing is, I won't have any way to test this until thursday, and it's due friday (Don't you guys love when your deadlines are completely ridiculous? I totally do :D ) so I'm trying to put together a code that'll work quick.
Here I'm trying (or failing hard) to create a file called log1.txt, would this work?
#define MMCSD_PIN_SCL PIN_B10 //o
#define MMCSD_PIN_SDI PIN_B11 //i
#define MMCSD_PIN_SDO PIN_B12 //o
#define MMCSD_PIN_SELECT PIN_B13 //o
main()
mmcsd_init()
char filename[]="log1.txt";
fat_init();
mk_file(filename);
mmcsd_write_byte(0, filename);
Posted: Tue Apr 26, 2016 8:19 am |
Comments in line:
//These need to be declared _before_ you load the mmc library.
main()
//keep to the C standard and declare variables at the start of sections
FILE file_stream; //You need a file variable created.
mmcsd_init(); //semi-colon missing
fat_init();
mk_file(filename);
//Now you need to open the file....
//mmcsd_write_byte(0, filename);
//No. You write to the open [u]file[/u].
fatopen(filename,"w", file_stream);
fatputc('\0',file_stream); //This now writes the 0 byte to the file
fatclose(file_stream); //then you must close the file
while (TRUE)
Also general comment you must have the pull-up resistors on some of the SD lines. required to ensure it wakes in the right mode, and also recommended to speed the rising edges. |
skelzer
Posted: Tue Apr 26, 2016 8:36 am |
| Ttelmah wrote: | Comments in line:
main()
fat_init();
mk_file(filename);
while (TRUE)
First of all, thank you very much Ttelmah for being so thorough, this helps a lot, as I don't even have the IDE in the PC I'm using today, so I'm using notepad.
I think I have the basics down by now, will work on it tomorrow and hope everything works fine on Thursday (Praying to the gods of compilation now...) |
Posted: Tue Apr 26, 2016 9:24 am |
One warning. In the code library you will find three threads, including an SDHC modification, and a couple of fixes for faults in the standard SD driver. There is then an 'accrued' version at the start of the forum as a sticky (from electr0dave). Use this.
This fixes all the current bugs with the MMC driver and also gives support for cards over 2GB. |
skelzer
Posted: Wed Apr 27, 2016 2:02 am |
| Ttelmah wrote: | One warning. In the code library you will find three threads, including an SDHC modification, and a couple of fixes for faults in the standard SD driver. There is then an 'accrued' version at the start of the forum as a sticky (from electr0dave). Use this.
Roger.
I could get my hands on the IDE earlier than I expected, tried this:
| Code: | #include <main.h>
#include <mmcsd.h>
#include <fat.c>
FILE file_stream;
mmcsd_init();
fat_init();
mk_file(filename);
fatopen(filename,"w",file_stream);
But gives me a few errors:
| Code: | *** Error 90 "main.c" Line 17(27,28): Attempt to create a pointer to a constant
*** Error 51 "main.c" Line 18(20,31): A numeric expression must appear here
*** Error 51 "main.c" Line 19(16,27): A numeric expression must appear here
Line 17 is fatopen.
Before I forget, my compiler version is 5.045. |
skelzer
Posted: Wed Apr 27, 2016 2:08 am |
Fixed:
Added the line
| Code: | | #device PASS_STRINGS=IN_RAM |
after the #include <33EP512GP504.h>
and changed the declaration of
to
Posted: Wed Apr 27, 2016 2:15 am |
Needs to be added.
Then all the references to file_stream, need & (except in the declaration). |
Posted: Wed Apr 27, 2016 2:31 am |
Whoa.
Your way of 'fixing' it, means you can be writing to an undeclared area of memory. It'll compile, but won't necessarily work.....
Problem is that:
File *file_stream;
Means that 'file_stream' is now a pointer, but doesn't actually declare any where for it to point 'to'.....
Declaring 'FILE file_stream;' declares the actual variable.
If you want to save typing '&', do this:
FILE actual_stream;
FILE *file_stream=&actual_stream;
Then you can use 'file_stream' as a pointer to 'actual_stream', and it will be pointing to legitimate memory.... |
skelzer
Posted: Wed Apr 27, 2016 2:34 am |
| Ttelmah wrote: | Whoa.
Problem is that:
File *file_stream;
FILE actual_stream;
It's 9 AM in the morning, I've had way too little coffee and I'm absolutely blaming it on that.
Thanks Ttelmah, you're being a real life-saver. |
Posted: Wed Apr 27, 2016 3:06 am |
I'm sorry I left the '&' off when typing my stuff.
We all do it. |
skelzer
Posted: Fri May 06, 2016 2:43 am |
Hello again , things got really busy and I couldn't work on this project, but I'm back on it :D.
It seems the program keeps looping at
If I comment this line here:
| Code: | | #use FIXED_IO( B_outputs=PIN_B2, PIN_B10, PIN_B11, PIN_B15) |
It won't get stuck on that part, but will keep returning -1 (Error I guess).
Any idea why could this be? (I'll be uploading the signals I got with my logic analyzer in a few minutes)
Posted: Fri May 06, 2016 3:51 am |
Have you actually tested that you have the sector read and write working on the device?.
Fat_init, calls the mmcsd_init. This does the speed changes to switch the device up to the faster SPI clock. The way it is written, is fractionally silly. Instead of exiting if mmcsd_init errors, it ploughs on and tries to read, to get the sector size, and data layout. So if the init has failed, it can get into a really problematical state.
I'd be checking that you have the mmcsd driver working properly before trying to get fat working. |
skelzer
Posted: Fri May 06, 2016 4:01 am |
| Ttelmah wrote: | Have you actually tested that you have the sector read and write working on the device?.
I'd swear you comment everytime I'm editing my post...
Will check it out as soon as I'm done uploading the signals I got with the logic analyzer. |
